Samsung un48ju6700 half screen ghosting problem
  • CityZen
    • May 2014
    • 40
    This curved LCD TV has an issue affecting just the right side of the screen. It is not a backlight issue, although it might appear so from one of the attached images. The problem appears to be the right side of the screen not updating properly. Moving images on the very right side will leave a trail of ghost images. Although even just the computer cursor sitting still makes a vertical ghost band the entire height of the image. The color on the right side also looks like it doesn't have the full bit depth (the Windows background looked kind of dithered on that side).
    I went into service mode and ran the various image tests, but all of them showed the same kinds of issues as mentioned.
    Is the problem likely to be the T-con board, or the boards that connect to the bottom edge of the LCD itself, or something else?
    Things I tried already (with no effect):
    - swapping the left/right FPC cables between the T-con board and bottom edge boards.
    - swapping the FPC cables that join the outermost bottom edge boards.
    - undoing/redoing the clamps on the FPC cable between the main board and T-con board.
    - gently pressing along the bottom edge boards and FPC connectors.
    The pink star pattern is this image: https://support.lensstudio.snapchat....D0EBiX_5yg.gif
    that I just magnified until it filled the screen. It's not so obvious in the picture, but on the TV, the color is very faded on the right side.
  • CityZen
    • May 2014
    • 40
    Re: Samsung un48ju6700 half screen ghosting problem
    Here's another picture I'd taken. Notice how the letters "HDMI" get smeared up and down the right side, as well as the disappearing background.
    • neilc6
      • Nov 2015
      • 1550
      It's a bad panel but there may be a workaround. If it has side tabs on the bad side, you can try ripping them all off.
      • chrismurphy
        • May 2014
        • 251
        • australia
        Bad panel pull off side tabs it may work
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4434
          • Italy - Milan
          removing the side tabs is not the best way, its like a finger amputation or similar, check the near thread of Ancient1.
          • CityZen
            • May 2014
            • 40
            From looking at Youtube videos of repairs of Samsung TV's of similar vintage, it seems like there are only tabs on the bottom of the screen.
            (This TV has 60 sets of plastic clips that hold the front bezel and rear metal to the LCD assembly, and I can't see the sides of the LCD without undoing all those.)
            The tabs on the screen bottom have no test points. There are COF driver ICs, but again nothing to problem on the flex either.
            Is it possible that the outer pair of tab boards are the horizontal drivers?
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4434
              • Italy - Milan
              Yes much probably you don't have side tabs, so the only way if i'm right is to block clock lines or start signal to the bad side..
              • CityZen
                • May 2014
                • 40
                Yes, I just now understood what you meant after trying the experiment I mentioned.
                If I leave the outer bottom board disconnected on the problematic side, the result was not as interesting as I hoped: the whole screen fails to show any image.
                I did try various experiments masking out some of the connections, and they did make certain vertical bands of the screen display improperly.
                After thinking about the way LCD screens are driven, I realized that the horizontal rows are only driven by timing signals, whereas the vertical columns are driven by pixel data.
                Only two signals are needed for the rows: the clock (count) and start (reset) signals you mentioned.
                I may try some more masking to see if I can isolate them on the joiner flex cable, but it's kind of tedious. A glass workbench would be helpful, so I don't have to keep lifting the TV up and setting it back flat again each time.
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4434
                  • Italy - Milan
                  it is needed a photo of tcon board without eventual metal frames
                  • CityZen
                    • May 2014
                    • 40
                    T-Con:
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4434
                      • Italy - Milan
                      Remove the sticker and do a photo of that connector area without flash reflection
                      • CityZen
                        • May 2014
                        • 40
                        Okay, took a while, but here are better T-Con pictures.
                        Also, I removed the bezel, and discovered there are side tabs.
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4434
                          • Italy - Milan
                          Follow the near discussion of Ancient1, there are all the directives..
                          • CityZen
                            • May 2014
                            • 40
                            Okay, so if I understand you correctly, you are saying that the right side of the screen is missing either the VGL or VGH drive voltage, and that it might be possible to fix that by measuring the testpoints on the side tabs to look for these voltages, find out where it is missing from (compare left and right sides), and then to find a source of the missing voltage (either on Tcon or bottom drive boards) and wire it to the lowest test point where the signal is missing from. Is that right?
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4434
                              • Italy - Milan
                              It is right except that you better wire it on distribution board not tcon..
                              • CityZen
                                • May 2014
                                • 40
                                Okay, so I wasn't able to get back to this set until this evening.
                                I measured the voltages on the lowest tabs on the left and right sides. I was able to find 26V and -6.6V on both sides. I'm not sure what to conclude from this.
                                • hasitha prasad
                                  • Aug 2021
                                  • 7
                                  • Sri lanka
                                  This is probably due to right side gate COF tab (one of them shorted) issue. I recently repaired a 4k one (Symptoms: right side dark and slow motion image) and I had to remove all the right side COF tabs to get the panel to working correctly. You need to have side COF tabs on both sides of the panel to do that, otherwise this trick won't work and you surely end up with totally useless panel. After removing tabs picture might show little bit discolored (which happened to me in my case) on the right side but only a very sharp eye would notice that. That happens because after removing one side COF tabs the other side's COF tabs has to do all the gate driving on both sides and most of the time they are bit weak for that. Here are some videos that might help you.
                                  https://www.youtube.com/watch?v=c2d68zLWVc0
                                  https://www.youtube.com/watch?v=l5Xx6__1CP0&t=68s
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4434
                                    • Italy - Milan
                                    I can only add to what the previous user said, talking simple, try to cut the vcc that feeds right gate cofs, then turn tv on, then off, join back the cutting, turn again on and hope for the image to come back and good..before this is useful save all tcon eproms content..
                                    • kca
                                      by kca
                                      Hello all ~
                                      08-31-2025, 06:38 AM
                                    • howardc64
                                      Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
                                      by howardc64
                                      TV was fixed just after removing Samsung's rear snap cover.
                                      This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
                                      Maybe PSU->backlight connector didn't have a good contact?...
                                      07-23-2025, 12:34 AM
                                    • JunkmanJimbo
                                      Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
                                      by JunkmanJimbo
                                      Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
                                      No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
                                      Please help. Thanks in advance!
                                      08-12-2025, 11:45 AM
                                    • Ryan.man
                                      by Ryan.man
                                      02-04-2025, 12:23 PM
                                    • Chrissygizmo
                                      by Chrissygizmo
                                      02-10-2025, 12:33 AM
