Sharp Aquos LC-32GD8E
  • gilly1984
    • Jun 2012
    • 751
    Just bought this from ebay.
    Its a Sharp Aquos LC-32GD8E.
    Guy said it wont come on but has standby light, but there is no lights at all, when i plug it in 3 lights flicker on the front of the tv, they flicker once and very fast.
    The psu is a DUNTKD605FM14, all rubys apart from the 2 main filter caps which are Nichicons.
    I get all the correct voltages on the psu apart from the 24v inverter power.
    Attached is the schematics for the hole tv, page 5 is the psu.
    Any help would be great.
    PS, the way the boards are connected together is stupid.
    EDIT,
    I have searched on here but found no similar problem.
    Do NOT touch heatsinks when testing for voltages as they may be LIVE!
    Re: Sharp Aquos LC-32GD8E
    I think the way the boards are attached is excellent. I really like how they do it. Not only does in minimise clutter in the chassis, it means the connectors are really secure and not going to fail. Once you get used to them they are easily removed.
    I may have encountered this PSU before... though it wasn't at fault. I have the SM for the LC-32SD1E, which is probably similar.
    • gilly1984
      • Jun 2012
      • 751
      Should the 3.3v going to the clicky power button short to ground to power up the tv? Because thats what it does?
        Probably. What do you think?
        • gilly1984
          • Jun 2012
          • 751
          No idea, you're the brainy one here
          Is there anything i can check on the mainboard? The relay on the psu doesnt click either, but tested with a 9v battery and the relay works.
          Sugar, forgot to add pics to first post.
            Yep I seen this PSU before.
            Count the blinks when the power is pressed. OPC will blink as will power. This gives you an error code. e.g. 2-5 might be backlight control.
            • gilly1984
              • Jun 2012
              • 751
              Thats my problem, i searched on here and most have a flashing opc light.
              I get no lights whatsoever. No relay.
              All 3 lights flicker when i put the power cord in, very dim and for less than a milli second, its not a code, just the boards receiving power i think.?
                If you have standby voltage and no PSON, suspect the main board.
                • gilly1984
                  • Jun 2012
                  • 751
                  I cant find the pin for PSON, I see BLON for backlights but no PSON.
                    It would appear it uses two signals, PCON1 and PCON2. I note it has a separate 24V power supply, so the PCON signals probably control the individual supplies. Check if they change when power button is pressed. PCONs are on the 2nd largest connector going to the main board assy.
                    • gilly1984
                      • Jun 2012
                      • 751
                      Yh, i see them, will test now. What voltage should i see on them?
                        Any change is good, if they are zero to 3V, or 3V to zero, but the PSU doesn't come up, suspect PSU.
                        • gilly1984
                          • Jun 2012
                          • 751
                          No voltage at all across them.
                          But i did notice that both of them are 15 ohms to ground when power cord plugged in and 1574 ohms when power cord pulled out.
                          Does this tell us anything?
                            It tells us the main board is pulling them low... time to look at the main board.
                            • gilly1984
                              • Jun 2012
                              • 751
                              Is this a bad sign?
                              I see no corrosion anywhere on the boards.
                              • gilly1984
                                • Jun 2012
                                • 751
                                Ok, what should i check first?
                                  1st is flux, normal.
                                  2nd is rust, probably been in someone's garage after it failed.
                                  Follow this guide, you will need to make/buy a cable:
                                  • gilly1984
                                    • Jun 2012
                                    • 751
                                    Ok, got hyperterminal set up, Just need to make a lead.
                                    Will the tv even respond even though it has no opc lights?
                                      It might... but I don't know for sure.
                                      Note: You need to get the firmware from Sharp. I am not sure how you can/would do this.
                                      • gilly1984
                                        • Jun 2012
                                        • 751
                                        Damn, just looked on the site and my tv is not listed for firmware downloads
                                        What could i check on the mainboard, could it be a short?
                                        • scubacamper
                                          Sharp Aquos LC-70C6400U Half Screen Dark
                                          by scubacamper
                                          I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                                          Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                                          when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                                          05-03-2025, 12:19 PM
                                        • sefoster
                                          Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                                          by sefoster
                                          I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                                          11-20-2022, 09:29 AM
                                        • jonah1024
                                          Sharp Aquos LC-40UG7252E LCD TV burn in?
                                          by jonah1024
                                          Hello!
                                          I'm a few days old into this TV screens repair universe so please bear with me.
                                          Recently, and all of a sudden my 40” 4K Sharp Aquos LCD TV turned on with colors all smudged in some places on the screen that remain like that even without any kind of video source. I do have image but the colors are smudged/tinted/ washed out in patches as per defects. This to me looks similar to burn in but I’m shore this is not an OLED.
                                          - I did the classic unplug and hold power button to discharge the caps but it didn't help.
                                          - I did a factory reset as well...
                                          07-16-2024, 04:23 AM
                                        • fixit007
                                          Samsung flicker - BN44-00932T board or else?
                                          by fixit007
                                          I picked up this TV that the prior owner said - just died.
                                          Tested the fuse - burnt. A dead capacitor is visible too on the hot side (CP801). Got the replacement power board (cheaply - used). Replaced the board - the TV turned ON!
                                          Now, about a month later (yesterday) I noticed the left side of the screen was flickering from time to time. That was already happening with the antenna input, not through HDMI.
                                          Also, some glitchiness with a Fire stick on HDMI3 - I hit an app with quick dark screen in stick, the TV goes - no input. Then I had to choose the stick...
                                          05-04-2024, 06:14 PM
                                        • klassic
                                          Sharp Aquos LC-60LE635E three blinks
                                          by klassic
                                          Hi community,
                                          I will describe my problem with a TV in those short following terms to be the most precise :
                                          What i have :
                                          power board DPS-162KP-1
                                          main logic board QPWBXF733WJN2
                                          symptoms :
                                          white led light logo at startup,
                                          after 2 minutes, blinking 3 times a row, repeating
                                          no backlight (and apparently no picture, checked panel with flashlight)
                                          no startup sound
                                          powerboard investigations :
                                          1-2 PNL : 0v
                                          3-4 GND
                                          5-6-7-8 UR : 13.15v
                                          9-10-11-12...
                                          10-24-2023, 01:39 PM
