Fixing another power supply in a monitor after my previous success..
Problem: You press the on button and nothing at all happens, no backlight and no light on the power LED.
So far: Tested the Primary section of the power supply. The main filter cap is reading a stable 336V, BUT the input to the PWM IC reads a wildly varying voltage between 11 and 14V... The capacitor beside the PWM IC also varies wildly between 12 and 16V... Same for the voltages across the Zener diodes, for example zener diode D802 voltage reads between 0 and 6V (sometimes even going negative).
The passive components seem to check out okay.. Still waiting on my new multimeter to be able to check out the MOSFET. Am I right in thinking that the varying voltage is more lightly to be caused by one of the active components malfunctioning?
http://omg.wthax.org/PWB_0560.jpg
(I'll link to the image cos it's very big).
