Asus s301la bios
  • khalid4321
    • Aug 2017
    • 1
    • Saudi Arabia
    Asus s301la bios
    Hi sir
    asus s301la bios dump . I need bios pleas help me
    thank you
  • Elsid79
    • Aug 2015
    • 47
    • Ukraine
    Re: Asus s301la bios
    • tota7
      • Feb 2017
      • 15
      • ISRAEL
      Thanks a lot , its work, and boot FATS
      • Elsid79
        • Aug 2015
        • 47
        • Ukraine
        not at all, always happy to help
        • maurovalero
          • Sep 2018
          • 69
          • colombia
          workinggggg gracias capoooo
          • exerion5000
            • Aug 2014
            • 83
            • Argentina
            Bios For ASUS Q301L Rev 2.0
            Hi.I Need Bios For ASUS Q301L , Board S301LA Rev 2.0 , when adapter is connected the board automatcally turn On in Black screen (fixed consumption 250ma without internal battery), backup attached for repair ,Thanks in advance.
            • peste
              • Dec 2016
              • 12643
              • ROMANIA
              Re: Bios For ASUS Q301L Rev 2.0
              try..
              • exerion5000
                • Aug 2014
                • 83
                • Argentina
                Originally posted by peste
                try..
                Hi.Thank you,same behavior with this Bios,maybe a EC Issue,this board com with IT8585VG,is available EC Rom for this model?.Regards.
                Symptom: With only Battery installed no respond to power on,With AC adapter the board self power on without image , if push power button goto off but when release the button self power on again (every status leds`s On), if unplug the ac adapter the board still on ( by internall battery) , if push power button the board go off but never power on again,only automatically when plug the ac adapter.
                P.D: On board Ram Disable method was applied,same result.
                • peste
                  • Dec 2016
                  • 12643
                  • ROMANIA
                  try..
                  • exerion5000
                    • Aug 2014
                    • 83
                    • Argentina
                    try..
                    Hi again,main bios file was correct (EC is no programmable in this model because carry the IT8585VG),problem was the processor,was replaced by another i5-4200 extracted from scrapp motherboard (HP Folio 1040 g1 with liquid damage), never discard a failed motherboard!,always can use some parts with him.Thanks for repair main file,the Ram disable method work fine,external memory must be DDR3 1.5v (no DDR3L),on-board memory was restablish after repair.
                    • bodie
                      • Sep 2020
                      • 5
                      • Philippines
                      Thank you, its working..
                      • dariusgc
                        • May 2020
                        • 35
                        • Lithuania
                        Hello, can someone clean bios?
                          • 20682
                          Type the laptop serial number, full name and model, motherboard model, etc.
                          read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
                          • dariusgc
                            • May 2020
                            • 35
                            • Lithuania
                            S/N: DCN0BCIRR05N49
                            ASUS Vivobook S301LA
                            S301LA Rev.: 2.0
                            • dariusgc
                              • May 2020
                              • 35
                              • Lithuania
                              S/N: DCN0BCIRR05N49
                              S301LA Rev.: 2.0
                              It seems to work, but when I start Windows loading it gets stuck, on logo, maybę it's a bios issue?
                              • razor_amd
                                [TUTORIAL] fix asus bios with bios from asus web support (by razor_amd)
                                by razor_amd
                                With ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
                                For example, you can have 3 similar ASUS motherboards, all being the same model, all of which will have different BIOS versions.
                                I will give you an example and my version of preparing BIOS from ASUS website and in the process I am always cleaning Intel ME while doing it so you have fully cleaned BIOS, no DMI data, no password, nothing.
                                This is the picture of 3 similar ASUS motherboards, all of them being X555LD...
                                12-15-2020, 07:07 PM
                              • grimacelord
                                ASUS TUF GAMING Z790-PLUS WIFI - BIOS Help
                                by grimacelord
                                I have spent the last hour on this and I guess this is just over my head, so here I am.
                                I have an ASUS TUF GAMING Z790-PLUS WIFI motherboard here that needs to have the BIOS updated in order to accept the latest CPUs.
                                The BIOS chips seem to come as a set of two: GD25B64ESIG and GD25B128ESIG. My guess is one of them is a fail-safe for the main BIOS? I really don't know. Or one of them is ME and other is BIOS? I don't know.
                                Anyway, I took dumps of both chips and then downloaded the latest update for this motherboard from ASUS's website...
                                07-10-2025, 02:52 PM
                              • throwaway327
                                Asus ROG Ally X -RC72LA - changed hidden bios settings with 'Smokeless-UMAF', won't get past boot logo
                                by throwaway327
                                ASUS ROG Ally X - (Handheld Gaming PC)
                                Model No: RC72LA
                                Serial No: SBNVKD001014459
                                Hi all, I've spent the past week digging through the forums and guides to try correct my foolish mistake of changing hidden settings while tinkering around, and to be honest my heads overloaded so I'm hoping you'll be able to help.
                                I used a tool called 'Smokeless-UMAF' to access usually hidden settings in the bios. I tweaked one or two 'safe' things but made the mistake of tweaking a lot of settings under 'USB/Thunderbolt Configurations' when I didn't know what they did. For...
                                06-18-2025, 05:52 PM
                              • jbonavita
                                by jbonavita
                                Some issues
                                Things I tried
                                04-29-2025, 09:38 PM
                              • lrouw84
                                Asus vivobook s510ua bios changed to x510un
                                by lrouw84
                                Hi there,
                                I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
                                I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....
                                01-28-2023, 01:31 PM
