Asus s301la bios
  • khalid4321
    • Aug 2017
    • Saudi Arabia
    Asus s301la bios
    Hi sir
    asus s301la bios dump . I need bios pleas help me
    thank you
  • Elsid79
    • Aug 2015
    • 47
    • Ukraine
    Re: Asus s301la bios
    • tota7
      • Feb 2017
      • 15
      • ISRAEL
      Thanks a lot , its work, and boot FATS
      • Elsid79
        • Aug 2015
        • 47
        • Ukraine
        not at all, always happy to help
        • maurovalero
          • Sep 2018
          • 69
          • colombia
          workinggggg gracias capoooo
          • exerion5000
            • Aug 2014
            • 83
            • Argentina
            Bios For ASUS Q301L Rev 2.0
            Hi.I Need Bios For ASUS Q301L , Board S301LA Rev 2.0 , when adapter is connected the board automatcally turn On in Black screen (fixed consumption 250ma without internal battery), backup attached for repair ,Thanks in advance.
            • peste
              • 13924
              • ROMANIA
              Re: Bios For ASUS Q301L Rev 2.0
              try..
              • exerion5000
                • Aug 2014
                • 83
                • Argentina
                Originally posted by peste
                try..
                Hi.Thank you,same behavior with this Bios,maybe a EC Issue,this board com with IT8585VG,is available EC Rom for this model?.Regards.
                Symptom: With only Battery installed no respond to power on,With AC adapter the board self power on without image , if push power button goto off but when release the button self power on again (every status leds`s On), if unplug the ac adapter the board still on ( by internall battery) , if push power button the board go off but never power on again,only automatically when plug the ac adapter.
                P.D: On board Ram Disable method was applied,same result.
                • peste
                  • 13924
                  • ROMANIA
                  try..
                  • exerion5000
                    • Aug 2014
                    • 83
                    • Argentina
                    try..
                    Hi again,main bios file was correct (EC is no programmable in this model because carry the IT8585VG),problem was the processor,was replaced by another i5-4200 extracted from scrapp motherboard (HP Folio 1040 g1 with liquid damage), never discard a failed motherboard!,always can use some parts with him.Thanks for repair main file,the Ram disable method work fine,external memory must be DDR3 1.5v (no DDR3L),on-board memory was restablish after repair.
                    • bodie
                      • Sep 2020
                      • 5
                      • Philippines
                      Thank you, its working..
                      • dariusgc
                        • May 2020
                        • 45
                        • Lithuania
                        Hello, can someone clean bios?
                          • 22293
                          Type the laptop serial number, full name and model, motherboard model, etc.
                          read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
                          • dariusgc
                            • May 2020
                            • 45
                            • Lithuania
                            S/N: DCN0BCIRR05N49
                            ASUS Vivobook S301LA
                            S301LA Rev.: 2.0
                            • dariusgc
                              • May 2020
                              • 45
                              • Lithuania
                              S/N: DCN0BCIRR05N49
                              S301LA Rev.: 2.0
                              It seems to work, but when I start Windows loading it gets stuck, on logo, maybę it's a bios issue?
                              • razor_amd
                                by razor_amd
                                12-15-2020, 07:07 PM
                              • pirati
                                by pirati
                                10-27-2025, 04:20 PM
                              • grimacelord
                                by grimacelord
                                07-10-2025, 02:52 PM
                              • jbonavita
                                by jbonavita
                                Some issues
                                Things I tried
                                04-29-2025, 09:38 PM
                              • throwaway327
                                by throwaway327
                                Model No: RC72LA
                                Serial No: SBNVKD001014459
                                06-18-2025, 05:52 PM
