Question for Budm (and everyone else) for fsp212-3f01 Power Supply
  • Paul678
    • Nov 2011
    • 402
    Budm,
    Are these your photos?
    http://s807.beta.photobucket.com/use...F2180.jpg.html
    And if so, was replacing Q7 and the ZD4 zener successful for you? These
    two components were shorted out on my unit.
    This site:
    http://www.tv.quuq.org/index.php?ind...y_view&iden=74
    ....Also recommends replacing R65 5R1 smd, but this component measured
    good on my board.
    Re: Question for Budm (and everyone else) for fsp212-3f01 Power Supply
    Yes, that is my picture, it is the common failure for this power supply. Fixed many of them. It is setup as a linear regulator to supply the VCC for the 5VSTBY.
    • andytv
      • Oct 2013
      • 19
      • canada
      Hi, Just join the forum, great info. Glad I could found info. for my Viewsonic PS. Already replace the cap. and found (thanks to this thread) that in fact Q7 and the ZD4 are shorted out. I will replace Q7 with a 2N2222a but need confirmation on the Zener, 15V 1/2W zener ?????
      Thanks.
        I use 1N4744 (1W) in my repair.
        • andytv
          • Oct 2013
          • 19
          • canada
          Thank you. Hopefully this should bring back to life the PS.
          • andytv
            • Oct 2013
            • 19
            • canada
            My old ... Viewsonic now working like a new one. Capacitors and replacement of Q7 and the zener diode solved the problem. Also had a problem with "leaking" color from the screen, (top left), similar to someone dragging their fingers on a fresh coat of paint. Problem also corrected, I guess problem was caused by the defective caps. Many thanks to this forum and specially to Budm, help greatly appreciated.
            • 12rounds
              • Sep 2014
              • 41
              hello gentlemen,
              came across this thread while trying to finish repairing a fsp212-3f01 psu in a viewsonic n3251w; it has the only partial schematic of the psu that i have been able to find so far. I started with a dead totally dead tv - even after replacing all the visibly exploded electo caps. q7 and the adjacent zener brought the +5vdc portion back to life, giving me a red led on the front which will turn green when pushing the power button. My problem is that now i don't have the +12 and +24. Any thoughts as to where to start?
              Thanks!
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
                by sam_sam_sam
                03-31-2024, 02:12 PM
                by sam_sam_sam
                07-01-2024, 06:34 AM
              • shamsudeen
                Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                by shamsudeen
                Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                i know that in linear power supply the noise will be very low comparing to SMPS supply....
                07-19-2025, 07:14 AM
              • JimBanville
                Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                by JimBanville
                The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                09-13-2023, 07:21 AM
