well... i got a Proview LP917W (Model: 900W) 19" Widescreen LCD on my bench right now.
symptoms were:
- turns off after 2 to 10 seconds
- red tint
- hissing noise
replaced all caps in there with rubys... just to find out that the caps weren't the main problem..
the hissing noise is gone now, but it still turns off after 10secs (cold) to 2secs (warmed up)
after some research here, i found out that the CCFL tubes are worn out and are overloading the inverter, so it turns the CCFLs off (OLP).
i then went through the trouble disassembling the panel itself to get to the CCFL tubes.
i somehow managed to do that without destroying anything.. *yay*
okay .. now i got the CCFLs here on my desk.
2 of them in a aluminum frame (4 in total).
when connected to an external inverter (without OLP ... one of those cheap ones that comes with those PC modding CCFLs..) they do actually light up, but the first pair (lower ones) isnt evenly lit and has the ends of one tube totally black, and the other one ..
well... let me put a line break here first ;P
the other pair has all ends totally black, but one of the 2 CCFLs actually lights up red-ish/pink instead of white!? WTF?
took some (bad) photos of that..
lower pair (unevenly lit ; left side brighter than right)
http://bambooz.pytalhost.net/Proview/DSC07062.JPG
ends of those tubes..
http://bambooz.pytalhost.net/Proview/DSC07065.JPG
http://bambooz.pytalhost.net/Proview/DSC07066.JPG
upper pair of CCFLs..
http://bambooz.pytalhost.net/Proview/DSC07068.JPG
http://bambooz.pytalhost.net/Proview/DSC07072.JPG
http://bambooz.pytalhost.net/Proview/DSC07069.JPG
so those are pretty much toast
problem is: where the hell do i get replacement CCFLs ?!
the length is the main problem..
the original CCFLs are 2mm diameter and 415mm long (length of the tube without metal contacts)
i found some probably matching ones on digikey germany
http://search.digikey.com/scripts/Dk...me=289-1137-ND
digikey part number 289-1137-ND
but they are 2,4mm diameter and 437mm length (allthough i don't know if that's with or without the metal pins..)
problem is: i would need 4 of those...
4x 12,26 EUR = 49,04 EUR...
almost 50EUR (about 64 USD) in replacement CCFLs for a 119EUR (new) LCD.. okay.. let's forget that
another shop i found on the net has 2,6mm dia 415mm length (without contact pins) CCFLs in stock, but they're even more expensive...
4x 21,42 EUR = 85,68 EUR ... so that would be about 86 EUR (about 109 USD!!!) for those CCFLs-..
and that LCD Monitor sells (new) for 119 EUR at the moment.. sometimes even 99 EUR
i already thought about alternatives...
for example..:
- using one fat 3mm+ CCFL instead of two 2mm ones
- using two cheap 310mm ones aligned so that they light up the screen halfway evenly (see attached pic for what i mean with that.. don't know how to describe that in english >.> )
- using LED stripes instead of CCFLs. this would mean more work to get it working, but it would probably last _much_ longer than any CCFL...
to show you what i mean with LED-stripes..:
sooo.... any ideas where to get replacement CCFLs cheap or what else to do with this thing..!?
it's just too good to be just thrown away, as the LCD works fine (except the backlight) and its a 19" widescreen :/
symptoms were:
- red tint
- hissing noise
for example..:
