Capacitors, Aqueous-Nonaqueous
  • Brewster
    Old School
    • Jun 2007
    • 8
    O.K. I'm aware of the debate between aqueous vs nonaqueous caps, but how do I determine if a cap is or isn't? More specificly Panny FJ,FK,FL and Ruby ZLH.
    I haven't noticted it listed on data sheets, or am I just blind? Thanks.
  • starfury1
    • May 2006
    • 1256
    Re: Capacitors, Aqueous-Nonaqueous
    No real answer for you
    Actually that is an interesting question, I was wondering myself ?
    I dont know, I guess maybe the manufacture publish something?
    maybe the type of electrolyte used
    (although I think they may keep that info close to their chest so as to speak)
    PeteS in a post round here somewhere did talk about baking them @ temp
    The ones that last the longest are would most likely non aqueous type.
    I go by whats said by those in the know here.
    but yeah its a good point
    Were do you get this information?
    maybe something it the spec gives it away as being one type or another.
    (but guess those here would want more then that as conformation of which type)
    Can anyone comment on this
    Cheers
    You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...
    • linuxguru
      • Apr 2005
      • 1564
      FJ, ZLH - aqueous.
      FK - non-aqueous.
      FL - unsure.
      No specific electrical measurements are conclusive, but the ultra-low ESR caps are invariably aqueous, while caps specified as long-life are often non-aqueous. It's pretty blurry out there, especially for some Rubycon offerings like the ZT - they're aqueous, but have most of the properties of non-aqueous caps.
      • gonzo0815
        • Feb 2006
        • 1600
        I think the higher the endurance and the higher the temp the lower the h2o content in the electrolyte and vice versa.
        ESR values are related too, but this is a field of constant improvements in both fields.
        Other then that and PeteS first hand test results you can`t answer this question.
        And i assume, that no mfr will openly share this knowledge with anyone not affiliated.
        • starfury1
          • May 2006
          • 1256
          yeah thats what I thought Gonzo thanks
          Thanks Linuxguru too.
          Following on from the above it makes a bit of sense when you think FC are worst specs (in some respects) then FM but FC are suppose to be Non-aqueous and FM is Aqueous.
          So what you use is going to depend on what parameters of the cap you need to exploit, and as always its a few things and some trade offs always come into play
          I guess
          is what will make it a bit harder to workout which is which and possibly we may not need to worry to much about it as time goes on.
          (not that I think people overly worry now but from a design point its probably a good idea to consider and from a repair side for max life its good to know which type I suppose)
          not really of any help to the original question but bit on electrolyte here
          http://en.wikipedia.org/wiki/Electrolytic_capacitor
          http://www.faradnet.com/glossary/e_gloss.htm#eccap
          http://electrochem.cwru.edu/ed/dict.htm#e12
          caps here
          http://electrochem.cwru.edu/ed/encyc...electr-cap.htm
          I'll have to find that post PeteS made on cooking them, got me wondering what he said now
          Cheers
          • PeteS in CA
            • Aug 2005
            • 3586
            • USA, Unsure of Planet
            Broad-brushing a bit, you may be able to infer which are aqueous-electrolyte types from a couple of things in the datasheets. Ignoring Rubycon for a moment, if you look at Panasonic, UCC and Nichicon, the non-aqueous series, e.g. FC, LXZ, PW and PA, are rated for -55C and the impedance at -10C is double the 20C impedance. The aqueous series, e.g. FM, KY, KZE, KZG, HE, HD, HM, HN and HZ, are rated for -40C or -25C (HM, HN and HZ) and the -10C impedance is ~3X (2.7X - 3.9X is the parts whose specs I checked out) the impedance at 20C. IOW, the performance of aqueous electrolyte caps at low temps falls off faster than the performance of non-aqueous caps. With UCC, their non-aqueous series are LX(x), while their aqueous series are KY or KZ(x). With Nichicon, their non-aqueous series are P(x), while their aqueous series are H(x).
            The above seems true of Rubycon low impedance parts, with the possible exception of the YXF series. YXF is rated for -40C and the -10C impedance is ~3X the 20C impedance, suggesting that the electrolyte is aqueous, but one of their marketing types told me that it is non-aqueous. My guess is that either he misunderstood my question or that he is incorrect. ZL is the low impedance, long life series Rubycon is recommending for demanding applications such as power supplies and DC-DC converters. VRMs may need the ultra low impedance of MCZ.
            PeteS in CA
            • linuxguru
              • Apr 2005
              • 1564
              PeteS: Thanks, that's a very useful criterion. Even if the datasheets don't show this information, a test rig consisting of an AC bridge, a thermometer, some dry ice/refrigerator, and a few other odds and ends is enough to measure the impedance/temperature curve sufficently accurately to make this determination.
              • starfury1
                • May 2006
                • 1256
                Thanks PeteS....
                So the Above "As a rough rule of thumb" but no Guarantee comes with it
                (thats what I suspected something it the specs might give it away)
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  Suggestion:
                  See if you can locate the MSDS (Material Safety Data Sheet) for what ever series you want to know about.
                  Mann-Made Global Warming.
                  - Dr Seuss
                  • dragon3x
                    After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                    by dragon3x
                    Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                    power on.
                    Here are some examples :
                    (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                    switching supply area).
                    (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                    than 6.3 V.)
                    1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                    I replaced capacitors with aluminum-polymer.
                    3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                    03-21-2025, 02:46 PM
                  • slybunda
                    AA and AAA battery charger capacitors?
                    by slybunda
                    hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                    it has inside:
                    2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                    2 x 470uf 16v LZ105c branded as G.Luxon
                    not heard of these brands are they any good?
                    iv attached photos of the charger and the board inside for an idea on the type of...
                    12-24-2023, 04:41 AM
                    Panasonic switching power supply daughter board has two 27uf @ 50 volt capacitors which I do not keep in stock
                    by sam_sam_sam
                    I did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
                    This is one of the shit est boards I seen in a very long time and it was the daughter board the traces just lifting off the board I had to use the capacitor leads to repair the the traces and the main board is not any better because I had to repair several traces for the daughter board to the main board
                    After all of...
                    07-13-2024, 08:14 PM
                  • Cama
                    Solar Inverter - SMH-II - 2 missing capacitors
                    by Cama
                    I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
                    My model is : EASUN SMH-II 7 KW
                    Mother Board : P/N 18947-002401250250
                    Maybe the EASUN SMH-II 4.2 KW have the same capacitors
                    Thank you...
                    09-12-2025, 02:50 AM
                  • Ady2017
                    Are there any datasheets available for Elna RJG capacitors?
                    by Ady2017
                    I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
                    05-25-2025, 02:19 PM
