Samsung Plasma power supply, blown standby IC
  • Maxxarcade
    • Jul 2006
    • 973
    Working on a 42" Planar plasma TV that uses a Samsung power supply. IC2 is melted, which appears to be the IC for the standby power circuit.
    The power supply is Model B4K-50, Assy #LJ44-00051A.
    Anyone here worked on one of these that could tell me the chip number? It's too burned to read. It is an 8 pin IC, with only 7 pins attached.
    I checked around and did not find any other shorts, and no fuses are blown. I'll be checking the caps before I power it up with a new chip.
  • Krankshaft
    • Jan 2007
    • 2328
    Re: Samsung Plasma power supply, blown standby IC
    Does it have an external switching transistor?
    If not then it's probably a Power Innovations TOP IC (PWM and Switcher in one 8 pin package). They are used alot in low power applications (especially standbys) where small part count is a priority.
    • Toasty
      • Jul 2007
      • 4171
      Samsung PS42P3S ?
      B4K-50 - a.k.a. BN96-00249A
      See this thread. Maybe OP will have other pics or can look at his.
      https://www.badcaps.net/forum/showthread.php?p=93294
      Good Hunting!
      veritas odium parit
      • Maxxarcade
        • Jul 2006
        • 973
        Originally posted by Toasty
        Samsung PS42P3S ?
        Good Hunting!
        Thanks, I was able to find the service manual for that PS42P35, which uses the same power supply as this Planar set. Looks like the chip is an IEC2A280. I can't find one anywhere though
        • ecking767
          • Oct 2009
          • 492
          Hello Maxxarcade
          This website sell the chip you need
          http://www.bluestar-online.com/Searc...14&Search.y=17
          good luck with your repairs
          ecking767
          • Maxxarcade
            • Jul 2006
            • 973
            Originally posted by ecking767
            Hello Maxxarcade
            ecking767
            Thanks!
            I'll order the chip, and post the results when I get it installed.
            • Toasty
              • Jul 2007
              • 4171
              >>Looks like the chip is an IEC2A280. I can't find one anywhere though<<
              Does your Google not work???
              Bluestar is the first hit, then Digikey (min qty 2000) and then Mouser a few after that.
              Mouser stocks them too, at 1/3 the price.
              http://www.mouser.com/search/Product...kTzhe9BA%3D%3D
              I wouldn't think these just blow out like that without some other component failure. I'd do some investigating of surrounding components before ordering.
              veritas odium parit
              • Maxxarcade
                • Jul 2006
                • 973
                Wow, I must have left out a letter or something. Nothing turned up when I looked earlier.
                I will inspect the circuit before I power it up. There's not much to it though. The voltage comes off the bridge and goes right to the chip, then the chip goes right to the transformer. This TV was used in a bar and may have been hit by a power surge. I'm sure there are some bad caps too. I already replaced 3 leaking Samwha's in another section.
                This was another situation where the circuit blew to protect the fuse, instead of the other way round
                • Wizard
                  • Mar 2008
                  • 2296
                  This can cause by bad transformer or the output diode or shorted load.
                  Yes, this is all in one smart PWM with power MOSFET transistor built in. Nice stuff.
                  There are MOV around the input filter network as well. Check other items to make sure board is salvageable.
                  Cheers, Wizard
                  • Krankshaft
                    • Jan 2007
                    • 2328
                    The datasheet says that it has over voltage and over current protection if the IC sensed an overload then it should have shut down by removing drive from the FET according to the datasheet.
                    The only way it would have flared up like that is if the internal switching FET shorted out protection circuit can't do anything then. The damage does look like it could have come from a power surge.
                    But be sure to check the bridge rectifier, transformer with a DMM, and the output rectifier as suggested. When something blows up this bad you have to check the surrounding parts to prevent a repeat.
                    Hope the traces are still in good shape otherwise you're going to have to do some reconstructive surgery.
                    • Maxxarcade
                      • Jul 2006
                      • 973
                      Just letting you guys know that I got it working. Had to replace a few caps, a resistor, and the IC.
                      • Krankshaft
                        • Jan 2007
                        • 2328
                        Nice job!
                        Another TV saved from the landfill.
                        • Wizard
                          • Mar 2008
                          • 2296
                          Excellent!
                          Cheers, Wizard
                          • glegge
                            • 2
                            Hey, is there any chance you could forward the service manual for the lj44-00051a onto me? as you say, it's used in the ps42p35 manual you found.
                            many thanks
                            kind regards all the way from New Zealand
                            Gavin
                            • Maxxarcade
                              • Jul 2006
                              • 973
                              many thanks
                              Gavin
                              What's your email?
                              • Krankshaft
                                • Jan 2007
                                • 2328
                                I'd recommend you send your e-mail through PM alot of spammers use crawlers to capture emails from forums.
                                • Maxxarcade
                                  • Jul 2006
                                  • 973
                                  Well, I got 4 more of these sets in, all with the same problem. I had to order more caps because I went through so many in one night.
                                  However, one of them also has a blown KA1M0880B IC. None of my familiar sources carry that part. Is it possible that there is an updated replacement or cross?
                                  • chevelle_nut
                                    • Dec 2008
                                    • 62
                                    The Fairchild site lists that as a good #, but if it has the KA1M0880BYDTU they suggest using a FS7M0880YDTU. They also list a FS7M0880 power switch as well.
                                    hope this helps
                                    • Maxxarcade
                                      • Jul 2006
                                      • 973
                                      hope this helps
                                      Yep, I found that info the other day and ordered one to try. The replacement is 70Khz and the original is 67Khz, so hopefully they are truly compatible. I'll probably have to re-adjust the output voltage, but no big deal.
                                      • glegge
                                        • 2
                                        What's your email?
                                        hi there, thanks for replying, sorry it's taken so long to get back, but i dont check in here often.
                                        my email is glegge@clear.net.nz.
                                        I've had a go tonight at fixing the supply. after replacing caps, i get a red light on the control board above it, and the green light comes on but no VS voltage.
                                        I'm guessing it's the big NEC mosfets 'NEC k2372' (shorted) and the IR2109 (now has it's lid blown off).
                                        i'm really looking forward to getting the schematics so i can trace this fault down easier and get this set going again.
                                        many thanks!
                                        i really appreciate your forwarding on this schematic.
                                        Gavin
                                        • cheeky2
                                          Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
                                          by cheeky2
                                          This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
                                          I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
                                          Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
                                          06-15-2025, 05:12 AM
                                        • lp20th
                                          Samsung Plasma TV Power Supply Issue
                                          by lp20th
                                          I have a vintage 2008 Samsung 50” Plasma TV, Model code PN50A550S1FXZA with a power supply part number BN44-00222A. I repaired the power supply board several years ago finding a couple of cold solder joints on the back side of the board and it's worked great up until now. Recently a fried sound occurred with the smell of burnt electronics and the TV shut down. Trying to turn it back on yielded the typical relay clicking with no TV boot up. Upon investigation, removing feeds to the other boards within the TV it was found that disconnecting the logic board from the power supply allowed the...
                                          11-28-2023, 10:28 AM
                                          09-07-2024, 05:50 AM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                        • rju
                                          Samsung 60" Plasma TV, Blinking Standby LED
                                          by rju
                                          A sports bar/restaurant with ~40 Samsung Plasma TVs. This is the 2nd TV that has a blinking standby LED. I'd like to learn how to repair these TVs because I'd guess that over time more and more of them will develop this symptom. My hope is to repair the bad PCB, however if that's not realistic then I'd replace the bad PCB.
                                          Model PN60F5300AF, Type PN60F5300, Model Code PN60F5300AFXZA
                                          Upon applying power, the red standby is steady. When I tap the power button, the standby LED immediately blinks twice, then it blinks once ~ every 4 secs. Also, Upon applying power, the...
                                          07-21-2020, 05:23 AM
