LG5270 LCD TV - Lines and designs
  • OldMan
    • Jun 2011
    • 47
    Picked up a 52" LG LCD which turned on to a very dimly lit screen. I figured it was a power or display drive board issue. I hadn't touched the TV because of a busy schedule in about 2 weeks and today when I was testing it I encountered a very different symptom. It now turns on and has sound if an input is plugged it. The video comes up as rainbow vertical lines and strange grey boxes. I have attached a couple pictures to illustrate what I mean.
    I can unplug one of the 4 ribbon cables going to the TCON board and make that quarter of the screen to black. Depending on which portion I unplug, the colors come and go as expected.
    I'm wondering if anybody has experience with this or could weigh in on if my TCON has failed (never encountered this in my repairs) or if I have a strange LCD failure (typically fail with just lines and no designs)
    Any comments/suggestions are appreciated.
    Re: LG5270 LCD TV - Lines and designs
    This definitely resembles a video board failure - either the T-con or main board. The split in the screen definitely leans towards a T-con issue. I doubt it's a panel failure, it's too "discrete" - panel failures usually lead to black bars or blurry parts.
    If you connect a video+audio source to the TV, can you hear anything from the speakers? You may need to flick through the inputs using the INPUT button.
    • OldMan
      • Jun 2011
      • 47
      tom - yes I can get audio out of the speakers. I've only tried the vga input with my laptop but in my experience once i have audio once, it works on all inputs. i've also had experience where if audio works, the video works once i replace another part on board (tcon,inverter,psb)
        Can you check the supply voltages on the PSU? Post a picture of it if you need help. I have seen this symptom with a bad PSU.
        Also, do the lines move or change if you turn the TV off and on?
        BTW, my LG 42LC46 dims the screen with no input so I think that isn't a problem if the screen is dim with no input.
        • infringer
          Badcaps Member
          • Sep 2009
          • 244
          • United Frickin States
          Tom66 if the lines did move would you say this is more so the video board or TCON board you brought up an interesting comment just figured I would dive further into it.
          Please note: I am not responsible for any harm caused to you anything discussed is just discussion. Before you try anything discussed be sure that you have the appropriate knowledge and safety gear for the job. Like with anything education and safety are first! Do not try anything @ home without it.
          • OldMan
            • Jun 2011
            • 47
            Lines do not move from their positions when TV is turned on/off. I checked several times. I did notice that the lines seem to gradually appear from middle to edges over about 3seconds when I power on. Almost like a slowly appear PowerPoint transition (if you're familiar with this look)
            Voltages seem quite normal. Standby is 5v. Power to main is 12v when on. 24v to inverters.
            I'm thinking about replacing the TCON at this point....
              Yeah, 95% sure that's a T-con issue. Main boards don't cause a fading effect usually. Just make sure you order the one for the exact panel in your TV (check if it is an LG.Philips LCD panel.)
              • OldMan
                • Jun 2011
                • 47
                I'll update back with what I find out. Hopefully ordering the new TCON tonight. Stay tuned.
                • OldMan
                  • Jun 2011
                  • 47
                  Here is where I stand:
                  I've replaced the TCON board with the exact board and it solved my initial issue with the lines. However, now that my lines are gone I don't have any video showing up. The screen still illuminates telling me the inverters are just fine. My sound also works, even when I switch to different inputs. Switching out the video board with another of the same number does not change anything.
                  So what should I test next? Perhaps my video board is not getting the power needed to output video? I did
                    So the screen just have slight glow to it without any pictures or on screen menu? It sounds like a dead T-CON or it is not getting the power. Cable seating are good?
                      I suspect you got a dud T-con or the LVDS is not properly seated. If the LVDS is good, return the T-con and try again. The T-cons are pulls from cracked screen TVs so no-one can be totally sure they are good and many don't bother testing them at all.
                      • OldMan
                        • Jun 2011
                        • 47
                        I will try to return the board. Seated the cables many times in case it was the issue, but no such luck. I'll try for another T-CON I guess.
                        • electronicsurplus
                          • Jun 2012
                          • 210
                          I agree with Tom66 that the problem is with the T-conn or LVDS cable. you might be able to determine which, in some cases by moving the LVDS cable or wiggling the cable to see if any changes at all.
                          Also,you can try by heating the board with a heatgun or by placing in an oven @ 300 degrees for 5-10 minutes to re-seat the ic's. but be sure to cover and plastic connectors in aluminum foil with some heatsink compound, if available, to prevent melting. this has worked for me with a few tcons when not available. surely worth the try doesn't cost much
                          This Forum absolutely the best and, the most helpful forum I have ever found anywhere. thanks to all the fantastic members here
                          Help keep these from the landfills
                          • OldMan
                            • Jun 2011
                            • 47
                            Which TCON do you think is bad -- the one which gives me the lines shown in my initial post to this thread or the one I now received which gives no color? Both? Or maybe this suggests cables?
                              Both. Your original one was bad, and the new one was not tested, IMO.
                              • OldMan
                                • Jun 2011
                                • 47
                                Over 1 year and two moves later I've turned my attention back to this TV. Model is 52LG70, not LG5270 as I stated in my first post to the tread.
                                I've managed to get a working TCON into the set which resolved my lines issue but I have another problem now. The TCON has 4 ribbon cables coming out - two from top and two from bottom which control their respective portions of the screen in a quarter area fashion. When I have the top two ribbons plugged in I get perfect picture on the top 45% of the screen. If I plug in only the bottom two or all 4 I have a totally black picture. I'm envisioning a faulty circuit out the bottom of the TCON to the panel which feeds back and keeps all picture black. Something probably got shaken up during my moves...
                                Anyone have experience with a 4 ribbon TCON and know where I might check first? I'm hoping I do not have to completely disassemble the set to fix this issue.
                                • OldMan
                                  • Jun 2011
                                  • 47
                                  I got bored tonight and went back to this TV....
                                  To update on my last post here is what I've found. If all 4 ribbons are plugged into the TCON the screen is black on start up. Removing each ribbon one at a time from left to right on top and left to right on bottom next, replacing after each before moving to the next I have the following picture displayed with backlight on and volume at all times....
                                  CN4 (top left) = black picture
                                  CN5 (top right) = black picture
                                  CN6 (bottom left) = black picture
                                  CN7 (bottom right) = picture on ~75% of screen with bottom left of screen now being black with a few lines
                                  I've attached pictures to complement what I've written here. Swapping out LVDS cable does not impact what I'm seeing in any case. Nor does a swapping TCON. Both scenarios display the same black screen unless bottom right ribbon cable is unplugged from the TCON board.
                                  Could the ribbon cable that goes from TCON to the panel be the faulty component in this TV? If so, whats the best means of confirming this is the case? How would I find a replacement?
                                  • Clydeuk
                                    • Jan 2012
                                    • 193
                                    Can you not swap around these ribbon cables to check? Say switch the bottom left and right ones around, do the same tests you mention above and see if the fault moves to the other side? From the pictures they appear to be the same though I can't be sure.
                                    For what it's worth (I hope I'm wrong) I think you have a failure of one of the driver ic's on the bottom right section, removing it's ribbon is removing the problem allowing the remainder of the display to function. That would mean a faulty panel obviously.
                                    Before condemning it might be worth removing any covers that fit over the lower section of the screen (or maybe it's metal frame - depends on panel), you might find a faulty SM capacitor or something else which is dragging the whole thing down. I had this on a large Panasonic LCD where a tiny blob of solder on a capacitor had shorted to the surrounding metal, removing this brought it back to life. I also had a Samsung with a shorted SM capacitor on one of the boards at the top that was the cause of no display but half a display if the ribbon that side was removed.
                                    • OldMan
                                      • Jun 2011
                                      • 47
                                      Thanks for the advice. I can try to swap ribbons. This was my only thought but didn't want to disassemble entire frame unless absolutely necessary. I will also check out any SM caps while I'm at it.
                                      • OldMan
                                        • Jun 2011
                                        • 47
                                        Swapped the ribbons and the issue didn't go to the new quarter of screen/board so I've confirmed ribbon is good. Looking at the boards that are tab bonded to the screen I see a lot of green corrosion on the flip up ribbon connectors. Suspecting this may be the issue. Suggestion for how to remove? I tried using eraser and alcohol with qtips without luck. Maybe WD40? If I look for blobs of solder on the SM caps, what will I look for?
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
                                        • advant
                                          by advant
                                          02-03-2020, 12:25 AM
                                        • Syseng
                                          Lenovo P14s Gen 5 SVP unlock
                                          by Syseng
                                          This sums up discussion related to Lenovo P14s Gen5 in this thread. Credits go to Sbaro and especially Maxpower3. The locked dump is attached.
                                          The device is based on NM-F871 motherboard with Nuvoton NPCK397 series controller. The motherboard also contains three BIOS chips: two different Winbond chips for main BIOS and external EC flash, and also a Gigadevice chip which purpose I do not know. The password information is contained directly in controller and thus can be manipulated by reprogramming it, so reprogramming BIOS chips is technically not required, however you may wish to make...
                                          06-22-2025, 07:44 AM
                                        • Stanley1843
                                          Screen Display Vertical Multicolor Lines
                                          by Stanley1843
                                          Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
                                          06-29-2024, 11:54 AM
                                        • Daren87
                                          Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                          by Daren87
                                          I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                          08-13-2023, 03:25 PM
