LG 42LB5600-UZ sound but no backlight
  • Ifixstuff9
    • Jul 2017
    • 120
    I have an LG 42LB5600-UZ. When I connect the TV to a video source I can hear sound and I can see an image when I do the flashlight test. If I open the TV and measure the voltage coming from the power board to the LEDs I get nothing. I'm pretty sure I have a bad power board.
    So, here are my questions:
    Is there any way I can test the back light before ordering parts?
    Is there a way I might be able to repair the board? The fact that the backlight has absolutely no power yet the rest of the TV works fine leads me to believe that it might just be one bad component that needs to be swapped out.
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: LG 42LB5600-UZ sound but no backlight
    Assume led's. Not enough pictures to see. You have no 24v
    • Ifixstuff9
      • Jul 2017
      • 120
      Whats pictures do you need? I can add more if you want.
      • dskall
        • Oct 2016
        • 2905
        • usa
        Whole back of tv. The rest of the boards. Close up of connectors
        • Ifixstuff9
          • Jul 2017
          • 120
          Here are the pictures you asked for.
          • attainteddragon
            • Apr 2013
            • 764
            • australia
            since you have a pic on screen but no backlights, you are looking at an led failure unless there is no voltage on led+, but it is an lg and will almost always be led failure in this situation.
            WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
            • Ifixstuff9
              • Jul 2017
              • 120
              I have no voltage on LED+, hence my suspicion that the power supply is bad. I did some research on this model and it seems like replacing the power supply is a common fix for this model.
                Turn TV off, set DCV meter to 600VDC range, then put DCV meter's black probe on the chassis and red probe of the meter on the LED+ pin of the LED connector, keep an eye on the meter then turn on the TV to see how high the Voltage goes up to then wait about 5 seconds to see how low it goes down to.
                https://www.badcaps.net/forum/attach...1&d=1499898761
                BTW, the solder joints for D201 (this one supplies the B+ to the Voltage boost converter for the LED power supply section), D208 do not look good, you can see small ring around the legs. I would re-solder all the transformer legs and all the legs of the devices that are mounted to the heatsink too.
                LG EAY63071904 Power Supply / LED Board.
                http://www.shopjimmy.com/lg-eay63071...led-board.htm#
                • dskall
                  • Oct 2016
                  • 2905
                  • usa
                  Need voltages from connector that goes from power supply board to main board. Will need pin#- PIN DESCRIPTION -Pin voltage in standby-Pin voltage when pushing power button and picture of connector on power supply board.
                  Format:
                  Pin# - Pin Description - Pin Voltage standby - Pin voltage power on
                  1 - XXXXXXX - XXv - XXXv
                  2 - XXXXXXX - XXXv - XXXv
                  3 - XXXXXXX - XXXv - XXXv
                  4 - etc.
                  • Ifixstuff9
                    • Jul 2017
                    • 120
                    Sorry I didn't reply until now. I just went ahead and ordered a new power supply, something came up and I don't have time to work on the TV anymore. Tomorrow I might take a look at the power supply and re-solder those connections if I have the time.
                      BTW, when you measure the LED+, what did you use for the GND reference?
                      • Ifixstuff9
                        • Jul 2017
                        • 120
                        I was using LED- as a reference. I decided to use the chassis as GND reference and I got 114 volts. So, I guess that means the back light is bad?
                          Did you do the test as instruct by watching the Voltage to see how high it goes up to before dropping down to 114VDC? That is important to find out of the Boost converter starts at all.
                          The LED Voltage should be around 200V with working LED (as printed on the board), but it will go up a lot more higher than that if the LED string has open circuit. Right now the feeding Voltage to the Boost converter looks to be 114V as you have measured.
                          • Ifixstuff9
                            • Jul 2017
                            • 120
                            I did the test. When I first power on the TV I get 248 VDC, but that voltage drops down to 104 VDC shortly after.
                              OK, that is what I want to see when the TV is first turned on which is VERY important info when troubleshooting LED backlights problem because opening up the LCD panel is the last thing you will want to do. Time to open up the panel to get to the LED strips and wiring.
                              • Ifixstuff9
                                • Jul 2017
                                • 120
                                The panel type is T420HVF07.1, and its made by AU Optronics. I found a replacement LED kit for the panel on shopjimmy.com, but its out of stock. Will any other led strips work or does it absolutely have to be one for the T420HVF07.1 panel?
                                  The strips have to match panel otherwise they may fit or work properly, IE same amount of LEDs and Voltages/Current requirement.
                                  • Ifixstuff9
                                    • Jul 2017
                                    • 120
                                    Ok, I'll just wait until I can find an exact replacement.
                                    • jbfr_54
                                      • Dec 2012
                                      • 52
                                      • France
                                      Why don't you try replacing individual LED's ? It's not so hard and a lot lot more economical (about 10 cents each LED replaced). I personnally ordered LED's 3528 rated at 400 mA form Aliexpress and repaired several Toshiba, LG and Samsung TV's using these. A lot of posts explain how to, even youtube movies describe how to proceed. The most critical is to open the screen to access the strips. You have to test each LED using a multimeter by removing a bit of white painting on the strips PCB lanes to allow electrical contact with probes (try both polarities for testing). When each defective LED is identified, do not remove the strips from the screen chassis, remove the lens using a cutter, then the with plastic cache. Use a thermal gun to gently warm the LED that should be freed and move away. Use soldering flux to ease resoldering of new LED (using a magnifying lens is a good idea). Hold the new LED in the correct position (polarity and well above solder pads), heat each pad from side of LED to make solder stick to LED pads together with the PCB pads. It is not always nécessary to add solder as the flux will ease the existing solder on the PCB to move to the LED. DO NOT HEAT TOO LONG THE LED, IF NOT OK IN FEW SECONDS WAIT A BIT AND RETRY. Mke sure that the LED is now correctly soldered and functionnal. Glue the cache back in place, the lens (using cyanolide glue on the 3 plastic pads of the PCB), make sure the lens is aligned with the LED.
                                      You better try as anyway your strip(s) is bad, it will cost you only the buying of the LED's (about 10$ for a hundred).
                                      Good luck.
                                      • Ifixstuff9
                                        • Jul 2017
                                        • 120
                                        Sounds like a good idea, I might as well give it a shot because the LEDs are so cheap.
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • Ierwin
                                          by Ierwin
                                          05-13-2025, 03:31 PM
                                        • triplefour
                                          TCL 75S421 has sound but no backlight not even a flash
                                          by triplefour
                                          TCL 75S421
                                          PSU BOARD: 40-L402H8-PWD1CG
                                          it shows not even a flash of backlight when powering up.
                                          but the tv appeas to turn on and i can hear the sound of the menus moving and clicking. i can power down the tv with the button.
                                          testing the backlights with my tester all 4 strings lit up and showed similar voltage drops. around 110 or so.
                                          unplug mb and leave only psu plugged into backlights (PSU + BL SELF TEST MODE?) does not light the backlights.
                                          i do see 24v but 0v on PSON and BLON (i didnt write this down tho so cant be sure)
                                          with mb connected, PSON...
                                          11-17-2023, 09:54 PM
                                        • slimmy182
                                          [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
                                          by slimmy182
                                          Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
                                          I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
                                          Looking on google I found this:...
                                          01-14-2023, 11:55 AM
                                        • Dani_2024
                                          by Dani_2024
                                          10-28-2024, 05:06 PM
