LG 42LB5600-UZ sound but no backlight
  • Ifixstuff9
    • Jul 2017
    • 120
    Re: LG 42LB5600-UZ sound but no backlight
    http://www.ebay.com/itm/Replacement-...-/361798126670 Do you think these will work? They are not as cheap as the ones you suggested but 12 LEDs and diffuses for $10 is still a lot cheaper than new LED strips.
    • dskall
      • Oct 2016
      • 2905
      • usa
      Those should work but you really don't need the lens just led
        Foot print information is not provided!
        • jbfr_54
          • Dec 2012
          • 52
          • France
          The Shopjimmy LEDs do not mention voltage, size and current but look correct, the vendor may give you details. Anyway, you don't need the lenses as they usually do not break when removing. Here are the LEDs I use : https://fr.aliexpress.com/item/100PC...484083505.html
          Their color temperature, light flux value, voltage and current are just perfect fit. You just need to wait a bit more for receiving them ! As a complementary information, the hot air gun I use to unsolder the LEDs is just a standard painting remover gun to which I added a home made nozzle to reduce air flow size. Not necessarily an expensive hot air soldering station. Just be carefull not to overheat the PCB.
          • Ifixstuff9
            • Jul 2017
            • 120
            Thanks for the info. I've ordered replacement LEDs, an LED rework station, and an LED backlight tester. I know it sounds a little excessive, but it will pay for itself if I can fix this tv.
            • jbfr_54
              • Dec 2012
              • 52
              • France
              #26
              Great, let us know when you'll be finished.
              For testing the LED's one by one, I use an analog multimeter with a 3V and 9V internal batteries that is able to illuminate an LED in ohmmeter X1 position. If you use a tester on an entire strip, you may see a full black strip for only one single failing LED (open circuit) while in other cases a failing LED will be acting like a resistor or a diode then you can see the ones to be changed.
              • Ifixstuff9
                • Jul 2017
                • 120
                I just installed the new LEDs and the TV works perfectly. Thanks for the help. Also, the LEDs I provided a link for above were the wrong size so I ordered the 3528's and they work great.
                • dskall
                  • Oct 2016
                  • 2905
                  • usa
                  #28
                  Thanks for the update
                  • jbfr_54
                    • Dec 2012
                    • 52
                    • France
                    #29
                    Hi Ifixstuff9, Thanks for the update, I am glad you fixed it for just a small cost compared to buying LED Strips.
                    I hope this will help convince people to try this kind of inexpensive fix as it is not much difficult to achieve.
                    • guyaca
                      • Sep 2015
                      • 7
                      • Mauritius
                      #30
                      TV LG 42 pq30r negative picture. Sound OK
                      • dskall
                        • Oct 2016
                        • 2905
                        • usa
                        #31
                        Start new post
                        • jfhojat
                          jfh
                          • Jan 2019
                          • 7
                          • ir
                          #32
                          TV LG 42LB5600 has high led voltage that reason to burn LED Stripe.
                          • Tynan Dill
                            by Tynan Dill
                            Assuming...
                            11-22-2024, 01:46 PM
                          • Ierwin
                            by Ierwin
                            05-13-2025, 03:31 PM
                          • howardc64
                            by howardc64
                            07-24-2025, 05:17 PM
                          • triplefour
                            TCL 75S421 has sound but no backlight not even a flash
                            by triplefour
                            TCL 75S421
                            PSU BOARD: 40-L402H8-PWD1CG
                            it shows not even a flash of backlight when powering up.
                            but the tv appeas to turn on and i can hear the sound of the menus moving and clicking. i can power down the tv with the button.
                            testing the backlights with my tester all 4 strings lit up and showed similar voltage drops. around 110 or so.
                            unplug mb and leave only psu plugged into backlights (PSU + BL SELF TEST MODE?) does not light the backlights.
                            i do see 24v but 0v on PSON and BLON (i didnt write this down tho so cant be sure)
                            with mb connected, PSON...
                            11-17-2023, 09:54 PM
                          • slimmy182
                            [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
                            by slimmy182
                            Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
                            I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
                            Looking on google I found this:...
                            01-14-2023, 11:55 AM
