Hi Guys,
I need your advise on how to proceed with this monitor.. Starting to lose my patience with it..
Model : HX191D
Background : Owner says the house had a power surge. I am not sure whether this caused it or the surge caused the monitor to breakdown
Fault : No Power LED.
What i did:
1) Check fuse. It is open. Change the fuse to Fuse #1. Plug it in then 'Pop'. Fuse #1 blown.
2) Check Bridge Rectifier (KBP206G). It is shorted. Found one KBP210 from old PSU/monitor. Replaced it & and the blown fuse #1 with Fuse #2. Plug it in then 'BOOM'. Thermistor (SCK103) blown. Together with Fuse #2.
3) Check Bridge Rectifier. It is no longer shorted. Replaced blown Thermistor & Fuse #2 with Fuse #3. Plug it in then 'Pop'. Fuse #3 blown again.
4) Check Bridge Rectifier. It is no longer shorted. Check Thermistor. No blown signature & resistance reads 9.1 ohms (spec is 10 ohms). Check inverter controller (LD7575PS) and there are no shorting between all the pins to Gnd (Pin 4). Replaced blown Fuse #3 with Fuse #4. Plug it in then 'Pop'. Fuse #4 blown again.
Stumped..
What else that i did/observed:
Unplugged & check the resistance of the following, with ohms set to lowest 200 :
1) D821, Q801 - not shorted on all the pins with each other
2) T801 - some pins are shorted to each other. Unsure whether it should be shorted. They are group in Red. See attached photo.
3) T901 & 902 - some pins (Pins 1-6 to be exact) are shorted to each other. Unsure whether it should be shorted. They are group in Red as well. See attached photo.
4) F802 is replaced with a jumper. But i am not sure whether this is intended to be that way.
Question/s :
Is blown fused caused by components in the Power board ONLY?! Or do i have to check the Logic card or could be caused by the panel?
Hope somebody can guide me further on my next step. Thanks as usual guys...
Edit 1 : Need to highlight that i have not recapped the board, except 1 (replaced it with a Panasonic FM). Also i did check most of the diode, that i can see all over the board, & shows no shorting on the diodes. Hope i did not missout any of them
Model : HX191D
What i did:
Stumped..
Question/s :
.. Do not want another 'fireworks' happening in the household.. lol..
