hitachi 32hxc01ua
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    hitachi 32hxc01ua
    hi just picked one of these up it uses a vestel 17ips19-5 psu ive go no standby light at all no voltages are marked on the board either any ideas guys.
    just done some voltage tests the main board is a 17mb82-2 it has one fuse on it fs2 and it does have voltage each side i have found various 12 volts 5 volts ans 3 volts on the main board but still has no standby led lit im persuming as the mainboard does have the voltages going to but no standby led the main board is more than likely the issue?
    Re: hitachi 32hxc01ua
    Can you supply a pic of the main board? This model is notorious for having a shorted/dead CPU.
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      hope this helps
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        tom im messaged a member on here who may have one also i have found the exact one on ebay all numbers match 100% even lcd number matches would you gamble its the main board the tv is only a few months old previous owner brought cash from argos lost all receipts!! looks brand new what would resale be on one of these be? once fixed as i need to weigh up the costs etc. i will probs re sell on gumtree. i have just noticed this is a led set as well.
          Yes, given your symptoms, most likely bad main board.
          Resale, in my area, £80 to £100, maybe a little more if it's got box and manual.
          • vinceroger69
            • Mar 2012
            • 6714
            • uk
            thats ggod to hear no box or manual hence the owner loosing receipt she put it in the box her other half put the box out for bin man behind her box no manual either with purchase price and the new main it will owe me £50.00 mains £30.00 alone there was one a fiver cheaper he had bad feedback and it wasnt my panel number ive got the exact one from recycling lives ebay shop so if i can get £85.00 i will be happy.
              That is a risk, 2 month old TV and main board is £50? Personally I'd not spend that much only to make £5...
              You could find panel is cracked or bad for example.
              • vinceroger69
                • Mar 2012
                • 6714
                • uk
                sorry tom worded that wrong cost £20.00 main just under £30.00 so i could make £35.00 i guess what would the going rate be in your opinion for a viewsonic n4060w 40 in lcd no freeview built in i paid £20.00 then £15.00 for caps and inc a brand new remote control has a stand too im not sure what to ask on it?
                  Viewsonic is HD Ready I'd try £120 to £140. I used to get closer to £180 but the prices have dropped for 720p TVs.
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    • uk
                    thats a good price then for the 40in lcd pity though they didnt come with freeview but at that price im sure i can find one the buyer can have im testing the tv out in my bedroom its a great picture works fine since ive done the full panasonic capacitor psu recap.
                      Ah misread thought you said it DID have Freeview... I typically knock £20 off if it doesn't have Freeview.
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        • uk
                        i will try for £100.00 then cheers also have you a scheme to check the psu voltages on this vestel 17ips19-5 psu? ive looked and cant see one.
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          • uk
                          new main board arrived noticed one thing the white connector housing socket that goes over the speaker wires pins was missing on the new mainboard anyway i thought nothing to loose so i put in the board turned set on after a retune all works well so then i slid the old white speaker housing of my faulty main board and fitted it to the new board with a bit of epoxy glue.
                          no issues so far but will leave on test for a few days but have to admit i do prefer plasma pictures. so another tv saved with a total outlay of £49.00 not the cheapest but is the newest set and is a led that ive repaired some times i guess main boards will need replacing as cant always do component repairs.
                            Oh, it's an LED TV... I have no experience with the price there but you should get more even though the picture quality is no better...
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              • uk
                              edge lit led yes the odd thing is no mains switch so if you want to turn it right of you need to unplug yes there is a standby switch on the set its soldered to the main board a little smd type switch only noticed when fitting new main it only lets you switch from standby to on and then turn to standby again these type of sets brand new in tesco yesterday £139.00 so not sure what i can ask for this? its totally unmarked with stand and remote.
                              tom just been offered a 37" LGlh3000 they say Used to take ages for the screen to become clear now it comes on slightly but has lines through it is it worth buying £25.00 no stand though could a bad t con or power issue cause this lines are top to bottom
                              • dtmf
                                • Mar 2012
                                • 2
                                • Bulgaria
                                i have found various 12 volts 5 volts ans 3 volts on the main board but still has no standby led lit ?
                                Problem is U10 and U12 Spi Flash. Must be rewriten again.
                                Read/Write as 25q16 and 25q64.
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  Vince did you ever fix this ?
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    • uk
                                    yes a new main sorted it and sold fast so all was good.
                                    • ReeceyBurger123
                                      Never Give Up !
                                      • May 2014
                                      • 7325
                                      • Britain
                                      Good stuff Was just wondering, normally on them IPS19 Psu's the diodes blow causing them symptoms.
                                      • Anor1412
                                        • Dec 2017
                                        • 22
                                        • England
                                        Hey guys on the subject of this tv I’m having trouble with mine. The backlight seems to have gone would the cause be the leds? I have done the flashlight test and you can see the menu when you shine on it. Any help would be great with this guys?
                                        • Dani_2024
                                          by Dani_2024
                                          10-28-2024, 05:06 PM
                                        • ygorsan
                                          LG 55NANO77SRA TV – Menu scrolling by itself even after removing button board (Main Board EBU66792103)
                                          by ygorsan
                                          Hi everyone,
                                          I’m looking for help with a persistent issue on an LG TV model 55NANO77SRA, which uses the main board EBU66792103 (also used in LG UQ80 and NANO75/NANO80 series).
                                          🧩 Problem Summary:
                                          • The TV keeps scrolling through the menu or selecting items by itself.
                                          • I removed the physical button board (the entire panel with power and volume buttons) and also disconnected the flat cable (CN202) from the main board.
                                          • The remote control is not in use (batteries removed), and the TV still shows the same behavior.
                                          • I
                                          Yesterday, 08:34 AM
                                        • jb_Bak
                                          by jb_Bak
                                          CN6401
                                          Pin 01 NC
                                          Pin 02 NC
                                          Pin 03 "BL_ON": 0V
                                          Pin 04 "N/C"
                                          Pin 05 "STBY 3.3V": 3.5V
                                          Pin 06 "GND": N/C
                                          Pin 07 "AC_OFF"...
                                          09-27-2021, 04:52 PM
                                        • JDC
                                          (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                                          by JDC
                                          ONN 100012588
                                          Issue: No Power, Then Rebooting After Main Board Change
                                          Short answer: replace main board and power board
                                          Technical answer: replace main board and Q306 & Q307 on power board.
                                          Long answer:
                                          TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                                          07-15-2022, 07:39 AM
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
