Samsung UN50MU6300FXZA with no power showing
  • blake.s
    • 123
    I have a samsung un50mu6300fxza with no red led status showing up. Tv does not power up, show backlights or anything.
    I ran tests on pin set CNM803. Voltages are below
    ANA_DIM 2 / FAIL_COUNT 1 - 0v
    OD_ON/OFF 4 / A13V 3 - 8.9v
    PWM_BLU 6 / A13V 5 - 8.9v
    POWER_ON 8 / A13V 7 - 8.9v
    GND 10 / A13V 9 - 8.9v
    GND 12 / GND 11 - 0v
    Edit: TV set just randomly came on with power showing it is going through. Still no backlights but the led light shows red.
    Edit 2: Now set has backlights lit but no picture coming to screen. However, tv took atleast 30 mins to come up with power going through it and when power is unplugged it repeats the same process.
  • R_J
    • Jun 2012
    • 9607
    Re: Samsung UN50MU6300FXZA with no power showing
    On these power supplies, the A13V will be around 8 volts in standby, You can check the backlight voltage (275v) across CH1 when the tv is first turned on. If the voltage is there, check the two led strings with your tester
    • blake.s
      • 123
      The power came on and when the tv finally powered on it showed the voltage when it was turned on. The backlights did come on and voltage was 275v. There is just no picture on the tv now.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8340
        if the tv does not power up, it could be the eeprom, also try disconnecting the wifi board.
        • PantherDave
          by PantherDave
          Hi all!
          05-29-2024, 02:01 PM
        • mrtek
          Samsung UN43NU6950FXZA No power
          by mrtek
          Hi
          Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
          Main fuse = OK
          Back light LED = OK. Power them with aux power source
          LED output = OK 156V
          I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
          Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
          07-20-2025, 08:06 PM
        • Cooperr
          Samsung 59" plasma PN59D550C1F seeking advice on mystery power board issue
          by Cooperr
          I picked up this TV from Facebook Marketplace, original owner described it as "screen went black after a pop" and I hoped to see an obvious fuse or cap to replace. Doesn't seem to be the case, but my experience and electrical knowledge are kind of limited for this.
          The power board (BN44-00445A, see attached) turns on and Vs and Va seem to momentarily have power, then they steadily drain to zero over a minute or two as if they're only getting power from capacitors. I've been measuring Vs and Va from the test pads, with and without the other boards connected to the power board...
          10-21-2025, 01:11 PM
          by sam_sam_sam
          03-31-2024, 02:12 PM
        • cheeky2
          Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
          by cheeky2
          This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
          I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
          Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
          06-15-2025, 05:12 AM
