Please need unlock 830 g8
Re: Please need unlock 830 g8
Become a Badcaps supporter
Thanks to all supporters.
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae.. -
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
Attached Files----------------------------------------------------------------------------------------------------------------------------------------------------------
Please help unlock bios HP 830 G8, thank you.Last edited by SMDFlea; 03-26-2023, 02:37 PM. Reason: Deleted attachment due to low server space, March 2023----------------------------------------------------------------------------------------------------------------------------------------------------------------------
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
HereAttached Files
Mọi khoản quyên góp cho badcaps đều được hoan nghênh, hãy nhấp vào liên kết này để quyên góp. Cảm ơn tất cả những người ủng hộ----------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Thank you.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
Hp 830 G8 both files are 32mb
one is front side
one is back side
would appreciate if someone can help me out because rcunlocker does not accept 32mb file
also will appreciate if someone can give me the tool or guide me how to remove as i have 3 more to doLast edited by SMDFlea; 03-26-2023, 02:38 PM. Reason: Deleted attachment due to low server space, March 2023Comment
Re: need unlock 830 g8
In the first boot, you have to go into bios setting for disable all the secutity options, avoid activate computrace or absolute features.Attached Files
Only flash EC file.
WSON8 pogo pin adapter aliexpress
https://www.aliexpress.com/item/1005002085479404.html
https://www.aliexpress.com/item/1005001633856995.htmlComment
by SysengThis sums up discussion related to Lenovo P14s Gen5 in this thread. Credits go to Sbaro and especially Maxpower3. The locked dump is attached.
The device is based on NM-F871 motherboard with Nuvoton NPCK397 series controller. The motherboard also contains three BIOS chips: two different Winbond chips for main BIOS and external EC flash, and also a Gigadevice chip which purpose I do not know. The password information is contained directly in controller and thus can be manipulated by reprogramming it, so reprogramming BIOS chips is technically not required, however you may wish to make...-
Channel: BIOS Requests ONLY!
by remizbushkaHi sirs. please help
Dell Inspiron 5775 bios locked "Unlock Setup fail"
After generating the Password Recovery code, I go to the “Security” tab - “Locked Settings” - it says “Unlock Settings? I tried many wrong passwords and it shows an error to unlock settings [ Press any key ].
What I did:
I read the bios dump.
Downloaded the bios update to 1.6.0 from the official Dell website, extracted the dump from it, updated the bios, but the problem persisted. Please help me to solve the problem....-
by Syavko1Hello, help me. I need to unlock the BIOS on my laptop. HP Spectre x360 Convertible 14-ea0520na (2Z6W0EA)
I have access to Windows. Is it possible to unlock it through Windows? Do I need to unsolder the chip? -
by zeniusHello, I have an old Dell G3 3579 (ST: 2WQ7LP2-8FC8) with a newer 8FC8 BIOS password. I have successfully attached to the flash chip (W25Q128JVSQ) on the motherboard with a CH341A programmer and made several modifications using Intel FIT (e.g., allow software SPI write) without bricking. I was also able to boot to a modified GRUB shell where I attempted to edit many BIOS security related options like BIOS Guard/Lock, Flash Signature Override, ME FW Image Re-Flash, etc.
Unfortunately, some of these modifications like to Intel BIOS Guard failed because it is fused into the PCH. Also,...-
ola boa tarde! será que conseguem ajudar! por incrível que aparente não consigo lembrar minha senha! da bios!
can help, i ty buy but in now i have without recurses in this country , are tryng unlock may admin unlock with serial ..my good, but are booting normaly in windows.
5ZQGXM3-8FC8
i forget my laptop up, is an alienware m15 r6 dell .
- Loading...
- No more items.
