Please need unlock 830 g8
  • zinnou
    • 41
    • algeria
    #201
    Originally posted by Blaze Tech
    try
    Unlock Done Thank You
    • alfredposadas09
      • Aug 2020
      • 342
      • Philippines
      #202
      Originally posted by zinnou
      hELP PASSWORD BIOS
      x360 830 G8
      SN 5CG223ORSF
      PROD ID 3S8V8AV
      dont touch the ec put it back.. flash the main bios
      first boot press f10 reset bios to factory defaults and exit.
      • javier fajardo
        • Sep 2021
        • 66
        • Colombia
        #203
        Hello, I need help to unlock an HP elitebook 830 g8, could you help me, thank you
        elitebook 830 g8
        SN: 5CG2410Z5B
        board : 6050A3426501
        • rex98
          • Feb 2023
          • 1287
          • Mandaue CEBU, Philippines
          #204
          elitebook 830 g8
          SN: 5CG2410Z5B
          first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
          use BCU. you can permanently disable Absolute lock in BCU.
          here's your DMI:
          Serial Number: 5CG2410Z5B
          Product #/SKU: 6C103EC#ABM
          CT Number: PQSNP00WBH819I
          Description: HP EliteBook 830 G8 Notebook
          BuildID: 21WWCVDZ603#SABM#DABM
          Feature Byte: 476J6S6b7B7H7M7R7W7m7saBaEapaqauawbUbhcAfPguhKhkjhk8mEmwn7nVngpDpnpqpr.Hy
          • javier fajardo
            • Sep 2021
            • 66
            • Colombia
            #205
            here's your DMI:
            thank you very much, it worked perfectly
            • zinnou
              • 41
              • algeria
              #206
              BIOS LOCKED
              HP ELITEBOOK 830 G8
              PRODID 6A3M6AV
              SN 5CG21508Y5
              • hoaca388
                Badcaps
                • Jan 2022
                • 12237
                #207
                BIOS LOCKED
                HP ELITEBOOK 830 G8
                PRODID 6A3M6AV
                SN 5CG21508Y5
                HP EliteBook 830 G8 Notebook PC
                CT Number_6LGWQ0JWYG73BC
                Serial_5CG21508Y5
                Product_6A3M6AV4
                Fearture byte_76J6S6b7B7H7M7Q7W7m7saBapaqauawb8bUcAdpdqeMfPguhKhkj4jhk8mEmVmwn7nVngpDpq.f3
                Build Id_21WWCVET601#SUUW#DABB
                • zinnou
                  • 41
                  • algeria
                  #208
                  Serial_5CG21508Y5
                  Product_6A3M6AV4
                  write done put all time show bios password
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 12237
                    #209
                    What do you mean ?
                    • zinnou
                      • 41
                      • algeria
                      #210
                      After writing the file
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12237
                        #211
                        Have you reset the settings to default ?
                        • zinnou
                          • 41
                          • algeria
                          #212
                          Power and click f10 show boot menu and restart 3 time and show password not open bios setting
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 12237
                            #213
                            Ok , You have a second chip, post it here.
                            • zinnou
                              • 41
                              • algeria
                              #214
                              second chip
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 12237
                                #215
                                second chip
                                Here
                                • zinnou
                                  • 41
                                  • algeria
                                  #216
                                  Here
                                  work fine thank you
                                  • renald21
                                    • Sep 2020
                                    • 27
                                    • Philippines
                                    #217
                                    pls unlock my hp elitebook 830 G8
                                    sn: 5CG152P2T
                                    heres the backup.*****************
                                    TNX A LOT.
                                    Last edited by SMDFlea; 09-14-2024, 05:46 AM. Reason: Attach files directly to your post in a zip or rar archive. Read the rules https://www.badcaps.net/forum/troubleshooting-hardware-devices-and-electronics-theory/troubleshooting-laptops-tablets-and-mob
                                  • Hoanr
                                    • Oct 2018
                                    • 11
                                    • Us
                                    #218
                                    hello. i need the bios password removed from this dump.
                                    this is a HP Elitebook 830 G8
                                    serial is: 5CG142C2FK
                                    board is: CORVETTE-6050A3217501-MB-A01(A1)
                                    this was dumped from next to m.2 connector,
                                    bios firmware will be attached below. thank you to whoever helps me out.
                                    • shiyab
                                      • Sep 2023
                                      • 1587
                                      • india
                                      #219
                                      post both file
                                      • rex98
                                        • Feb 2023
                                        • 1287
                                        #220
                                        here's your DMI:
                                        Serial Number: 5CG142C2FK
                                        Product #/SKU: 4L804PC#ABA
                                        CT Number: PKUHC00WBFTUAW
                                        BuildID: 21WWCVCT601#SABA#DABA
                                        Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUcAdUdpdqeMfPguhKhkjhk8mEmVmwnVng.NY
                                        MAC Address : C8:5A:CF:38:00:83​
                                        • qsenc
                                          ThinkBook 14/15 G2 ARE bios unlock
                                          by qsenc
                                          Hi guys,
                                          i have looked everywhere for a way to unlock this bios but seems only G2 ITL has a way to be unlocked ( witch i thought is the same) , but not this model. Also i have looked for a hardware way for unlock.
                                          Did anyone had success to unlock this model?
                                          Thank you
                                          ThinkBook 15 G2 ARE Laptop - Type 20VG
                                          Serial Number MP1X30S7
                                          Machine Type Model 20VG0008UK...
                                          09-17-2025, 11:59 PM
                                        • Syseng
                                          Lenovo P14s Gen 5 SVP unlock
                                          by Syseng
                                          This sums up discussion related to Lenovo P14s Gen5 in this thread. Credits go to Sbaro and especially Maxpower3. The locked dump is attached.
                                          The device is based on NM-F871 motherboard with Nuvoton NPCK397 series controller. The motherboard also contains three BIOS chips: two different Winbond chips for main BIOS and external EC flash, and also a Gigadevice chip which purpose I do not know. The password information is contained directly in controller and thus can be manipulated by reprogramming it, so reprogramming BIOS chips is technically not required, however you may wish to make...
                                          06-22-2025, 07:44 AM
                                        • remizbushka
                                          Dell inspirion 5775 bios "Unlock Setup fail"
                                          by remizbushka
                                          Hi sirs. please help
                                          Dell Inspiron 5775 bios locked "Unlock Setup fail"
                                          After generating the Password Recovery code, I go to the “Security” tab - “Locked Settings” - it says “Unlock Settings? I tried many wrong passwords and it shows an error to unlock settings [ Press any key ].
                                          What I did:
                                          I read the bios dump.
                                          Downloaded the bios update to 1.6.0 from the official Dell website, extracted the dump from it, updated the bios, but the problem persisted. Please help me to solve the problem....
                                          03-24-2025, 09:07 AM
                                        • salim5566
                                          loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                          by salim5566
                                          Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                          06-26-2025, 03:25 PM
                                        • Syavko1
                                          Unlock Bios HP Spectre x360 Convertible 14-ea0520na (2Z6W0EA)
                                          by Syavko1
                                          Hello, help me. I need to unlock the BIOS on my laptop. HP Spectre x360 Convertible 14-ea0520na (2Z6W0EA)
                                          I have access to Windows. Is it possible to unlock it through Windows? Do I need to unsolder the chip? ​
                                          01-22-2025, 02:04 PM
