Please need unlock 830 g8
Mọi khoản quyên góp cho badcaps đều được hoan nghênh, hãy nhấp vào liên kết này để quyên góp. Cảm ơn tất cả những người ủng hộ---------------------------------------------------------------------------------------------------------------------------------------------------------------- -
Re: Please need unlock 830 g8
Hello hoaca388
The dmi info is there but now the wifi is not working.
Let me know
Best regards ChrisComment
Hello hoaca388
Do you have a solution
please let me know
Best regards chrisComment
https://www.badcaps.net/forum/showth...light=NbDmiFitAttached Files
Mọi khoản quyên góp cho badcaps đều được hoan nghênh, hãy nhấp vào liên kết này để quyên góp. Cảm ơn tất cả những người ủng hộ----------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Hello hoaca388
The file is mpm lockt so there is no option in the bios to set the
info
Can you put that file in mpm unlock mode
Best regards chris
ps thanks for al the timeComment
need unlock hp 840 g8 6050a3217501-mb-a01
here are the main dump and ec
https://www.badcaps.net/forum/troubl...sting?t=103570
You MUST:- Read BIOS guides, methods, resources and tools
- Try the method at BIOS guides, methods, resources and tools before requesting help
- Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://badcaps.net/forum/showthread.php?t=88758 )
please need help unlock hp 840 g8 6050a3217501-mb-a01
here are the main dump and ecComment
hello sir i write ur bios everything perfect just wifi not dectect please sir can u fixAttached FilesComment
Hi, please can you help to unlock? it is a Hp x360 830 G8. Dump U367 S/N: 5CG22559NC
Thanks.Attached FilesComment
hp elitebook 830 G8 bios password pleas
sn: 5CG134C742Attached FilesComment
by SysengThis sums up discussion related to Lenovo P14s Gen5 in this thread. Credits go to Sbaro and especially Maxpower3. The locked dump is attached.
The device is based on NM-F871 motherboard with Nuvoton NPCK397 series controller. The motherboard also contains three BIOS chips: two different Winbond chips for main BIOS and external EC flash, and also a Gigadevice chip which purpose I do not know. The password information is contained directly in controller and thus can be manipulated by reprogramming it, so reprogramming BIOS chips is technically not required, however you may wish to make...-
Channel: BIOS Requests ONLY!
by remizbushkaHi sirs. please help
Dell Inspiron 5775 bios locked "Unlock Setup fail"
After generating the Password Recovery code, I go to the “Security” tab - “Locked Settings” - it says “Unlock Settings? I tried many wrong passwords and it shows an error to unlock settings [ Press any key ].
What I did:
I read the bios dump.
Downloaded the bios update to 1.6.0 from the official Dell website, extracted the dump from it, updated the bios, but the problem persisted. Please help me to solve the problem....-
by Syavko1Hello, help me. I need to unlock the BIOS on my laptop. HP Spectre x360 Convertible 14-ea0520na (2Z6W0EA)
I have access to Windows. Is it possible to unlock it through Windows? Do I need to unsolder the chip? -
ola boa tarde! será que conseguem ajudar! por incrível que aparente não consigo lembrar minha senha! da bios!
can help, i ty buy but in now i have without recurses in this country , are tryng unlock may admin unlock with serial ..my good, but are booting normaly in windows.
5ZQGXM3-8FC8
i forget my laptop up, is an alienware m15 r6 dell .
- Loading...
