Old Dell 15" - 1 second lights up, then goes black
    Re: Old Dell 15" - 1 second lights up, then goes black
    The original CCFL is about 310 mm long. I checked a spec sheet, and the rated brightness is 46,000 Cd/m^2
    PlainBill
    I was going to use 1206 SMD LEDs rated at 260mcd each. The tube is about 2mm dia and 310mm long = that means 2 * pi * r * h = 0.004m^2 = 223 cd for the tube. That means I'll need 1,000 LEDs+, which seems like way too much given that I've seen Edge LED screens with far less.
      Well the good news is, the LED strip I bought for £5 is really bright, and it looks like I can meet the original brightness of the CCFL. I burnt out some LEDs rather stupidly on one strip but it doesn't seem to have significantly affected it.
      I'll need to drop 18V down to 12V at about 250mA, this means according to V=IR, I need a 24 ohm resistor, so I'll order a 27 ohm 3W resistor (the resistor will dissipate 1.7W, so I will attach it to the metal casing to help dissipate some of the heat.) I'll probably wire in a MOSFET to control the brightness too.
      I need to figure out how to get the monitor to turn on without the inverter; it might be waiting for an "Inverter is okay" signal.
      Now I know why to be annoyed when manufacturers want an extra £100 for an LED vs CCFL TV .
      It's also interesting that this LED array only consumes around 4-5W but has almost the same brightness as 10-20W CCFLs. More efficient technology I guess.
      • PlainBill
        • Feb 2009
        • 7034
        Good job so far, now for a couple of points.
        The signal card is not looking for an 'Inverter OK' signal.
        The LEDs will always be on unless you use the 'inverter on' signal to control them.
        There is a 4 pin version of the 78XX series of voltage regulators. One example is the Fairchild KA278RA05CTU. The additional pin is an enable / disable control. You can use that to drop the voltage and turn the LEDs on and off. A REALLY clever guy could even figure out how to use the brightness control to adjust the brightness (don't look at me).
        PlainBill
          PlainBill
          I wouldn't use a 78 series regulator because it's far cheaper to use a power resistor. Also, a 78XX wouldn't drop current, so thermal runaway is a real possibility - not pretty! If I were hyped up about efficiency, I'd use one of my buck converter LED drivers I designed, but I don't have the time at present.
          For on/off, I figure I will just wire in the gate of the FET to the 18V_ON on the control panel. This comes out of the switch only when the monitor is on and could probably drive the FET into conduction.
          Problem is, at the moment, the display is still white - no video signal is being sent to it. I cannot get the signal board to power up. I tried shorting various connections on the inverter board to turn it on with no luck.
          How would the signal board know to shut down with a bad inverter/CCFLs, as was the case before?
            Good news is it is now working
            Turns out it was a loose LVDS cable; it now works perfectly.
            Interesting failure mode when powering the LEDs externally and the LCD is powered down. Very weird.
            See video.
            http://www.youtube.com/watch?v=ETL8q5nq1ro
            I'm ordering the resistors and MOSFETs later, will see how it works when finished.
              Okay! The conversion is complete!
              Assembly is all that remains... How many screws will be missing!? I tried to keep them in one place...
              The circuit for the MOSFET on/off is really simple, and is attached.
              I used an IRF510 because I had it on hand, if I were properly designing this I would order the right MOSFET. But the current is low enough that the MOSFET does not heat much.
              I used a MOSFET because I'm not entirely sure that switch would be happy passing 280mA as at present, it just controls a MOSFET on the main board.
              See the video on YouTube: http://www.youtube.com/watch?v=vevU_Fm6ap0
              • sofTest
                • Aug 2008
                • 361
                #27
                What LED strip did you use? I'm looking into doing a LED conversion on a 19", but is a bit unsure on which strips gives enough light. I've found 2-3 candidates, but it's nice to know what's been successful.
                Thanks.
                Be a mensch
                  Thanks.
                  I used these:
                  http://www.giantcod.co.uk/high-densi...-p-404319.html
                  Perhaps if I were to do it again I would spend a bit more and get these as the display would look at bit brighter. It was originally fairly dim anyway.
                  http://www.giantcod.co.uk/ultra-brig...-p-406179.html
                  They are for model aircraft and I used the left over ones from the metre strip (about 30 cm) for my flying wing.
                  • x_orange90_x
                    Vizio E55-E1 bad backlights or bad inverter?
                    by x_orange90_x
                    I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
                    I don't know how exactly to test the inverter itself. Is it...
                    01-29-2025, 09:24 PM
                  • Gentian
                    APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                    by Gentian
                    I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                    It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                    03-06-2023, 07:07 AM
                  • valvashon
                    Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                    by valvashon
                    For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                    History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                    01-04-2024, 01:44 PM
                  • eccerr0r
                    A modified sine wave inverter + a grid tie inverter?
                    by eccerr0r
                    If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
                    Next thing is trying to charge the batteries using solar power, but that's another issue ...
                    08-31-2023, 09:14 PM
                  • Francesc V.
                    Christmas lights - Something I am doing wrong
                    by Francesc V.
                    Hi:
                    i am trying to repair this Christmas lights from my parents. They are incandescent lights, no led lights.
                    I have tried with 12V a 24V small lights that I found in Aliexpress but is obvious that are not the right ones. They last microseconds connected. Do they blow because of Amps or Volts?
                    If I measure the Amps in the string........it's only 90mA. If I measure the Volts in the "green box"......it's between 0 and 190V, but doing a little bit of maths from the number of bulbs in series.......it's only about 6V per lamp.
                    Could...
                    03-11-2023, 07:38 AM
