CyberPower 1500AVR Not Charging
  • Weatherson
    • Jun 2020
    • 8
    Hi all. I have a CyberPower 1500AVR that has stopped charging its batteries. I replaced the batteries thinking this was the issue as the originals were several years old but the new batteries are the same. With the unit on and the batteries connected, I read 20.5 volts at the battery connectors. Not sure if that is helpful or not. I assume this is just what's left in the batteries after having the unit powered on for a day or so. There are no signs of damage on the board aside from some slight heat blackening of red and black wires just above the viper22a ic. The two caps in the photo, circled in red, both have a brown solution on their exterior which I assume is glue and not leaked from within.
    I've read other threads where some caps and the viper22a ic were replaced as a fix. Any help would be greatly appreciated and let me know what I can provide in assistance. Thanks and regards.
  • Weatherson
    • Jun 2020
    • 8
    Re: CyberPower 1500AVR Not Charging
    Anyone? Even just a schematic of this model would be helpful. Thanks.
    • R_J
      • Jun 2012
      • 9638
      I see some darkening of the circuit board around JP6, or is that just the way the picture was taken? I would check that area for poor solder connections, If there is heat in that area I would try replacing the two smaller electrolytics in that area, those small elec. caps. dry out but look ok as they don't leak or bulge.
        • Jul 2011
        • 6070
        I would recommend replacing the viper 22 and the small UF value capacitors as well at a minimum if you want to do some good measure replace all the capacitors
        • Weatherson
          • Jun 2020
          • 8
          The only board darkening is at the viper22. Anything else is just camera phone variations. Thank you though.
          Can I assume that the caps in the vicinity of the viper22 are dedicated to the charging function? Or when you suggest replacing the small uf caps, you mean throughout the board? I think I would prefer to start with minimal replacement and work up from there if need be. Thanks for the input.
            • Jul 2011
            • 6070
            Yes replace the capacitors next to the viper 22 ic chip at a minimum to see if you can get it to work correctly or not also replace the capacitors next to optic sensor as well
            • R_J
              • Jun 2012
              • 9638
              I suspect the viper 22 is used to supply a standby voltage only not for charging etc.
              I recommended replacing the small caps if the area was over heated, since it was just a shadow in the image they may be ok, but you never know as small caps like that usually don't have any bulging or leakage, they just dry up overtime.
              • Weatherson
                • Jun 2020
                • 8
                Sorry for my lack of knowledge but which is the optic sensor on the board?
                  • Jul 2011
                  • 6070
                  An optic sensor is a ic chip that has 2 pins on one end another 2 pins on the other end of it
                  I can not see it in the pictures that you have provided
                  • Weatherson
                    • Jun 2020
                    • 8
                    So that would be U2 in this image?
                      • Jul 2011
                      • 6070
                      Look up the part number and you will then know what type of device this is but I would recommend changing the capacitor right next to it
                      Here is the data sheet for this device
                      What is the part number for U1 next to the optic sensor
                      • Weatherson
                        • Jun 2020
                        • 8
                        As far as I can tell as it's difficult to read but U1 is..
                        UTC
                        TL431K
                        WMH
                          • Jul 2011
                          • 6070
                          This is the voltage reference ic chip if you have old switching power supply board you could find one that works correctly and replace it and see if fix’s your problem or just replace the viper 22 ic chip the optic sensor ic chip and the voltage reference ic chip and the two capacitor and see if you get the switching power supply board to start working correctly again
                          Now for the optic sensor you can check to see if you have any voltage on LED side of the sensor which is around 2 to 3 volts the voltage reference ic chip depending on on ic chip could be any where from 1.5 to 2.5 volts you would have to look at the data sheet for this information
                          • Weatherson
                            • Jun 2020
                            • 8
                            Just a quick update.. I finally got all the parts needed and replaced the COSMO device, the Viper22a device and all the caps in the general area of the Viper22a. The unit now works properly and charges the batteries as it should. Thanks to everyone who helped me get through this!
                              • Jul 2011
                              • 6070
                              One more item that did not end up in the landfill
                              Good work
                              • bmasephol
                                • Jan 2025
                                • 2
                                Posting to say thank you for the information in this thread.
                                I have a GS-1500U, which is essentially a rebadged CyberPower 1500AVR that was sold by BestBuy under the Geek Squad brand quite a few years ago. I've gone through at least 2 sets of batteries in it over the years and most recently it wouldn't charge the batteries anymore. I charged the batteries with my Noco Genius 10 and put them back in but within a few days the batteries were dead and the unit would loose power at times (completely powered off). I tried fresh batteries and had the same experience.
                                I came across the thread researching via google. I ordered up the chips/caps mentioned above (COSMO/Viper and caps) and replaced them. As best as I can tell I'm back in business.
                                I will give it a few days of testing to ensure its working but I'm grateful for this forum and thread!
                                • carrzkiss
                                  Cyberpower cps1500avr not charging batteries
                                  by carrzkiss
                                  Hello, all.
                                  Cyberpower Battery Backup Unit.
                                  I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
                                  When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
                                  In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
                                  Checking the voltage, it was down to 22v.
                                  I quickly removed everything...
                                  06-15-2024, 02:10 PM
                                • quickname
                                  Cyberpower 1500AVR UPS repair
                                  by quickname
                                  I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
                                  Like clockwork, I've had to replace the SLA batteries every 4 years. It was about that time and the UPS was acting like it needed new batteries... randomly shutting off with AC present, not being able to charge fully, and poor runtime when AC was removed. So, I replaced the batteries but noticed that it was not charging properly.
                                  I decided to verify that the batteries were...
                                  11-12-2023, 09:57 AM
                                • orientalsniper
                                  LA-L246P Not Charging Batteries
                                  by orientalsniper
                                  Hello all, I've tried multiple batteries, replaced the charging IC (ISL95522AHRZ) and updated the BIOS.
                                  It detects the power adapter (90W), so the DC IN jack is okay.
                                  It shows "IDLE" instead of "Charging", battery health shows "Excellent" on the BIOS.
                                  09-15-2025, 02:29 PM
                                • coasterghost
                                  Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                                  by coasterghost
                                  For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                                  Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                                  Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                                  System Hardware:
                                  Processor: AMD Ryzen 7 PRO 5850U
                                  Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                                  09-08-2025, 10:46 PM
                                • Thomasraud
                                  Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
                                  by Thomasraud
                                  i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
                                  QUOTED
                                  -It works on charger (without battery connected-only charger)
                                  -It works on battery (without charger connected-only battery)
                                  -& it also works when plugged in battery & charger, but it's not charging the battery
                                  //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
                                  and..
                                  QUOTE
                                  The IC cannot maintain the input current level
                                  06-28-2022, 06:47 PM
