50" Panasonic Plasma dead.
  • titodj
    • May 2012
    • 39
    I got a 50" Panasonic Plasma model th-50px75u that wont power up.
    When I plug it, I can hear a click.
    But after that if I press the power button, I just get a static red led, no blinking or nothing.
    Any way, I got a troubleshooting diagram from scribd, and followed the steps for No power/ Dead Unit.
    In pin 20 of D5 I got 3.0v
    and in pin 11 of P25 I got 3.2v
    So according to that diagram there is something wrong with the power supply. (power supply ETXMM655MEH )
    I did a visual inspection, and I cant see anything obvious, and measured continuity in all the fuses I saw.
    But thats about it, I dont know what else to look for.
    Im attaching some pictures of the power supply.
    Thank you in advance for your help, and kind attention.
  • titodj
    • May 2012
    • 39
    Re: 50" Panasonic Plasma dead.
    Quick update.
    Looking in youtube how to check diodes, I found that two of them apear to be opened, im posting the pictures to see if this can help.
    Thanks again.
    • retiredcaps
      • Apr 2010
      • 9271
      1) Are you using the diode test function on your multimter?
      2) If yes, post the actual readings. You should have 2 readings per diode.
      --- begin sig file ---
      --- end sig file ---
      • titodj
        • May 2012
        • 39
        Yes I'm using my multimeter.
        The first one (the one next to what looks like a coil)
        .168 and .520
        The second one (next to the yellow thing)
        .001 (after a while of jumping all over it settel's there)
        .003
        Thanks.
          Second one seems bad.
          • retiredcaps
            • Apr 2010
            • 9271
            .003
            The second is shorted (not open). Remove it and retest out of circuit.
            • titodj
              • May 2012
              • 39
              Thank you, I finally got to take the power supply off, and remove the diode.
              off circuit reads "OL" on both directions.
              So I assume the diode is bad.
              Now, I have a few questions, should I look for something else in the power supply?
              Is that diode alone likely the cause of the failure?
              The diode is the Panasonic ST3D82 Diode Surge Protector
              Should I just replace the diode and test? or test something else and then replace??
              Also the first diode that I mentioned in this thread, its fine even tough it gives readings in both directions?
              .168 and .520
              Thanks again, for your help.
                That diode is probably good (it is a TVS, so will not conduct normally); is it still reading a short between the terminals on the PCB, where you removed the diode?
                • titodj
                  • May 2012
                  • 39
                  If i use the continuity test between the two empty terminals where the diode was, I get a beep
                  If I use the diode mode I get 0.00 so I guess "yes"?
                  I get a shorts between the terminals.
                    OK, so there is still a short. Which area are you testing? (I'm not sure which one it is the picture.)
                    • titodj
                      • May 2012
                      • 39
                      I took out the diode next to what it looks like a yellow transformer.
                      And I'm getting a "beep" between the terminals where the diode was.
                      Thanks.
                        That MAY be normal, as the diode is simply there to protect the transformer which will read as short. I think you need to look elsewhere.
                        • titodj
                          • May 2012
                          • 39
                          Thanks, I wil replace the diode, and see if that helps.
                          • cuestaj1707
                            • Sep 2012
                            • 24
                            • usa
                            Hi dear titodj,I'm working in the same power supply and i tried some thigs but still no find the solution,replaising this diode fix your problem?,because i have the same in mine,thanks.
                            • cadiman
                              • Mar 2010
                              • 397
                              I have replaced large caps on some of the other types of plasma power supplies.
                              I would check or replace the large caps in the secondary part of the supply.
                              • cuestaj1707
                                • Sep 2012
                                • 24
                                • usa
                                I have two sets of large caps one whit 3 caps 900 uf 220 v and others 3 220uf 450 v this last one is the one close to the 110 v main entry which one is the one that you guess is give me a problem,thanks
                                • titodj
                                  • May 2012
                                  • 39
                                  Just to update this thread.
                                  After replacing the three big capacitors (450 v 220uf) I was able to hear the relays click, but still no go...
                                  So following the flow charts in this excellent troubleshooting manual, I was able to pinpoint the problem in the GS board, so decided to take out the GS board...
                                  And... BINGO !!!
                                  I found a 5cts coin stuck in the SD card slot !!!
                                  A pair of needle nose pliers and one minute later, the problem was resolved !!
                                    LOL! Awesome! Interesting that a coin would cause that, but I guess it acts as a nice shorting block!
                                    Oh, and you're 5 cents richer
                                    • spidey12345
                                      • Sep 2013
                                      • 3
                                      I have the same issue. My son stuck a washer stuck in the SD card slot, as it looked like the slit on his penny bank. I pulled it out, but now the TV is stuck on channel 3, and it wont change channels or adjust the volume, it pretty much turns on and off to channel 3 and I cant change to HDMI nor any other input.
                                      Any ideas how to address the issue. I've been reading that there is a way to disconnect the SD reader permanently....its a 6 year old 50 inch Panasonic Plasma...
                                      thaks
                                        I would check the button board connectors are seated correctly and no buttons are stuck.
                                        • jm1234
                                          Panasonic plasma TX-P42ST50 - 6 blinks
                                          by jm1234
                                          anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                          It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                          I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                          I checked that board for any obvious faults...
                                          05-22-2024, 06:59 AM
                                        • cloo
                                          Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                                          by cloo
                                          I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                                          It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                                          So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                                          After doing a factory reset this problem was gone and the picture was back to...
                                          01-06-2025, 06:02 AM
                                        • Alicat
                                          Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                                          by Alicat
                                          Stopped by this site trying to fix my parents Panasonic Plasma TV.
                                          Model number is TH-50PZ85U
                                          Power comes on and the red power light stays on solid.
                                          Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                                          I also hear a few clicks.
                                          I also think my parents said there was a thunderstorm and the TV failed after that.
                                          Section 6 in the service manual talks about power and no screen,...
                                          10-30-2024, 10:09 AM
                                        • Lintesir
                                          Panasonic P42S30 Plasma - Pink sparkles
                                          by Lintesir
                                          My parents' Panasonic P42S30 died recently, and they asked me to have a look at it. I was able to identify the SN-board as the culprit, as it was shorted. After removing Q401, Q402, Q421 and Q422 the short was gone, so I replaced these components and that got the TV working again. However, when testing the tv a bit, I noticed quite bad pinkish sparkles on some colors. For instance the greyish bar on this forum seems to trigger it quite badly. I made a fullscreen test picture with only that color, with the below result.
                                          There is about a 5cm high region at the top without any sparkles,...
                                          07-26-2024, 03:16 AM
                                        • tofik
                                          PANASONIC TX-P42X10Y Plasma TV damaged after a power spike
                                          by tofik
                                          Hello, I have an PANASONIC TX-P42X10Y Plasma TV, purchased new in 2009.
                                          Unfortunately plasma is not working at all after a power spike. Standby LED is not even working.
                                          I did some quick tests, YSUS + ZSUS MOSFETS and IGBT's are free from shorts, diodes on these modules seems to also be fine, buffer board is free from shorts as well.
                                          Anyway I focused mainly on the PSU, did some voltage tests with the results as below, I attached them on the photo (also please see attached PDF with the SERVICE MANUAL for this model, page number 43).
                                          I understand...
                                          02-17-2023, 02:34 PM
