Short on ASUS Laptop
  • m4a2t0t
    • Mar 2013
    • 279
    Plugged in charger and sparks were coming from jack. Removed board and saw some burn marks on the 8-pin chip ( 4835GM P-CHANNEL ENHANCEMENT MODE POWER MOSFET ) and the center is missing from what looks like a diode.
    Plugged in charger with board removed and this chip let out its supply of magic smoke. MB39A132 DC|DC Charger for Li-ion battery https://cdn.badcaps-static.com/pdfs/...5951e1e5c3.pdf
    Pin 1 to ground shows continuity - 15ohm.
    If I check from the DC Jack inputs (power) to ground I have continuity.
    Should I remove that Charging chip and check if there still is a short? How can I find out what that other chip is with center missing? Without buying another mobo? Can I check that MOSFET while it is attached to the board?
    ASUS PN# 60-NVKMB1000-C03
  • dj_ricoh
    • 2073
    • uk
    Re: Short on ASUS Laptop
    Hello!
    you need to remove that management chip and see if the short its there if not , replace.
    remove that p-chan. mosfet and see if its ok.( ) D to S
    p.s. for that diod remove it to and see if its ok. use the MM on the diod mode
    • m4a2t0t
      • Mar 2013
      • 279
      Removed the charging chip and no more short from DC input pins to ground.
      Diode show open both directions.
      How do I test the mosfet? Diode test both directions 0v. Resistance shows 0 ohm I checked all D>S.
      • fddizon
        • Sep 2011
        • 555
        • Philippines
        test it the way like a diode pin123 to pin 5678. one way reading only
        if reading is both direction, remove mosfet from board and re test.
        • m4a2t0t
          • Mar 2013
          • 279
          diode test shows 0v both directions. mosfet has been removed from board.
          • trebo
            • 514
            • Wales, UK
            How does it test, now its off the board???
            • m4a2t0t
              • Mar 2013
              • 279
              I only tested it after it was removed
              • m4a2t0t
                • Mar 2013
                • 279
                Is this a suitable replacement for the MOSFET? http://www.newark.com/international-...red%20Products
                I don't know what to use for the diode and am having trouble finding anything close to that DC-DC convertor IC.
                • fddizon
                  • Sep 2011
                  • 555
                  • Philippines
                  replace all 3. diode mosfet and ic
                  • m4a2t0t
                    • Mar 2013
                    • 279
                    but what kind of diode? Should I just get another dead mobo?
                    • spleenharvester
                      • Mar 2010
                      • 921
                      This is the motherboard schematic mate: http://www.mediafire.com/?csrv45qanno670c
                      Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
                      • fddizon
                        • Sep 2011
                        • 555
                        • Philippines
                        try getting from old motherboard. getting one from power section too just like where the broken diode was used.
                        also check mosfets near charging ic.
                        • m4a2t0t
                          • Mar 2013
                          • 279
                          all the boards I am finding are no power boards lol.
                          • fddizon
                            • Sep 2011
                            • 555
                            • Philippines
                            see the schematic and get the part number, buy it from ebay or ask someone from here if there is available on hand.
                            • billpool
                              • Sep 2013
                              • 8
                              Asus Republic of Gamers Laptop having same issue - smoke coming out when I plug in the power supply - comes out immediately. If anyone has specific info I would greatly appreciate it. I have seen this issue is extremely common by doing google searches but I would like specific circuit board info if possible as it is bound to be a common failure point. Thanks!
                              • billpool
                                • Sep 2013
                                • 8
                                finished taking apart laptop to get at MB, photo below shows that one of the pins on the power supply connector is burnt. Help? I assume it's not just re-soldering it?
                                Thanks, please help me to know next steps. I have it torn apart, not sure what to test besides seeing now where it's fried.
                                -Bill
                                • fddizon
                                  • Sep 2011
                                  • 555
                                  • Philippines
                                  bill, you need to create a new thread for that.
                                  but anyways... you need to remove dc jack from mobo using proper tools
                                  after removing, check the pad pin with black against ground if there is short...
                                  if none, clean the pad thoroughly, apply a little bit of solder to the pads, then return the dc jack if still good.
                                  then solder it nicely.
                                  hope this helps
                                  • billpool
                                    • Sep 2013
                                    • 8
                                    creating a new thread for this
                                    • hephaistos
                                      • Sep 2013
                                      • 5
                                      • Romania
                                      Hi, i`m having the same problem as m4a2t0t and i would like to know if replacing those 3 parts resolved the problem or if it were other parts burnt also.
                                      I replaced the diode and mosfet then i saw that the ic MB39A132 had a "blown like" dot exactly at pin 1.
                                      As i said i would like to know if it resolved the problem those 3 parts because if it didn`t i will throw away the laptop because it doesn`t worth it.
                                      Thank you!
                                      • fddizon
                                        • Sep 2011
                                        • 555
                                        • Philippines
                                        try replacing the md chip.
                                        • acedogblast
                                          by acedogblast
                                          11-02-2024, 05:13 PM
                                        • DynaxSC
                                          ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                                          by DynaxSC
                                          Hi
                                          I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                                          08-04-2025, 12:20 PM
                                        • ebugs
                                          Asus laptop EC/SIO chip replacement
                                          by ebugs
                                          Asus Vivobook 15 (board X513ea R2.0) gone dead when user plugged an iPhone cable into the USB-C port during boot. Now there's no LED light, no power at all. I checked all MOSFETs and capacitors, no shorts found. The board only has 3.3V and 5V present, no other voltages.
                                          I injected 3.3V into the EC chip power rail (ITE IT5125VG 128), and it draws 80mA, while the 3.3V LDO chip RT8249C has a max output of 100mA. I checked the boardview and found there are only two chips on this 3.3V rail, EC and Realtek audio chip. So I think EC could be the problem.
                                          I found the EC chip...
                                          09-14-2024, 02:09 AM
                                        • dqtech
                                          Asus X455L Short Mosfet
                                          by dqtech
                                          I got this laptop from friend with problem short 19v....when i check this 2 mosfet getting short...i remove that mosfet and confirm that mosfet is short...
                                          and check that 2 capacitor PC9009 and PC9004 pad is also short...already check where that capacitor goes and came from but cannot find the main problem...please help
                                          08-09-2022, 08:53 PM
                                        • flat-earther
                                          ASUS X54H laptop thinks it's always charging even with charger unplugged
                                          by flat-earther
                                          The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                                          Windows also shows ''Plugged in'' when charger is not connected.
                                          This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                                          Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                                          If I let battery run out and say it has 3% Windows will...
                                          06-24-2025, 09:32 AM
