Short on ASUS Laptop
  • hephaistos
    • Sep 2013
    • 5
    Re: Short on ASUS Laptop
    Originally posted by fddizon
    try replacing the md chip.
    Excuse me but i don`t understand what md chip is.... are you refering at that MB39A132?
    One other thing: if the chip`s only task is to take care about the battery i think the laptop should have started and not charge the battery but mine doesn`t start at all. Does this chip do other things too?
    Thanks!
    • fpaliuc
      • Nov 2013
      • 7
      • Italia
      I have the same problem due to inverted polarity on the power adapter. The MB39A132 IC has the burned sign. Also, I've checked the 4835GM SOP8 IC Chip (the upper right one) and all the S-D pairs are shorted. The diode is OK.
      When I connect the power adaptor, there are sparks comming from the connector and the PC doesn't start. Would I solve the issue only by removing the bad MB39A132 IC and only soldering a new 4835 IC? (I don't care about the battery not charging. I only need the PC to work while powered from the AC source).
      • londoner
        • Jan 2014
        Hope this thread is still being followed!
        My daughter's laptop won't charge using the external PSU, so I took the mobo out and can see a part that is burned out, but I can't locate it on what I think is the circuit diagram (got from the post above - thanks!)
        I've joined the two together below.
        Assuming this is the correct section of the schematic (my mobo is rev 2.1 but looks identical) - the underside of the board gives no clue as to how the components are connected together.
        Anyone know what the burnt-out component was?
        • khaahk
          • Dec 2013
          • 812
          • Estonia
          It is D6801 protection diode against reverse polarity. You can remove it and test run without it to see if anything else has burnt.
          • londoner
            • Jan 2014
            Thanks!
            Didnt get a "thread changed" email or would have replied sooner.
            Cannot find the part by googling - is it in this class:
            http://cpc.farnell.com/transient-voltage-suppressors
            If so, will this one do it?
            http://cpc.farnell.com/fairchild-sem...smc/dp/SC07237
            Also, can I just plug the bare mobo into the DC power by attaching the plug? I had to remove the CPU heatsink to get it out to trace the fault. I presume if you power a "bare" mobo like this, thermal protection will prevent CPU damage?
            Thanks again - really appreciate it.
            Chris
            • khaahk
              • Dec 2013
              • 812
              • Estonia
              #26
              You can remove the diode and test the mainboard even without CPU, it should still charge or show charging light. There is a good possibility that something else has gone bad also. Then it would be a waste of time and money to replace the diode.
              If test run is ok then look here:
              Ebay - in UK:
              http://www.ebay.com/itm/SS0540-SMT-M...item5aea91b1e0
              The SC07237 should be ok also but might be bit big to physically fit.
              • vienzen
                • Feb 2015
                • 112
                • PHILIPPINES
                #27
                Hello there did you solve your problem?
                • acedogblast
                  by acedogblast
                  11-02-2024, 05:13 PM
                • DynaxSC
                  ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                  by DynaxSC
                  Hi
                  I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                  08-04-2025, 12:20 PM
                • ebugs
                  Asus laptop EC/SIO chip replacement
                  by ebugs
                  Asus Vivobook 15 (board X513ea R2.0) gone dead when user plugged an iPhone cable into the USB-C port during boot. Now there's no LED light, no power at all. I checked all MOSFETs and capacitors, no shorts found. The board only has 3.3V and 5V present, no other voltages.
                  I injected 3.3V into the EC chip power rail (ITE IT5125VG 128), and it draws 80mA, while the 3.3V LDO chip RT8249C has a max output of 100mA. I checked the boardview and found there are only two chips on this 3.3V rail, EC and Realtek audio chip. So I think EC could be the problem.
                  I found the EC chip...
                  09-14-2024, 02:09 AM
                • dqtech
                  Asus X455L Short Mosfet
                  by dqtech
                  I got this laptop from friend with problem short 19v....when i check this 2 mosfet getting short...i remove that mosfet and confirm that mosfet is short...
                  and check that 2 capacitor PC9009 and PC9004 pad is also short...already check where that capacitor goes and came from but cannot find the main problem...please help
                  08-09-2022, 08:53 PM
                • flat-earther
                  ASUS X54H laptop thinks it's always charging even with charger unplugged
                  by flat-earther
                  The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                  Windows also shows ''Plugged in'' when charger is not connected.
                  This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                  Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                  If I let battery run out and say it has 3% Windows will...
                  06-24-2025, 09:32 AM
