Samsung UN75F6300AF Won't Power Up
  • toddw65
    • Jan 2014
    • 108
    I picked up this monstrous Samsung unit today where the owner said the house had been hit by lightning. I can't see anything obviously burnt or blown.
    On CNM803 I get 5.34V on pin 18 and .25V on pin 20. Nothing on any other pins.
    Also, when I disconnect the harness between the main board and the power board, the LEDs all light up and the screen is nice shade of blue.
    Thoughts?
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Re: Samsung UN75F6300AF Won't Power Up
    Mainboard is bad.
      So the backlights come on and stay on when the power supply board is not connected to the main board, that means the power supply board and the LED backligts are OK but the main board is the problem.
      More like the surge came through the HDMI ports or cable port.
      • toddw65
        • Jan 2014
        • 108
        Ok. Thank you both.
        • tvtimmy
          • Mar 2015
          • 1160
          • usa
          Check ebay quick. Only a few to buy and only 1 cheap one. 1 is going for $200+.
          • toddw65
            • Jan 2014
            • 108
            Snagged this one. Fingers crossed.
            • toddw65
              • Jan 2014
              • 108
              Well, some progress... I think. Got the main board today and put it in. Now, when I hit the power button, relay RL801S on the power board clicks and then ~2 seconds later clicks again and with that last click, the backlight leds all flash for just a split second.
              Hopefully the voltages below taken from CNM80 make sense. I've included the voltage initially and then the drop during the 2 seconds between the relay clicks. Most measurements drop to zero. A couple don't have time to drop all the way to zero and the 5V on pin 12 doesn't drop. Hopefully that makes sense and the formatting works.
              Edit to add that once the cycle starts, it continues until the TV is unplugged.
              Code:
              Initial V	V during 2 seconds	Pin	  Pin	  Initial V	  V during 2 seconds
              3.3	    0	        20	  1	  3.3	      0.13
              1.03	    0	        19	  2	  1.79	  0
              0.99	    0	        18	  3	  0	      0
              0.89	    0	        17	  4	  12.56	  0
              0	    0	        16	  5	  12.56	  0
              0.15	    0	        15	  6	  19.93	  13.9
              0	    0	        14	  7	  19.93	  13.9
              0	    0	        13	  8	  0	      0
              5.32	    5.32	        12	  9	  5.32	  0
              3.3	    0.25	        11	  10	  5.32	  0
              • budwich
                • Jul 2015
                • 3097
                I would suggest you put pin labels on the your "chart" as trying to figure out what the picture says versus what you charted seems less than obvious.... it would certainly help those who are trying to help without "mashing their brains"... :-)
                • toddw65
                  • Jan 2014
                  • 108
                  Well now that I look at what I posted, no wonder it's confusing. I tried to get crafty and totally screwed up the pin numbers. Sorry about that. I'll post a less crafty update shortly.
                  • budwich
                    • Jul 2015
                    • 3097
                    • toddw65
                      • Jan 2014
                      • 108
                      Ok. Attaching it as a picture. Lets see if this is better.
                      • budwich
                        • Jul 2015
                        • 3097
                        better but I don't think you are there yet... where are the pin "labels". Look if its too much effort for you to do, then think about how much effort it is for someone who might be trying to help you out in their "spare time".
                        • toddw65
                          • Jan 2014
                          • 108
                          That was in my very first post. Attaching together to avoid confusion.
                            Sorry. So I click on the pictures of the chart, then click on the pictures of the board, after 10 times of clicking back and forth to see what each pin is and Voltage are for each I gave up.
                            And BTW pin 1 and pin 3 is labeled as N.C. (No connection) so I do not expect to see the Voltages on those two pins.
                            Pin 12 blu-on/off signal is stuck LOW = No backlights.
                            At this point with the info on post 2 and 3, we know which board is the problem.
                            • toddw65
                              • Jan 2014
                              • 108
                              Sorry Bud. I promise I wasn't trying to be a pain in the butt.
                              Two questions: Am I safe to assume that the arrow is pointing to pin #1 on CNM803?
                              And so you'd say that I likely purchased a bad main board?
                                Arrow = Pin 1.
                                The exposed pins you see on the top side of the board are the ODD number pins, to get to the EVEN number pins you have to probe from the backside of the connector using skinny probe tip or probe on the bottom side of the board.
                                • toddw65
                                  • Jan 2014
                                  • 108
                                  Ok. That's what I assumed all along but the voltages on pins 1 & 2 threw me. Maybe this new main board actually bad because I've double and triple checked and then checked again and the voltages are correct.
                                  I also updated to show the voltages/pin/labels all together.
                                  • CapLeaker
                                    Leaking Member
                                    • Dec 2014
                                    • 8352
                                    BLU_on off 0.15V. That is generated on the main board. So you got a bad main board here.
                                    • toddw65
                                      • Jan 2014
                                      • 108
                                      First main board I bought was apparently bad. Another board and the TV is back up and running. Thanks for you help on this one guys.
                                      • Andrew F. Ali
                                        • Jan 2014
                                        • 2450
                                        • Trinidad & Tobago
                                        That's great you got your TV going again but I still think you did not understand when we said we wanted the Pin Nos. and their labels. So what we wanted as an example:
                                        Pin 1 N.C.: 0V
                                        Pin2 std-by: 3.3V
                                        Pin3 bl-on: 2.5V
                                        and so on.
                                        Probably you may get it right on your next repair question.
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • mrtek
                                          Samsung UN43NU6950FXZA No power
                                          by mrtek
                                          Hi
                                          Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
                                          Main fuse = OK
                                          Back light LED = OK. Power them with aux power source
                                          LED output = OK 156V
                                          I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
                                          Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
                                          07-20-2025, 08:06 PM
                                        • hill01
                                          Samsung UE75MU7009TXZG Endless Power Cycle
                                          by hill01
                                          Hi everyone and thanks in advance for any help I might get here
                                          My Samsung TV is about 4 years old. The exact model number is UE75MU7009TXZG.
                                          About half a year ago I started seeing occasional green frames pop up while watching movies. I mean literally green frames. Not the image turning green, but the entire screen turning green for a split second. This happened maybe once or twice during a 2 hour movie. So no big deal, but clearly something was not quite right.
                                          Since a few days, the TV won't turn...
                                          11-17-2021, 02:52 PM
