LN-T4061F has power, sound and picture, no backlights
  • Pioneerx01
    • Apr 2015
    • 241
    • US
    I got Samsung LN-T4061F. Powers on with splash sound, panel has image (flashlight test) but the back-lighting is not on. The power supply is BN44-00165A (IP-231135A, IP-40STD) all good caps, as far as I can see. All voltages are reading fine as well (12V and 5.4V) at least on the cables leading to main board.
    There is a lead coming from the main board called inverter on/off and it reads 5.4V when on. On the other side of the power board there is lead going to inverter called VCC_12V, but it only reads 2.5V. I can't test the transformer voltage as it runs around 2100V and my multi-meter goes to 1000V only.
    Would it be safe to assume that the PSU is bad? Is there anything I can test or replace? If I were to remove the VCC_12V cable from the board and pipe 12V straight to it from other 12V source on the board, would it be safe to do?
    -Peter
    Re: LN-T4061F has power, sound and picture, no backlights
    Can we see the whole back side of the TV? You have power supply/inverter board combination, the High Voltage output is fed into the Balancer board, the VCC_12V is used for the comparator circuits on the Balancer board for the LD (Lamp detect, >10V = Good) error signal and the FB (Feedback for maintaining constant brightness, in mV AC range).
    Do you have PFC Boosted Voltage to run the inverter circuit on that combo board?
    • Pioneerx01
      • Apr 2015
      • 241
      • US
      Technically is is the PSU/Inverter combo, but it does have separate Inverter board as well. Besides that 2.5V DC reading on the VCC_12V I am getting nothing on the other pins.
      Honestly, I am not sure what you are asking in the last question.
        That is not inverter board, it is called Balancer board to balance all the lamps current draw.
        So which board did you replace, the Balancer board or the power supply/combo board?
        • Pioneerx01
          • Apr 2015
          • 241
          • US
          I have replaced none of them. This is how I got the TV.
            Do you have the 13VDC on connector CN801 pin 19/21/22?
            • Pioneerx01
              • Apr 2015
              • 241
              • US
              Yes, all the voltages on the CN801 are good. I am reading 13.57V on 19/21/22
                Then you need to check the UI809 12V regulator 78M12 input and output to see if 13V is present at the input pin, also check the resistance between the output pin and GND pin to see if it show low resistance, it is either that regulator is bad, the filter cap is bad, or the load (UI802S) is bad. See page 3 of the schematic for details.
                • Pioneerx01
                  • Apr 2015
                  • 241
                  • US
                  Yep, the output in only ~2.5V with very high resistance of 8K. Input is at ~13.5V.
                  This is a 7812T Voltage regulator rated at 1A. All I have at home right now is L7812CV Rated at 1.5A. I should be OK swapping those out, correct?
                    Higher current rating is fine.
                    • Pioneerx01
                      • Apr 2015
                      • 241
                      • US
                      Yes, that is true, I just wanted to make sure there is no other electronics aspect I am overlooking, frequency, drop in/out voltage,...
                      I have swapped out the regulators and the TV came to life. I wan to thank you very much for your help and patience. Looking over the problem, I should have been able to figure it out myself. It was not that hard. Oh well. Still A+ for you. Thanks -Peter
                        Glad to hear it was just the bad regulator, there is flaw in that design since the input is only 13V and they want 12V output, there is not really enough head room for regulation, they should have use LDO regulator instead.
                        • stinger
                          Samsung UN70TU6980FXZA no sound no picture but does have backlights
                          by stinger
                          When I turn tv on, the backlights come on but there is no sound or picture. I have read that these tv's have problems with the panels going bad but the "no sound" has me questioning if the main board is bad. Is there a way to troubleshoot the main board to determine if that is the problem?
                          04-17-2024, 03:06 PM
                        • TR103
                          by TR103
                          - it keeps rebooting
                          01-22-2025, 04:12 PM
                        • Mgiffune
                          by Mgiffune
                          06-09-2024, 10:28 AM
                        • Ierwin
                          by Ierwin
                          05-13-2025, 03:31 PM
                        • jchang
                          Samsung UN70NU6900F no picture and no sound
                          by jchang
                          Hi all
                          I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                          Symptom:
                          No picture no sound.
                          When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                          No sound at all.
                          What I tried:
                          1. I tried unplugging the left or right ribbon...
                          01-09-2023, 06:28 PM
