Seiki se421tt
  • heavymachines
    • Mar 2011
    • 1028
    Seiki se421tt
    Hi i have this 42 inch led tv, i replaced the power board and the new one is doing same thing as old, it will run for few hours then shut off. Let it cool down and it will work again for few hours, I noticed the transformer gets very hot assuming this is the reason it shuts off display and power led will remain blue.
    Any help will be greatly appreciated, when i got this tv in here base was broke and cord was cut, i fixed the base and eliminated the cord to a 3 prong socket out of a junk power supply for a computer, cut a hole in the plastic casing to mount the new socket and looks very nice... any ideas what could be causeing the transformer to get too hot?
  • gilly1984
    • Jun 2012
    • 751
    Re: Seiki se421tt
    Is there a fan anywhere? If not try running a 12v pc fan over the hot are and see if it goes off. Could do some more handy work and fit it nicely into the case.
    Do NOT touch heatsinks when testing for voltages as they may be LIVE!
    • heavymachines
      • Mar 2011
      • 1028
      Re: Seiki se421tt
      its pretty thin panel i will check it out, good idea will report results...
      • gilly1984
        • Jun 2012
        • 751
        Re: Seiki se421tt
        Oh yh, you said led.
        Still worth a try.
        • heavymachines
          • Mar 2011
          • 1028
          Re: Seiki se421tt
          Nope still does it, shuts off with fan transformer still too hot and used a 120mm fan
          • heavymachines
            • Mar 2011
            • 1028
            Re: Seiki se421tt
            and power board is all samxon caps could this cause the transformer to get hot? or something causing too much resistance and where to look?
            thanks for any input
            • heavymachines
              • Mar 2011
              • 1028
              Re: Seiki se421tt
              well not near as hot as it was before the fan but what gives it weird it will run for few hours before shutoff...
              • gilly1984
                • Jun 2012
                • 751
                Re: Seiki se421tt
                Its probable nothing to do with the tranny.
                You have replaced the psu so whats left? Never had an led before so no idea of the boards inside.
                Does it have inverters? Im guessing not?
                  Re: Seiki se421tt
                  It will use about 90-150V to light the series strings of LEDs.
                  If a single LED fails, the TV will not run the backlight.
                  • heavymachines
                    • Mar 2011
                    • 1028
                    Re: Seiki se421tt
                    no inverters, ..... hence led lol... it seems to be consistent at 2 hours.
                    the tv is not that old...
                      Re: Seiki se421tt
                      I'd think cold solder joint, tried using a hairdryer to heat up parts of the board and see when it cuts out?
                      • gilly1984
                        • Jun 2012
                        • 751
                        Re: Seiki se421tt
                        New to this ha ha, Kind of figured there wouldnt be inverters.
                        Try what tom says, if theres a person that knows, its tom.
                        What boards are in an led tv?
                        • gilly1984
                          • Jun 2012
                          • 751
                          Re: Seiki se421tt
                          And just looked at that psu again, now,,, is it just me or are they making more simple things then charging us extra? Just that the psu look so empty?
                          • heavymachines
                            • Mar 2011
                            • 1028
                            Re: Seiki se421tt
                            all three boards are small and fairly simple however like you i am new to led...I am aware of tom66 knowledge he helped me in the past, he is awesome help and i fully respect his suggestions and will apply those suggestions...Thanks tom66 i will try your suggestion when i get back to the shop in the morning...
                            • heavymachines
                              • Mar 2011
                              • 1028
                              Re: Seiki se421tt
                              also since its smart gonna check to see if shutoff timer er something dumb is set....
                              • infringer
                                Badcaps Member
                                • Sep 2009
                                • 244
                                • United Frickin States
                                Re: Seiki se421tt
                                if one led fails they all fail? Interesting the old Xmas light syndrome that is just completely retarded imho... I actually opted for two LED TV's as an upgrade to the CCFL type for power savings how insane 1 LED goes out and it won't light up I suppose it isn't impossible to replace an LED but ... The real pain comes from getting to the backlight in the first place lol very poor engineering talk about a way to get you to buy a TV sooner lol at they rate they charge each LED should have a backup led in case one does fail.
                                Please note: I am not responsible for any harm caused to you anything discussed is just discussion. Before you try anything discussed be sure that you have the appropriate knowledge and safety gear for the job. Like with anything education and safety are first! Do not try anything @ home without it.
                                  Re: Seiki se421tt
                                  From the look of the power board, there are at least two LED strings for this TV which is typical.
                                  For examples:
                                  This 40" has 2 LED strings with 125 LEDs per string for edge lit panel.
                                  http://s807.photobucket.com/albums/y...20UN40D5005BF/
                                  32" with backlit panel. Two LED strings.
                                  http://s807.photobucket.com/albums/y...2EH4050F%20TV/
                                  • heavymachines
                                    • Mar 2011
                                    • 1028
                                    Re: Seiki se421tt
                                    I think it has 4 strings of led those 4 small matching connectors are for the led backlight.
                                      Re: Seiki se421tt
                                      They should be labeled with something like DRV1+, DRV1-, DRV2+, DRV2-, etc.
                                        Re: Seiki se421tt
                                        Which transformer that gets hot? The large one in the center or the top right for the PFC.
                                        • learnmore
                                          Help choosing replacement transformer for Levoit 600S SMPS
                                          by learnmore
                                          Hello Community,
                                          I'm attempting to repair the SMPS on a Levoit 600S air purifier. The transformer is likely open. It has six pins. 2 pairs on the primary side (one pair tested open) and 1pair of legs on the secondary side. Legs on the secondary side are spread wide apart (end-to-end). I've circled them in blue. Dimentons of the transformer are 22x23mm. Marking on the transformer are EE16 1.9mH-B. Fuse for the powerboard is fuse 250V 3.15A. I've been unable to find an exact match and I'm hoping for some help here to find a suitable replacment.
                                          Peace
                                          LM...
                                          11-04-2025, 09:35 AM
                                        • mikey5791
                                          Is it possible for transformer substitution?
                                          by mikey5791
                                          Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                                          Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                                          My questions are
                                          1. How do i test to see if the transformer is in good working condition?
                                          2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                                          Hope you guys understand what i was asking. My intention is...
                                          11-03-2022, 02:11 AM
                                        • dennis_elx33
                                          3PHASE STEP-DOWN Transformer in Check
                                          by dennis_elx33
                                          Hello All,
                                          i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
                                          Problem statement: Power tripped Off
                                          Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
                                          Action Done:
                                          1) Replaced the faulty parts with good spare.
                                          2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
                                          12-02-2024, 06:52 AM
                                          ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) Book Specification for Upgrade or Repair
                                          This specification for the ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T101HA - X5DHD boardview and T101HA - X5DHD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 04:40 PM
                                          ASUS Transformer T304UA-P71SP-CA Hybrid (2-in-1) Pro Specification for Upgrade or Repair
                                          This specification for the ASUS Transformer T304UA-P71SP-CA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T304UA-P71SP-CA boardview and T304UA-P71SP-CA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 12:00 PM
