Testing LG 47LN5700 backlight ps output w/ resistor
  • gliebisch
    • Oct 2017
    • 6
    As a way to verify proper output of the backlight power supply in LG 47LN5700, is it a legitimate method to simulate the LED load with a resistor? I have the schematic and spec of the two LED outputs, which are each nominally 0.4 A. So I thought about connecting a 250'ohm power resistor to each output, just long enough to get a normal load voltage reading. Since it calculates to about a 40W load, it would be for only a short duration for a measurement on each output, since I don't have a 40W resistor. Access to the LED + and - is possible without bothering the connector, although the connector will be out of course.
    I want to do this before I start tearing into screen disassembly chasing potentially bad LEDs.
    Re: Testing LG 47LN5700 backlight ps output w/ resistor
    Well, you need to find out what the Vf of the total LED string is fist.
    How did you come up with 250 Ohms?
    "I have the schematic and spec of the two LED outputs, which are each nominally 0.4 A." You forget about the Voltage output with loads, 100V 110V? The Vrdops on the LED string is not 100V because you also have MOSFET and current sensing resistor in series with the LED string that being driven. In your case from the other thread, you have 19V drops for the MOSFET and the resistor.
    BTW, you also need to understand how the LEDs string are connected in your panel and how set of LED strings it has, 1, 2, 3, 4? You will have to look at the LED driver circuit the board to figure that out.
    Your board has two boost converters to drive two sets of LED strings, since I already told you you have open circuit in one of the string, then all you have to do is to swap the two sets of the LED sting wires to see if the problem will follow.
      https://www.badcaps.net/forum/showthread.php?t=61174
      I already told you you have open circuit in one of the LED string. So what are you trying to do?
      LG LN5000 series:
      https://www.badcaps.net/forum/showth...ht=LG+47LN5790
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        There are reasonably cheap led testers on the market.
        http://www.ebay.co.uk/itm/SID-GJ2C-L...-/282072043319
        • gliebisch
          • Oct 2017
          • 6
          OK, thanks , Bud. Since I don't want to butcher the cable going from the LED driver output to the LED strips, suppose I swap the two LED drive circuits by creating a breakout on the PS/driver board from the points noted on the schematic attached here. With pigtail leads from these points I can easily swap LED 1 with LED 2, as you suggest.
          I appreciate your diagnosis of a bad LED string earlier. This exercise is purely to convince me that I have no choice but do do surgery on the LED strips, whereas a PS board replacement would be easy.
            https://www.badcaps.net/forum/attach...5&d=1509023144
            As you can see, all you have to do is to swap just two wires either the L+ wires or the L- wires.
            But since you have the diagram (which you should up load for future ref. for other people), do you now see why if you have open circuit in one of the string you will get 0V on the L- return pin?
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              From what I have read....you have an open LED on the backlight string. If it was me I wouldn't waste time trying to re-invent the wheel or for that matter invent anew wheel...I would strip down the panel to backlights and determine which strip or strips is the problem and decide if I would use the 'Reecyburger stack' method or buy new strips to repair this TV.
                Originally posted by andrew f. Ali
                from what i have read....you have an open led on the backlight string. If it was me i wouldn't waste time trying to re-invent the wheel or for that matter invent anew wheel...i would strip down the panel to backlights and determine which strip or strips is the problem and decide if i would use the 'reecyburger stack' method or buy new strips to repair this tv.
                +100, already explain how it works and why.
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4333
                  • Italy - Milan
                  I think the cheaper way to test LEDS are those Boost converters bought from China in conjunction with a ultracheap o free ATX PSU.
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    • uk
                    This is the tester i have for testing leds and here is the link for the stacking method led repair
                    https://www.ebay.co.uk/itm/SID-GJ2C-...75.c100623.m-1
                    https://www.youtube.com/watch?v=RxwdC7V5Ue0
                    • gliebisch
                      • Oct 2017
                      • 6
                      I would like to thank you, BudM and all the others for the invaluable assistance in getting my 47LN5700 repaired today. It was indeed one entire LED strip (L+R) that was out plus a single LED on another strip. I just replaced them all. Instead of buying an LED tester, I bought a Yescom 30V variable DC supply from Amazon, which is capable of a constant current mode. I was able to then test each pair (L+R) of strips (9 LED's) with about 24 volts and constant 50 ma current. I can use that power supply for general bench work and it was about the same price as the LED testers. In retrospect now, I spent too much time thinking it was the power supply. Upon repowering my TV, the backlight had been set at 100, I turned it down to about 75. Did a software check but it told me I already had the latest software. Not sure if the on screen software check is just for the Smart TV apps, or includes firmware for the system.
                      For anyone who needs it , attached is the PDF I used to find my way around the power supply LED driver, which I got from another poster who uploaded it in the past.
                        Thanks for the follow-up, glad to her you got it fixed.
                        90% of the TV that use LEDs for backlights will have failed backlights due to failed LED/s.
                        • FrancescoV
                          Onkyo HT-R390 no sound output, video output ok
                          by FrancescoV
                          Good morning everyone,
                          I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                          The firmware reported is the following:
                          M:1.00/11107BLP
                          D:?.??/????????
                          O:1.00/11107AL
                          The DSP firmware given the question marks seems corrupt.
                          On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                          05-11-2025, 02:59 AM
                        • jinu_j
                          Dell 2209WA - power supply - Fusible Resistor replacement
                          by jinu_j
                          Hi
                          I am trying to repair an ancient Dell 2209WA Monitor which suddenly shut off with a pop sound. On investigation found that one of the fusible resistors had blown. Further investigation identified multiple components as faulty because of which the fusible resistor blew. Please refer the attached circuit diagram showing the components that were found to be damaged.
                          1. FR950 - blown fusible resistor - 0.2 Ohm 1W
                          2. Q950 - shorted Q950 MOSFET - 650V 10A N Channel Mosfet
                          3. R835 - Blown Resistor - 20KOhm SMD resistor
                          4. D930 - Shorted Schottkey Diode...
                          05-03-2025, 10:51 PM
                        • mikey5791
                          Need help to replace burned resistor in 350w atx psu
                          by mikey5791
                          Hi to all forum members,
                          Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                          The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                          Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                          Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                          12-26-2024, 04:55 AM
                          NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                          by sam_sam_sam
                          I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                          I bought this from an eBay seller but unfortunately they only had one
                          I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                          I bought three of from them to also make battery packs with this output power limit in mind
                          I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                          04-23-2025, 05:50 AM
                        • MidnightRoller
                          Can a resistor lose resistance after hot air?
                          by MidnightRoller
                          I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                          I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                          02-02-2022, 11:46 PM
