LG 42PT350R clicking on/off
  • Fengo
    • May 2013
    • 39
    • South Africa
    Hi guys, i have a lg 42pt350r plasma that clicks on and off. Initially it had a purple display. I opened it up and try to determined the fault. Disconnected zsus and ysus boards. Measured voltages and all were correct. Disconnected mains and connected plug from zsus. Was in a hurry i guess, coz i got a spark on Va line. Since then tv just clicks on and off and voltage readings on Va is 109 and Vs 404.
    Any help will be greatly appreciated.
    Re: LG 42PT350R clicking on/off
    Va is 109???? Vs 404?????? Check your multimeter battery, and you should be using volt DC not AC.
    If you connected Va while the set is running, there is a good chance you have damaged the plasma panel (driver ICs), which would not be repairable without full glass replacement. Cables should never be connected or disconnected while running unless they are part of the low voltage side.
    • Fengo
      • May 2013
      • 39
      • South Africa
      You correct Tom, i used AC instead of DC. Stupid me...lol!!
      Never messed with the wiring while tv was running, did not wait till the caps discharged though.
      Tv clicks on, high pitch noise from zsus, then clicks off. Repeats that cycle endlessly.
      Problem is with the zsus i guess, just dont know which component.
      Desoldered one leg of big fuse from board and psu goes on and stays on.
      So problem definitely with zsus. Even changed some mosfets on zsus without any changed.
      Fuses all checked okay.
      Psu only clicks on and off when zsus connected, no other boards.
        With Zsus disconencted panel should have a dim, purple image. Does it?
        • Fengo
          • May 2013
          • 39
          • South Africa
          Nope, no image at all. Screen is completely dark.
            Your Vs and Va match panel sticker?
            In the middle of the set there's a small green board which connects to nearly all of the others. Please post a picture of that.
            • Fengo
              • May 2013
              • 39
              • South Africa
              Pic attached.
              Thanks Tom
                OK, see attached.
                TV must be unplugged:
                Two holes marked EXT AUTO GEN: Place a small wire jumper connecting them.
                The connector I have highlighted: Unplug it.
                Turn TV on (plug it back in.) Do you get test patterns? If NO, check Vs/Va. Do they match panel sticker? If NO, unplug Z-sus (this time with power off.) Power TV on again, do purplish/dim test patterns appear?
                • Fengo
                  • May 2013
                  • 39
                  • South Africa
                  No test patterns at all. When z-sus connected psu clicks on and off, no voltage readings on Va and Vs. Z-sus removed voltage match panel sticker.
                  Also noticed that when ribbon cable fom z-sus to control board were removed, high pitch sound from z-sus were quiet.
                  But it still clicks on and off.
                  Problem with z-sus must be on Vs rail, coz when 250V fuse on z-sus were removed, psu clicks on and stay on.
                  Power also went to control board, and green led flashes.
                    I think you have a defective Z-sustain then. But one final check. There is a little connector on the Z-SUB board. The Z-SUB connects to the Z-sus and panel. Where does this cable go -- to the bottom of the plasma display? If so unplug it (power must be off!) Then plug set back in WITH z-sus connected. Do Vs/Va come up? Do NOT reconnect this connector with power applied!!!
                    • Fengo
                      • May 2013
                      • 39
                      • South Africa
                      Still dead-end. Just clicks on and off.
                      Also thought z-sus is defective.
                      Any idea what usually fail on it?
                        Did that connector go to the bottom of the panel (long green board) or not?
                        • Fengo
                          • May 2013
                          • 39
                          • South Africa
                          Yes it does.
                            OK, at least you have ruled out a plasma panel short. It must be Z-sus then. Common faults are shorted transistors, bad diodes but also the chips which drive the transistors can go bad.
                            • jose6326
                              • May 2013
                              • 707
                              sounds like simialr problems on the Lg tv i picked up yesterday
                              only difference is the fuse is blowing on the psu
                                The problem is completely different unfortunately.
                                • Fengo
                                  • May 2013
                                  • 39
                                  • South Africa
                                  Thanks a mil for your time Tom.
                                  Will try to troubleshoot the most common problems then.
                                  Parts are not readily available in south africa, so i will have to troubleshoot with what i got.
                                  • jose6326
                                    • May 2013
                                    • 707
                                    well hopefully its an easy fix
                                    • steven82
                                      • Mar 2015
                                      • 3
                                      • malaysia
                                      Hi Tom,
                                      Currently facing same problem with my LG. found the zener diode/ scholtky diode kaput and code is blur..xx14 something. can found at Z and Y sus board...may know the to get this part? need help.
                                      • steven82
                                        • Mar 2015
                                        • 3
                                        • malaysia
                                        Fyi, as per attachement.
                                        thanks.
                                        • TrisHCl
                                          LED TV Boot loop - UE40F6500SB
                                          by TrisHCl
                                          First post...
                                          I have this TV, which was working, then suddenly would not turn on. It would get the clicking relay then flash up the screen for less than a second, off for a second then on again. Removing the plug the relay continues to click on and off for a few cycles, which I don't think it did before.
                                          Left it a few months, then finally got round to taking the back off, and it worked as it should. So I tested various bits and all was well. Then turned it on again, and back to the clicking relay.
                                          I disconnected the main board from the power...
                                          02-06-2025, 08:42 AM
                                        • EazyBone
                                          Qn65q800taa won't start
                                          by EazyBone
                                          Did some of the usual troubleshooting.
                                          Unplug main board connector and back lights come on and stay on and PSU supplies all correct voltages on the legend.
                                          When you just plug in the TV the PSU relay clicks on and off immediately and then continues to click on and off every 20 seconds or so. The red light on the front flashes once and then 5 to 8 seconds later flashes once again and continues the cycle with the relay.
                                          I've disconnected each you ribbon cable one at a time and every single T-Con cable one at a time to see if there's any change. No change as long...
                                          03-20-2025, 12:47 PM
                                        • slimmy182
                                          [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
                                          by slimmy182
                                          Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
                                          I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
                                          Looking on google I found this:...
                                          01-14-2023, 11:55 AM
                                        • GRANDGG
                                          LG 42lw4500 flashing red light , wight light , 2 clicks
                                          by GRANDGG
                                          Hi i have an issue with LG 42lw4500 wich after pressing the power button flashes red then goes solid white light 2 clicks and nothing , the weird thing is SOMETIMES if i leave the tv plugged in it would come on and fuction normally (i should mention that vertical rectangle going from the bottom to the top of the screen have some red dot artafacts it only appear in somthing like the tv input menu and any input i give like vga , but not in the system menu , i thought i should mention this , i cannot confirme if the tv had this issue when it was up and running in its previous owner . ) when checking...
                                          05-09-2025, 12:27 PM
                                        • Woodsworth
                                          MacBook Pro A2289 no signs of life except clicking trackpad and charging
                                          by Woodsworth
                                          I hope this is the correct place to post about this device. I originally posted regarding this on iFixit so see the details from that post below:
                                          "I'm hoping someone can give their opinion on the symptoms I'm seeing before I spend any more time and put money into this. I got this MacBook from a customer and after looking at it they decided they didn't want it.
                                          It doesn't turn on and there's no visual signs of life. I have tried resetting the NVRAM, SMC, power cycling, unplugging the battery, using the charger with the battery unplugged. Removed the...
                                          03-15-2024, 04:06 AM
