Rework Station Pump - Can They Be Repaired ?
  • mmartell
    • Oct 2013
    • 3189
    Turned on my 852+ clone the other day and the unit made a damn racket. Noticed quickly there was little to no airflow out from the wand nozzle and shut it down.
    It seems there are seals at the diaphrams that are know to melt or otherwise malfunction but parts are all but impossible to procure.
    Has anyone rebuilt one of these with off the shelf parts or should I start looking to replace the whole station ?
    • 31255
    Re: Rework Station Pump - Can They Be Repaired ?
    you can get the pumps cheap,
    but did you take it out yet? they can crack - and be sealed.
    • mmartell
      • Oct 2013
      • 3189
      Taking out the pump soon for inspection. Where do you see them for sale ?
        • 31255
        chinese places.
        *if* they are over $20 then buy a new unit with a fan in the handle.
        this goes nicely wih it.
        http://www.eevblog.com/forum/reviews...stom-firmware/
        • clearchris
          • Dec 2013
          • 687
          You can also replace with an air horn pump. Check the voltage though.
            • 31255
            no you cant, that's a hot-air unit - not a solder-scker.
            • clearchris
              • Dec 2013
              • 687
              Oh, woops. You are correct.
              • mmartell
                • Oct 2013
                • 3189
                Had a closer look at the diaphragms and I see no evidence of degradation or tearing. Will remove the bottom plate and check the motor itself next. Looks like these motors run off line voltage intead of the 12v I was expecting.
                • mmartell
                  • Oct 2013
                  • 3189
                  Removed the diaphragms and the bottom plate. The piston vibrates but does not move back and forth like it should. I can't yet tell if there is a track it should move in or moves just by magnetics ?
                  It seems like the diaphragms are weak, not torn in any way but too pliable. If these are meant to keep the piston in place then they are too weak as I can easily move the piston up and down with light pressure.
                  Any thoughts ?
                  • mmartell
                    • Oct 2013
                    • 3189
                    Should the diaphragms be strong enough to keep the piston from being pulled sideways to one of the coils ?
                    • xelectech
                      retired tech
                      • Nov 2014
                      • 238
                      How 'bout a picture or 2?
                      • mmartell
                        • Oct 2013
                        • 3189
                        Yes good idea. Will put some up later today.
                        • mmartell
                          • Oct 2013
                          • 3189
                          Some pics... they've all been rotated, yay.
                          The first pic shows the core with dual coils wired in series. Both coils ohm out to about 146ohm so I think they're good ??
                          The second shows the "piston" with dual magnets.
                          The third shows the piston inserted between the coils.
                          The fourth is the housing that the assembly slides down into.
                          The fifth is the control board.
                          There is no "track" or discernible way for the piston to be kept in place. In pic 3 the magnets are easily drawn to the core so when the whole unit is assembled they remain bound to each other such that no movement is possible whether power is applied to the coils or not. This is what makes me think the diaphragms (damn, pic coming!) should be stiff enough that when assembled they keep the piston BETWEEN the coils.
                          I'm sure someone here knows the precise theory of operation here so help me out. Are the diaphragms to blame or something else ?
                          • mmartell
                            • Oct 2013
                            • 3189
                            Diaphragms. You can see in the third pic how easy it is to distort them with one hand.
                            • xelectech
                              retired tech
                              • Nov 2014
                              • 238
                              Strange looking motor, for sure, I've never seen one like that. How are/were the diaphragms attached to the spindle? Just a guess, maybe each diaphrapm was ultrasonically or chemically welded to the black piece on each end, which made them stiff enough to keep things in place.
                              Looks like some kind of deposit on the control board, what do you reckon that is?
                                • 31255
                                the white is flux that got wet because they washed the pcb without removing it all first.
                                • mmartell
                                  • Oct 2013
                                  • 3189
                                  The diaphragms are mounted to the spindle by a small nut, and secured around the perimeter by the chambers that get screwed down over them to the main assembly.
                                  Stab at theory of operation - the coils receive a pulsed voltage pulling one of the the piston magnets in line with the core providing a full stroke in one direction. When the pulse abates the piston returns to the center position where the next pulse pushes it further in that direction until the second piston magnet is in line with the core and the cycle continues.
                                  Is any of that correct ?
                                  • mmartell
                                    • Oct 2013
                                    • 3189
                                    Is it safe to hook a scope to the coil source ? Maybe this is missing half the wave...
                                      • 31255
                                      i would say the diaphrams have somehow broken loose from the pole-piece.
                                      • xelectech
                                        retired tech
                                        • Nov 2014
                                        • 238
                                        Is it obvious how this thing built pressure, ie reed valves or some other separate mechanism, or did it depend on those holes in the diaphragm to somehow do the job?
                                        Stab at theory of operation - the coils receive a pulsed voltage pulling one of the the piston magnets in line with the core providing a full stroke in one direction. When the pulse abates the piston returns to the center position where the next pulse pushes it further in that direction until the second piston magnet is in line with the core and the cycle continues. Is any of that correct ?
                                        I was thinking it was just running mains frequency thru the coils, doing cycles of attraction/repulsion, but I could be wrong and you right. That motor is really cool, though, must be nearly zero friction when it's working...
                                        • shahnld
                                          wds-580 rework station issue
                                          by shahnld
                                          Good day.
                                          i received used bga rework station wds-580 which was not going above 300c despite the parameter was set to 350c, Everytime beeps at 300c so i did a factory reset and by mistake washed data and log etc. now the station boots to a white screen.
                                          Does anyone has a firmware for this station and want to share with me. i will really appreciate any help possible..
                                          kind regards...
                                          03-28-2024, 01:14 PM
                                        • minimania
                                          Need Schematic for jbc am6800 rework station
                                          by minimania
                                          hi all im looking for a Schematic for jbc am6800 rework station
                                          mine has stopped working fully
                                          it started with turning off when switched on then after a few off and ons it worked sort of for awhile
                                          now it wont turn on at all...
                                          01-28-2025, 03:44 PM
                                        • shahnld
                                          Seamark ZM-R6200 Rework station
                                          by shahnld
                                          Good day Experts.
                                          I have recently aquired a rework station SEAMARK ZM-R6800,. Is there anyone using this or some other similar station and give me some info about profile temp curve etc for removing leadfree soldered gpu chip..? just 1 profile will be enough to get started.
                                          Kind regards
                                          01-24-2024, 10:55 AM
                                        • petemanuk
                                          Help with IR6500 rework station
                                          by petemanuk
                                          I been playing with a recently acquired IR6500 rework station and watching lots of YouTube tutorials to see how to use it with not much success. I’ve only recently joined badcaps but going through the forums there is a lot of knowledge here, so though it best is if I ask my question here.
                                          1. Firstly is the IR6500 any good for BGA rework or should I be spending my money on a better one.
                                          2. The instruction manual is pretty useless on explaining how to set the PID loops (no information at all!!) both top and bottom heater for th Kp, Ki and Kd...
                                          10-14-2022, 12:31 AM
                                          ZD desoldering station pump rebuild
                                          by stj
                                          just did one.
                                          works great.
                                          so here's the discoveries.
                                          the pump "modules" have 4 parts, the main body, the outside bit, the inside bit - screwed to the main body, and the diaphram.
                                          the failure is the inside bit, it has a rubber coating for some reason that becomes tacky and breaks down - contaminating the diaphram.
                                          so you need to clean everything to get rid of all the tacky black stuff.
                                          then reassemble it.
                                          *BUT*
                                          you must put the 2 screws into the assembly only finger-tight.
                                          if you tighten it properly the valves dont work....
                                          08-21-2024, 05:59 PM
