toshiba sattelite L50-B-11C
  • grec
    • Mar 2013
    • 21
    • BiH
    how to reset bios password on this model or if any have bios bin file for seeprog please upload here !!
    thanks advanced
  • grec
    • Mar 2013
    • 21
    • BiH
    Re: toshiba sattelite L50-B-11C
    name of motherboard is DABLIDMB8E0 REV:E ..
    I'found here but can not download only vip member can download file ...
    https://www.elvikom.pl/schemat-toshi...ang=en#p143899
    or here
    https://www.vinafix.vn/threads/toshi...-psktae.14633/
    • Agent24
      I see dead caps
      • Oct 2007
      • 5096
      • New Zealand
      You could donate https://www.elvikom.pl/donate.php?lang=en and buy some points to download the file..
      Or maybe you can get the BIOS updater from Toshiba and extract the BIOS image from that?
      -David VanHorn
      • grec
        • Mar 2013
        • 21
        • BiH
        Bios is available on the manufacturer's website exe format and do not want to unpack.
        • Agent24
          I see dead caps
          • Oct 2007
          • 5096
          • New Zealand
          What software did you try to use to unpack it?
          -David VanHorn
          • ala_borbe
            aka Donald
            • 1625
            • Malta
            backup old and try this
            Im Back... sort of...
            • fernanixx
              • Nov 2016
              • 3
              • PHILIPPINES
              hey i need rom for DABLIDMB8E0 REV. E board
              i need the 1kb rom not the 8mb thanks!
              • polytek
                • Dec 2013
                • 497
                • TUNISIA
                this what i read from my board. and it's ok
                • naeemshahzad
                  • Jan 2015
                  • 129
                  • uae
                  hi here is what you ask for just take backup
                  • bluestar77
                    • Apr 2015
                    • 57
                    • sudan
                    Hi ,
                    If you want to reset password for this model you have to short G2 jumper it's near the CPU plug the ac adapter short this jumper and power it on don't remove the flat scrow driver form the G2 until you see the password had gone if you fail redo it again
                    • Attif
                      Attif
                      • Dec 2016
                      • 49
                      • pakistan
                      Re: toshiba sattelite L50T-B-11C
                      Main bios
                      • neoblink
                        • May 2017
                        • 3
                        • españa
                        Hi, how are you guys doing? I have a case with a toshiba satellite l50-b-18e laptop which turned on normal until I open it to clean ram. After putting lid does not start is left the light on the blue power connector and when battery is changed to red. The power button has the 3v and goes down to 0v when I press it. By dismissal I assume it is bios. And I would need your help to locate the bios of this laptop. Thanks in advance
                        • b8engl
                          • Oct 2016
                          • 1
                          • Portugal
                          Neoblink, did you fix that issue, cause i have the same here with my toshiba l50-b-23f dablidmb8e0 rev e?
                          • ismaelpulgar56
                            • Aug 2017
                            • 1
                            • chile
                            hola alguien sabe el valor de PR838 ,gracias
                            • borked it
                              • Sep 2017
                              • 2
                              • Aus
                              Found you guys via google, having similar issue I think so thought Id bump the old thread.
                              Toshiba L50-B PTSKNA 02RO16, I think it has Insyde BIOS (the DL for the precise machine from Toshiba has Insyde apps in it), but Im unsure. Mobo is dablidmb8e0 rev e as Ive looked inside.
                              Machine was slow and lost an AMD display driver but the system ran off the Intel and a newer AMD driver might have worked, unsure., Device manager said it was fine. I went to factory reset but seems Win 10 killed off the recovery partition for 8.1. No matter how I tried to effect a reset, it failed and the only OS option if offfered under any of hte chpoices was Win 10. 8.1 seems to be gone. So I attempted to do a fresh install with Win 10, and DLed a heap of drivers from Toshiba site.
                              So I just did a reinstall from a Win 10 disc. Machine seemed to install fine, walked away and leftit do its thing and when i came back and it was blank screen, no lights. Left for a while, nothing changed so thought maybe it shut down.
                              When I went to power it up, I get the usual flashing white light around power button, a few greens around keyboard and then all lights stopped after maybe 5 flashes. No sounds, no fan, no hdd, nadda.
                              Would I be right in assuming the BIOS is not functioning? Ive tied the Insyte flash BIOS as per https://www.bios-mods.com/bios-recov...bios-recovery/
                              Im using the BIOS exe from Toshiba for the particular machine, with an fd file extracted from it for x64, but wonder if maybe thats the wrong one.
                              Regardless, the outcome of the falsh technique is the same as the problem. No change.
                              Any hints?
                              • borked it
                                • Sep 2017
                                • 2
                                • Aus
                                Cant edit?
                                To clarify, when i say tried to flash, I mean tried, it does nothing different so its not flashing the BIOS.
                                • djtaiba
                                  • Jan 2017
                                  • 21
                                  • algeria
                                  its work !!
                                  • slcktnr
                                    • Jun 2018
                                    • 2
                                    • turkiye
                                    Thank you
                                    • johnnie boy
                                      • Jun 2018
                                      • 2
                                      • Greece
                                      hi guys attatched is 2 photos but i cannot see the G2 only G3 ? isit marked as G3 on this particular model ? as i see that some people see G3 ?
                                      this is located directly behind the power connector
                                      thankyou
                                      • jasn78
                                        • Jun 2018
                                        • 1
                                        • australia
                                        Johnny boy I am having a simliar issue however mine is due to loading ubuntu 17.xx that corrupted my kernel. I didn't realise until after I wiped the drive to reload an os about the bios issue. So I can't do any of the standard fixes. If you find a way of resetting I would also love to hear.
                                        • to5it0
                                          Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                                          by to5it0
                                          Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                                          I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                                          This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                                          I have opened the laptop and identified the main BIOS chip...
                                          10-24-2025, 01:35 AM
                                        • Citymin
                                          NT955XED (Samsung Galaxy Book2 Pro - 15.6) BIOS dump file Request
                                          by Citymin
                                          My Samsung Galaxy Book 2 Pro 15.6-inch laptop has no display and won't boot.
                                          The charging red LED lights up, but the charging screen doesn't show any indication.
                                          When I press the power button, the blue LED cycles on and off three times, then the screen doesn't turn on, and the device won't boot.
                                          (I've tried removing the battery and resetting the device, but the issue persists.)
                                          NoteBook Model name : Samsung NT955XED-KK51G(Galaxy book2 pro, i5-1240p, 15.6inch AMOLED)
                                          PCB model name : Venus2-15-5G(REV1.2), Venus2-15 ADL NPC
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
                                        • maanee11
                                          Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
                                          by maanee11
                                          Hello Everyone,
                                          I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
                                          It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
                                          In the website, you can only see specs etc.
                                          I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
                                          11-08-2025, 04:08 AM
                                        • m1ch43lzm
                                          Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                                          by m1ch43lzm
                                          Hi everyone
                                          I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                                          Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                                          Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                                          There's also an extra OTP Secu.R...
                                          09-06-2025, 05:47 PM
                                        • HOHA
                                          BIOS file for Toshiba Dynabook Satellite Pro C50-J-10M
                                          by HOHA
                                          Hi can you help me
                                          I did not find the BIOS file for Toshiba Dynabook Satellite Pro C50-J-10M
                                          IP3_TN16S_MB_V30_20210901A
                                          This is the old BIOS file, it is corrupted​...
                                          10-20-2024, 08:22 AM
