Samsung QLED Q60R constant reboot issue
  • MisterMystery
    • Jun 2021
    • 3
    I have a Samsung QLED Q60R tv model QN55Q60RAFXZA version AA02.
    As soon as I plug it in, it powers up and shows "SAMSUNG QLED TV" on the screen and the screen goes dark and I hear a little musical jingle but from that point, it reboots and starts the whole process over again. It wouldn't respond to any input from the remote.
    I ordered the repair kit for it, sj-KIT-QN55Q60RAFXZA-K2, from ShopJimmy and just got through installing the main board and power supply boards with all of the cables that came with it and I'm still getting the same result. What do you recommend I do from this point? I'm not sure what's wrong.
    The funny thing I installed the original boards and the last time I plugged it in, the tv actually responded to the remote but there was no picture but a backlight. The screen would dim when I would press different buttons but no picture. Very peculiar behaviour.
    I did test the voltages coming out of the original power board pins and they all matched the voltages silkscreened onto the board within a few points.
  • William1967
    • Nov 2017
    • 217
    • Netherlands
    Re: Samsung QLED Q60R constant reboot issue
    Probably a defect in the display, more common with Samsung with the 2 wide LVDS cables, sometimes repairable.
    • ikmpch
      • Jul 2020
      • 22
      Hi, it looks like EEPROM chip on main board is either bad or the software is corrupt. Check the EEPROM datasheet and test it. It could be helpful.
      • MisterMystery
        • Jun 2021
        • 3
        I appreciate both of your responses. Instead of looking at the EEPROM, would it not be easier to replace the entire board? That's what I did by ordering the kit. It came with the power board, main board, and cables and it still didn't fix the problem.
        As far as the display, why is it that I can still see the logo when it boots up if the display is faulty? And is it practical to replace components on the display? I did look into just replacing the entire screen and it's not available anymore and it's also over $500 which at that point I'm just going to buy another tv.
        • brucetv
          • May 2015
          • 281
          • united states
          With todays Samsung's it could be a short in the backlight's, lower panel driver boards, and a short in the Main board. We see very few problems with their power supply's except with the exception of a half dozen models. I unhook the main first and see if the backlights stay up. If they do I probe the main, look for optical, and then start unhooking ribbon cables. With alot of them that did away with tcon boards we find a ton of shorted caps, , resistors, and diodes. Sucks Samsung!
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4545
            • Italy - Milan
            brucetv, this is a Qled, so i guess theere is an entire Full hd screen of leds behind lcd screen as a backlight source.. i don't think the troubleshooting of normal backlight is suitable, each led is single way controlled by a special high density chip.
            • jneupauer@sbcglobal.net
              • Apr 2018
              • 9
              did the tv stay on when you put the original boards back in?
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4545
                • Italy - Milan
                Like i have said nothing, qled are normal backlight sorry
                  • Apr 2018
                  • 9
                  this QN55Q60RAFXZA was rebooting.
                  backlights stayed on when power cable to main was disconnected.
                  i reconnected the cable.
                  pulled ldvs cables... set stayed on.
                  turned up volume... had sound.
                  remote turned the set on and off normally.
                  tried each ldvs cable one at a time... set stayed on.
                  reconnected both ldvs.. set reboots.
                  i removed panel circuit board cover and let it run with both ldvs cables connected.
                  felt around the boards until i burnt my finger.
                  found diode pack hot.
                  removed two hot diode packs.. restored the tv to a working state.
                  they are very tiny
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4545
                    • Italy - Milan
                    Good job.. now it would be important to replace them, them are protection tvs diodes, them has at least more or less 40-50v rating because them are to protect clock signals i guess, normally clock signals have peaks of vgl to vgh so about -7 to 30v.
                    • brucetv
                      • May 2015
                      • 281
                      • united states
                      what were the markings on those diodes or url with order info. This old fart can barely see these with the scopes help. Did you get them at Mouser or Digikey? thx
                      • Ihsani
                        • Jun 2021
                        • 5
                        • Holland
                        Good day,
                        I have the same problem with Samsung TV QE55QE64ERAL .
                        the tv does turn on then the logo (QLED SAMSUNG) appears then it turns off.
                        The diodes don't get hot for me.
                        What could be the problem ?
                        thanks
                        • skaja
                          • Dec 2021
                          • 3
                          Thank you! Removing the two diodes worked for me on my qn65q80raf! First I removed the d002 with no change, then I removed d001 and the TV began functioning properly.
                          • skaja
                            • Dec 2021
                            • 3
                            Uhoh, now I notice very faint black horizontal lines on the entire panel. Not terrible but noticeable. Any idea of where I can find replacement diodes?
                            • skaja
                              • Dec 2021
                              • 3
                              I managed to resolve the ‘fixed horizontal lines’ by putting a half inch piece of tape on part of the panel led ribbon. This video helped me although it’s not exactly the same issue. Good luck future readers.
                              https://youtu.be/XCJAx92JwPs
                              • nomoresonys
                                • 12332
                                • U.S.
                                Good to hear, with the tape cutoff method working, I wonder if you could put those chips back in place, some report that they are needed, I'm not sure, haven't run across this issue myself??
                                • Gawrion
                                  • Feb 2022
                                  • 2
                                  • Poland
                                  Hey! I got exactly the same weird issue with my QLED. Tommorow i will check if my diodes are gettin hot. Did You left Your set without or did U replace them with new ones? Is Your TV working fine now?
                                  • Dennistech28
                                    • May 2018
                                    • 2
                                    Hi any resolve to this issue. I have the exact QLED Q60R TV. the same area gets warm when both lower boards are connected, when either one side or the other is connected the back lighting stay on and the area stays cool. like an over load with both connected.
                                    • nomoresonys
                                      • 12332
                                      • U.S.
                                      probably those diode packs, could try the method in post #15, maybe someone can verify HOW warm the diode packs get on a normal functioning tv.
                                      • Pooshoes
                                        • Mar 2022
                                        • 12
                                        I had the same issue with my set, 55" QN55Q6DRAFXZC. It would show the samsung logo and reboot. In my experience with bad panels if the LCD had an internal short usually it wouldn't display a logo so i suspected something else was up. I whipped out the thermal camera and discovered d001 was getting toasty (140c+) and under the microscope you could see factory flux black and bubling out from under the chip. Simply knocked off the diode pack with a blob of solder on my iron and TV is back to 100%.
                                        Diode number is 4262H
                                          Samsung 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U Chromebook Specification for Upgrade or Repair
                                          This specification for the Samsung 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U boardview and 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help...
                                          09-07-2024, 12:10 AM
                                        • x_orange90_x
                                          Samsung UN50KU6300F constant reboot, bad backlights?
                                          by x_orange90_x
                                          This TV is in a constant reboot where the screen very dimly lights up for about 2 seconds and says SMART TV. I checked the power supply and visually all components look good. I unplugged the main board to see if the backlights would come on but they do not. I also tried my LED tester on the backlight plug and didn't get anything. I know some Samsungs will not light off a single led is out regardless of using a tester, so I'm thinking they are bad. I found a whole set for about $25 which isn't bad, but before I buy them is like to know if they would indeed cause a constant reboot like this tv is...
                                          02-09-2024, 08:41 PM
                                          09-07-2024, 05:50 AM
                                        • Kaar3l
                                          Samsung QLED QE65Q7FNAT only standby light
                                          by Kaar3l
                                          TV: Samsung QLED QE65Q7FNAT
                                          PSU: BN4400940A
                                          MB: BN94-12832K
                                          I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                                          09-24-2024, 01:35 PM
                                        • brkie
                                          Samsung UE75TU6905 reboot loop
                                          by brkie
                                          I have a Samsung UE75TU6905 from 2021, with a maximum of 10 hours of usage as it has been used as a presentation TV in the office. It started rebooting, the picture disappears, the sound continues for 2-3 seconds, and then it restarts (Samsung logo with Tizen OS), after which it returns to the previous activity. I tried disconnecting HDMI, antenna, WiFi, and using different power outlets, and it seemed to improve (or so I thought). Before, it happened occasionally, but now it happens all the time, so the TV stays on for a maximum of 30 seconds.
                                          I read on Samsung's website (reviews)...
                                          09-04-2024, 01:45 AM
