Sceptre X322BV-HD burnt power supply
  • Mr Bill
    • Nov 2011
    • 648
    Smoke actually rolled out the top of the tv .
    The power board has a big burnt spot where the 2 plugs are for the ccfl bulbs. I've never encounter an issue like this before so where do i start? Is the board even repairable or should i just wait for a replacment to become available?
    Re: Sceptre X322BV-HD burnt power supply
    Some kind of carbon residue may have built up and created a high resistance short circuit which led to rapid heating of the track.
    Try cleaning the track, repairing it if necessary, then applying some kind of HV insulating silicone to it to prevent future arcing.
    • Mr Bill
      • Nov 2011
      • 648
      Tom, i cleaned the carbon area with alcohal but it pretty much still looks like picture 3. It doesn't look like there is a trace that goes between the 2 points but i haven't picked at it with a pen knife yet. The high voltage silicone, where would this be bought at? Digikey or is there a specific brand/type that works well?
        Ordinary insulating silicone will do. It looks like you should be able to test it without the silicone for now, then add the silicone to prevent a repeat of the problem.
        • Mr Bill
          • Nov 2011
          • 648
          Here is a picture after i scraped the area. Would this be good enough to give a try or should i clean it better?
          • Mr Bill
            • Nov 2011
            • 648
            Maybe there is a trace in there somewhere, it's reading 69.4 ohm. I just don't want to cook the board anymore than it already is.
              As you can see, they put the slots on the PCB to create air gap between the high voltage points, you need to competely cut out any carbonized section of the board out completely.
              • Mr Bill
                • Nov 2011
                • 648
                Bud,
                I drew a few cut lines. Would this work? or is there an easier way?
                  That will do, you can also cut the board by follow the tip where the cutout is already there and cut it through. Take the resistance reading and fill the gap with Silicone RTV. We want the gap between the two points.
                  • Mr Bill
                    • Nov 2011
                    • 648
                    Here is pic of the cut. I'm still getting the 69.4 ohm reading between points after i cut it.. Does this matter?
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      Paceworldwide on youtube has an excellent series of soldering videos. They are old style narration, which I love, but highly relevant.
                      I watched them sometime last year, but they have a whole series on rework and repair.
                      See
                      http://www.youtube.com/user/paceworldwide/videos?view=0
                      PS. Your multimeter needs an external cleaning!
                      --- begin sig file ---
                      --- end sig file ---
                        You may have burnt out winding on the secondary side, I would take that transformer out and measure the resistance and compare it to the un-burnt one.
                        • Mr Bill
                          • Nov 2011
                          • 648
                          I think i figured out where the 69.4 ohm reading was coming from. I put the board it and the backlights came on without any smoke or buzzing. Just need to apply some RTV silicone and close the tv up. Would the RTV silicone from an auto parts store work or should this be from an electronics outlet?
                          Retiredcaps,
                          what do you use to clean the meter? Alcohal and q-tips? I've had this meter for almost 12 years now and i've never even thought to clean it
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            I used this in my current ATX power supply
                            http://www.permatex.com/products/aut...ve_Sealant.htm
                            They do have a high temperature version in red I believe. I think it was $3.99 at Home Depot Canada.
                            Retiredcaps,
                            For the outer case I use gojo or fast orange (hand cleaner with pumice). The yellow Fluke cases that I buy used sometimes are covered with dirt, grease, etc. Dirty multimeters don't attract the same number of bidders or a high price -> perfect for me.
                            For the body, I just use a damp rag
                            Everyone knows that a clean multimeter gives more precise readings!
                              That Silicone RTV for making gasket is fine, I do not believe it contains any acid like the generic home Silicone sealant, I know the Silicone for electronics repair does not contain acid which is what I use at work on the PCB (it has to conform with UL) so it will not eat up the copper traces. So what did you find on the 68 Ohms reading? That is really low Ohm! Do you get the same reading on the other transformer?
                              http://www.hmcelectronics.com/produc...licones/RTV162
                              • Mr Bill
                                • Nov 2011
                                • 648
                                I'm Going to have to re-visit this old thread. I gave the tv to a friend for a real world daily use and it died after about a week. The tv turns on but no backlight, not even a brief flash. We did confirm the tv is displaying a picture by shining a flashlight throught the lcd and saw the menu. I took the back off and checked the voltages coming from the power supply.
                                5v - 5.21
                                12v - 12.35
                                24v - 24.02
                                DM - 2.285
                                BK - 3.109
                                384v at the large cap with the tv on. So the power supply portion seems to be functioning correctly. I've tested the mosfets on the top of the board and the few surface mount ones on the bottom and they all test in circuit good (not shorted). I checked the 2 ballast caps where the PSU originally arced and the meter reads OL which i believe is correct.
                                I'm hoping somone might see the layout of this board and shine some light on what drives the 2 connectors that go to the panel. The 24v by the way goes to the main board not the panel directly.
                                The pictures in post number 1 aren't the best. Let me know if you want some quarter shots of the board.
                                  We need to check the inverter section again, the power supply is putting out like it should. The inverter section uses the >300V for driving the inverter transformer.
                                  Brighter pictures of the top side of the board? Four 1/4 section pictures of the bottom side?
                                  • Mr Bill
                                    • Nov 2011
                                    • 648
                                    Sorry for the delay Bud, got the flu. Here are the pictures. I hope the resolution is good enough for troubleshooting. The bottom the board has a clear finish sprayed over it. Made taking a clear photo difficult with the flash.
                                      OK, I just download the pictures, let me trace things out.
                                      • selldoor
                                        Slow Learner
                                        • Dec 2010
                                        • 7870
                                        May just be the picture but U4 looks a bit singed?
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                          by sam_sam_sam
                                          07-01-2024, 06:34 AM
                                        • JimBanville
                                          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                          by JimBanville
                                          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                          Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                          I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                          09-13-2023, 07:21 AM
                                        • CMCM
                                          Russound CA4 Power Supply Repair
                                          by CMCM
                                          Hello Everybody,
                                          Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
                                          Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
                                          The outputs marked 12v and 20v are all measuring only 1v.
                                          The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
                                          The capacitors physically look clean (no bludgesor leaks) and...
                                          07-03-2025, 01:12 PM
