Digital AC100-300V BLUE LCD DISPLAY PANEL VOLT/AMP meter WITH SPLIT 0-100A CT
    • Jul 2011
    • 6057
    I have hacked this meter so that it can be with
    Variac 10A AC Power Auto Transformer 0-130 VAC w/ Meter,1000W Voltage Regulator
    ( I have seen on You Tube where people have put digital meters on a Variac but all the one I seen they have where the volt meter can not read the voltage below about 80 volts I did not mine to work this way )
    Which is something I going to buy soon
    How I figured out where the voltage input was I had decided to replace all the caps on the board top board with all the caps remove and high powered light it fairly easy to trace where the traces go
    So I traced wear all the input power went and found all you have to do is remove a surface mount diode ( M7 )
    and replace it with a 1N4007 and on the side of the diode that has the line is where you put the wire so you can measure the line voltage of the Variac out put
    • 31142
    Re: Digital AC100-300V BLUE LCD DISPLAY PANEL VOLT/AMP meter WITH SPLIT 0-100A CT
    that variac looks a hell of a lot better than the last set of foto's
    • redwire
      • Dec 2010
      • 3912
      Here is a better PCB pic (version with on-board CT) showing the voltage-sense rectifier diode.
      For my variac, I did the same but used the $1 mini-panel meters, the 22mm ones. It is easy to separate the power and voltage-sense.
        • Jul 2011
        • 6057
        I want to change the input voltage from 80 volts AC to 24 volts AC
        I know I have to change the input capacitor but to what value
        How do calculated this value
        Thanks to anyone that can help
        • redwire
          • Dec 2010
          • 3912
          What is the brown film capacitor's value?
          To go from 120VAC power to 24VAC, that is 1/5 so it would get upsized 5X. Assuming it's say 2.2uF 250VAC, to 10uF 100V.
          It's almost where you could just use a resistor dropper instead of a capacitive dropper. Short out that cap and replace the big 100R with say 270R 3W to get the same power supply current.
          But I'm not sure how current the panel meter uses, with backlight LED and LCD display+MCU. Guessing around 5V at 15mA.
            • 31142
            it would be better to use a rectifier and micro switching regulator for 24v
              • Jul 2011
              • 6057
              Powering from the rectifier at about 7 volts gives about 20 milliamperes
              So my guess is that it runs at five volts
                • 31142
                i already suspected that because it has a microcontroller.
                  • Jul 2011
                  • 6057
                  UpDate on running this meter module on 24 volts AC
                  The main capacitor was 330nf I replaced with a 1.5uf cap and now it will work down to 12 volts it might go lower than that but it might not read the voltage and current right
                  I did have to adjust the pot controls a little bit for it to read right it was reading a little bit high
                    • Jul 2011
                    • 6057
                    Your calculation 1/5 was right on
                    330nf I put in a 1.5uf
                      • Jul 2011
                      • 6057
                      UpDate
                      Did a burn in test over night and the meter module still working this morning
                      I now know that that this will work
                        • Jul 2011
                        • 6057
                        UpDate
                        This is with the volt meter module modified installed in the Variac 20 amp
                        as you can see it reads the voltage the same as the Radio Shack volt meter does
                        Now the voltage scale on Variac is way off it shows 105 volts which is better to show low than high
                        I am only going to use the scale for a ruff estimate of what voltage could be on the output side
                        Very pleased with the way it turned out
                        Here is the main ( but not the only) reason for buying this Variac is that sometimes I buy LED modules and do not have a power supply to power them
                        This brings me to this question
                        I would like to have a bridge rectifier with a capacitor and fuse
                        To have a dc power supply
                        What else should I use,do to make this setup as safe as possible
                        One note
                        With the control knob turn all the way to the right the voltage is 151 volts AC
                        One other question I have is what other uses does a Variac have please give examples
                          • 31142
                          one thing worth pointing out is the output voltage will probably change a bit with different loads.
                          so trust your meter and not any printed scale around the control knob.
                          • redwire
                            • Dec 2010
                            • 3912
                            You can add a rectifier/filter cap/bleeder resistor etc. and make an adjustable DC output- but it is dangerous.
                            A variac is an autotransformer, so it does not provide isolation from mains.
                            If line and neutral are flipped anywhere, the variac's (common) output would be hazardous live with respect to earth ground, even if set to zero volts output.
                            You would need an isolation transformer to ensure the variac's output is safe.
                              • Jul 2011
                              • 6057
                              Would this isolation transformer work for me
                              • redwire
                                • Dec 2010
                                • 3912
                                I think you could make an adjustable DC power supply with the variac using Triad N-51X looks good for a smaller isolation transformer, 0.3A output max. so a fuse for it would be good.
                                • japlytic
                                  • Oct 2005
                                  • 2086
                                  On my unit, I used a digital voltmeter display which has a minimum voltage of 60 VAC, but the display was just visible down to 30 VAC - this would be unreasonably low, since the connected appliance would not function at all!
