LG 60LN5400 Q409 burn
Re: 60LN5400 Q409 burn
The SMD Codebook
http://www.marsport.org.uk/smd/mainframe.htm
It shows Q409 maybe is this:
X7 BZX84-C47 Zet C SOT23 0.3W zener 47V±5%
X7 CMDZ5227B CSC I SOD323 250mW zener 5% 3.6V
Q407 shows is this MMBR901 SOT23 npn RF MRF901.
Service manual only found this 55LN5200UB, i cant see its bury....
Service manual I found it! i am so cheap don't want pay nothing...
http://service.minjja.lt/files/?id=5982
https://www.manualslib.com/manual/79...e.html?page=52
Q409 is AO3407A 30V P-Channel MOSFET:...........................
https://cdn.badcaps-static.com/pdfs/...fa1ec3aa2d.pdfLast edited by capwizard; 12-27-2016, 05:50 PM.Comment
by ttmi100xGreetings everyone,
I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
Upon closer inspection...6 Photos-
Channel: Troubleshooting Computer Displays
by howardc64Eventually discovered a burn mark near lower corner of LCD. Here is a summary
- Backlight on, no image
- Disconnect right buffer board (view from front), left side display comes on
- Masked off pin 7+8 (both ~12,5v on both left and right buffer board) from t-con to right buffer board (view from front) display works but have some lines
- Buffer board is pretty simple
07-11-2025, 04:04 PM -
by Tom41I have an AOC U27G3X 4K gaming monitor that I use both as a TV and for gaming on a Nintendo Switch 2 console. Recently, something very strange has been happening to it. After playing a game that has an on-screen timer for a few minutes, the last digit of the timer (the one rapidly flickering from 0 to 9) appears to burn in on the monitor. Going to a different source or power cycling the monitor does not help; there is a constant flickering area on the screen where that digit was.
It seems strange that only that digit would burn in, and NOT the other digits that are changing less frequently....-
10-23-2025, 04:33 AM -
by NevilletHi All,
I'm trying to repair a PCB that has some surface mount SOT23 devices that apear to be transistors but testing them on the board are giving confusing results.
Its named FS45 but I can't find a datasheet that seems correct.
The device is used in 10 places on the PCB. In 4 cases they appear to be controling triacs and the attached picture it shows it connected to a BT136 triac with the FS45 connected to the gate leg of the BT136.
Can anyone identify the device and suggest an alternative?
Many thanks.
PS: I have...5 Photos -
by mecmastHi,
I've searched the internet but couldn't flnd a replacement/substitute for this part.
It is marking as "2920N" SOT23-5 case.
I am looking for the "G2920T11U" 3.3v version.
Also uploading the datasheet.
Thank you all.... - Loading...
- No more items.
