Dell 5567 LA-D801P Rev 1.0 ( Working Bios + Me Clean )
  • ProSis
    • Jun 2017
    • 87
    • Turkey
    SR2ZU - MEC1440 - 216-0889018
    BAL20 LA-D801P Rev 1.0 ( A00 ) 2016-06-24
    Working Dump
  • kalilinux25
    • Mar 2018
    • 2093
    • ZAMBOANGA SIBUGAY
    Re: Dell 5567 LA-D801P Rev 1.0 ( Working Bios + Me Clean )
    Working Dump
    error when I try to import it
    • peste
      • Dec 2016
      • 13743
      • ROMANIA
      Working Dump
      post the bios here on the site ..
      • kalilinux25
        • Mar 2018
        • 2093
        • ZAMBOANGA SIBUGAY
        here it is sir
        • peste
          • Dec 2016
          • 13743
          • ROMANIA
          Originally posted by kalilinux25
          here it is sir
          try..
          • kalilinux25
            • Mar 2018
            • 2093
            • ZAMBOANGA SIBUGAY
            try..
            as always keeps working thank you sir
            • rudelito
              • Jun 2019
              • 14
              • Phillipines
              is this tested
              • sleandru
                • Mar 2020
                • 10
                • Brasil
                In this case, the notebook did not turn on with any other BIOS, only with the original, it has stable consumption at the source but without starting, help me clean ME from this bios BAL20 LA-D801P REV: 1.0
                (A00)
                service tag: 789MSL2
                  • 22108
                  (A00)
                  You must post the laptop service tag
                  • sleandru
                    • Mar 2020
                    • 10
                    • Brasil
                    Thanks for the tip sir, I updated my post
                    • Markus1741
                      • Sep 2020
                      • 965
                      • N/A
                      (A00)
                      Hello try this me clean file from your original file ....
                      Good luck ...
                      • kinoxa
                        • Dec 2011
                        • 26
                        • Kyiv
                        Dell Inspiron 5567 (LA-D801P) turns on, and back off after a few seconds
                        TAG: 7HM8J22
                        I tried BIOS from the branch, it doesn't work
                        • zenius
                          by zenius
                          12-08-2024, 06:13 AM
                        • TyMercer
                          Can I flash a working BIOS from one computer to another of the same make, model, etc?
                          by TyMercer
                          Apologies if this is the wrong forum, but I'm not looking for a specific BIOS file, I'm trying to understand how one makes a clean BIOS file. So here's the background. I have 2 HP EliteDesk 800 g2 mini 35w pcs. One is working fine; the other doesn't have display out or working USB's nor does it have any flashing error lights. The CPU does get worm enough to cause the fan to spin up, so I think it's posting, but I just don't know. I had it working at one point but trouble started when I tried to put in a drive caddy that had a cooling fan on it. I thought it would be compatible but wasn't...
                          11-13-2025, 09:39 PM
                        • Akhlz001
                          Dell Pro 13 Plus PB13250 Bios Unlock
                          by Akhlz001
                          Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...
                          09-20-2025, 07:15 PM
                        • Sathsul
                          Dell Latitude 5431 issues with dumping bios
                          by Sathsul
                          So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
                          The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
                          However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
                          10-28-2025, 07:49 AM
                        • gizaha
                          Dell Latitude 5580 possible bios corruption
                          by gizaha
                          Dell latitude 5580, motherboard cdp 80 la-e151p
                          3 amber 3 white blinks. Dell website sais it's problem "bios recovery" and suggested solution "recovery image not found"
                          (from here https://www.dell.com/support/manuals...e7a&lang=en-us)
                          I try plugging charger while pressing ctrl+esc, machine turns on, nothing and after 20 seconds it gives 3 amber 3 white blinks again.
                          Since ssd is replaced and had clean install windows, i've...
                          02-13-2024, 07:18 AM
