Dell 5567 LA-D801P Rev 1.0 ( Working Bios + Me Clean )
Re: Dell 5567 LA-D801P Rev 1.0 ( Working Bios + Me Clean )
error when I try to import it -
post the bios here on the site ..Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
here it is sirAttached Filesif you find these attachements useful please consider making a small donation to the site
try..Attached Filesif you find these attachements useful please consider making a small donation to the site
In this case, the notebook did not turn on with any other BIOS, only with the original, it has stable consumption at the source but without starting, help me clean ME from this bios BAL20 LA-D801P REV: 1.0
(A00)
service tag: 789MSL2Attached Filesif you find these attachements useful please consider making a small donation to the site
You must post the laptop service tag
.Comment
Hello try this me clean file from your original file ....
Good luck ...Attached Filesif you find these attachements useful please consider making a small donation to the site
Dell Inspiron 5567 (LA-D801P) turns on, and back off after a few seconds
TAG: 7HM8J22
I tried BIOS from the branch, it doesn't workAttached Filesif you find these attachements useful please consider making a small donation to the site
Channel: BIOS Requests ONLY!
by TyMercerApologies if this is the wrong forum, but I'm not looking for a specific BIOS file, I'm trying to understand how one makes a clean BIOS file. So here's the background. I have 2 HP EliteDesk 800 g2 mini 35w pcs. One is working fine; the other doesn't have display out or working USB's nor does it have any flashing error lights. The CPU does get worm enough to cause the fan to spin up, so I think it's posting, but I just don't know. I had it working at one point but trouble started when I tried to put in a drive caddy that had a cooling fan on it. I thought it would be compatible but wasn't...
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
by SathsulSo, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...-
by gizahaDell latitude 5580, motherboard cdp 80 la-e151p
Since ssd is replaced and had clean install windows, i've... - Loading...
