Lg 50pk590
  • diif
    • Feb 2014
    • 6978
    • England
    Lg 50pk590
    Hello, i have an LG Plasma here with an EAY60968801 PSU.
    I have read the threads with the same PSU and there is a repair kit i can buy, before i purchase i was hoping someone would confirm, or help me confirm this should sort the problem.
    The standby light comes on when i plug in the TV. When i press the power button on the remote i hear two clicks and the screen flashes white for less than a second then goes off. There is another click and the Tv goes back to standby.
    Thanks.
  • sordids999
    • May 2013
    • 2160
    • uk
    Re: Lg 50pk590
    firstly you can check various supply voltages such as Vs, Va, VSC, Ve
    • diif
      • Feb 2014
      • 6978
      • England
      Re: Lg 50pk590
      Thanks sordids999
      VS=201.4v
      VA=60.9v
      M5V=5.07v
      These seem to be spot on.
      I've just read on the Coppell website, that if all of the cables are disconnected apart from the AC then it is plugged in, a click followed by one or more within a second indicate a faulty PSU.
      I got 3 clicks, so i guess it is faulty.
      • PowerAmpFreak
        • 982
        • Sweden
        Re: Lg 50pk590
        Check the 3 power resistors in the top right corner of the PSU.
        • Hamie
          • Apr 2014
          • 1383
          Re: Lg 50pk590
          Does the vs and va stay on with the y-sus disconnected?
          • Hamie
            • Apr 2014
            • 1383
            Re: Lg 50pk590
            A good way to test the PSB is to buy a 200w service light bulb (maplins sell them) and solder it to the vs test point and ground.
            Furthermore if the 5watt resistors test good ive not heard many other types of failure for this PSB. Personally I've never seen the diode or ic go bad.
            • diif
              • Feb 2014
              • 6978
              • England
              Re: Lg 50pk590
              Thanks guys, I've just measured the three resistors and get 10.5, 10.4 and 10.2 ohms.
              Is the y-sus the board on the left ? this is my first plasma i have worked on.
              • Hamie
                • Apr 2014
                • 1383
                Re: Lg 50pk590
                I take it those measurements are in circuit?
                • Hamie
                  • Apr 2014
                  • 1383
                  Re: Lg 50pk590
                  With the Ysus disconnected does the vs and va stay on in the power supply?
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    Re: Lg 50pk590
                    Yes i measured in circuit. I then removed one from the board and got the same.
                    So i connect the Zsus but leave the Ysus disconnected, then check the VS VA ?
                    • Hamie
                      • Apr 2014
                      • 1383
                      Re: Lg 50pk590
                      Yes remove the ysus, plug the x back in and power on.
                      • diif
                        • Feb 2014
                        • 6978
                        • England
                        Re: Lg 50pk590
                        Thanks Hamie, i am a little confused now. I have identified the Ysus and Zsus, which is the x ?
                        • Hamie
                          • Apr 2014
                          • 1383
                          Re: Lg 50pk590
                          Sorry z is the x.
                          • diif
                            • Feb 2014
                            • 6978
                            • England
                            Re: Lg 50pk590
                            Thanks Hamie, yes VS and VA still present with just the Zsus connected.
                            • Hamie
                              • Apr 2014
                              • 1383
                              Re: Lg 50pk590
                              Ok finally disconnect the buffers from the ysus and power on.
                              • diif
                                • Feb 2014
                                • 6978
                                • England
                                Re: Lg 50pk590
                                Thanks, I appreciate your patience Hamie, buffers ? the big long board with the ribbon cables ?
                                Zsus still connected or just the Ysus with buffers disconnected ?
                                • Hamie
                                  • Apr 2014
                                  • 1383
                                  Re: Lg 50pk590
                                  Yip everything now connected apart form the buffer boards that connect to the ysus.
                                  • diif
                                    • Feb 2014
                                    • 6978
                                    • England
                                    Re: Lg 50pk590
                                    Cheers, VS and VA still present.
                                    • Hamie
                                      • Apr 2014
                                      • 1383
                                      Re: Lg 50pk590
                                      Ok check vsc, -vy, and zbais
                                      They should match your panel sticker.
                                      Like this.
                                      Vsc, and -vy are located on the ysus.
                                      Zbais on the zsus.
                                      -vy is measured sometimes across a resistor, but is marked with + and -
                                      All in dc volts.
                                      • diif
                                        • Feb 2014
                                        • 6978
                                        • England
                                        Re: Lg 50pk590
                                        With or without the buffer connected ?
                                        i did see those on my sticker and wondered where the points were.
                                        • Noah Glasse
                                          LG 50PK590 - three clicks and steady red light, won't turn on.
                                          by Noah Glasse
                                          I've got a LG 50PK590 plasma TV which upon plugging in will click three times and the red LED in the corner will come on and stay on, the TV however doesn't come on (no humming, sound, video, etc.) and using the touch controls or the remote does nothing. On exceptionally odd occasions, the TV will come on and work normally when plugged in and will last about 5 minutes before going back to off and unresponsive.
                                          I've got the back off of it and none of the caps stand out as visibly buggered, I've also tested the three resistors in the corner of the power board which...
                                          02-24-2025, 07:23 AM
                                        • tvguy12012012120
                                          by tvguy12012012120
                                          02-07-2025, 05:13 PM
                                        • fharris1977
                                          Vizio D50u-D1 Dead Set No Standby
                                          by fharris1977
                                          Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                          12-28-2023, 10:25 AM
                                        • Crystaleyes
                                          Samsung BN44-00259A standby question
                                          by Crystaleyes
                                          Hi all.
                                          I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
                                          SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
                                          Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
                                          The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
                                          08-11-2023, 05:15 AM
                                        • goldbird78
                                          LG 50PK550 EAX61392501/10 EAY60968801 clicks and shuts off immediately
                                          by goldbird78
                                          Hi All, I have an LG 50PK550 with the EAX61392501/10 EAY60968801 power supply board. When I turn it on it clicks and shuts off immediately, I have unpluged the power wires to to Zsus and Ysus board and it does the same thing. I have read up and replaced IC301 & d304 and checked the R927 R929 and all 3 fuses on the board and all appear ok. Still does the same, shuts off immediately with or without the z & ysus board hooked up. Any help would be appreciated. Thx
                                          02-17-2021, 08:45 PM
