Lg 50pk590
  • Hamie
    • Apr 2014
    • 1383
    Re: Lg 50pk590
    Without the buffer connected, then if they all match.
    • diif
      • Feb 2014
      • 6978
      • England
      Re: Lg 50pk590
      -vy = -185.3v
      vsc = 151.1v
      Zbias = 109.8v
      Similar results with the buffer connected.
      • Hamie
        • Apr 2014
        • 1383
        Re: Lg 50pk590
        Are all voltages permanent or is the tv going back to standby?
        • Hamie
          • Apr 2014
          • 1383
          Re: Lg 50pk590
          Do those voltages match your panel sticker?
          • diif
            • Feb 2014
            • 6978
            • England
            Re: Lg 50pk590
            I plug the tv in and press the power button on the remote, i hear two clicks and the voltages are there all the time. Yes they match the sticker.
            • Hamie
              • Apr 2014
              • 1383
              Re: Lg 50pk590
              if all the voltages are there all the time the tv can't be going back to standby?
              • diif
                • Feb 2014
                • 6978
                • England
                #27
                Re: Lg 50pk590
                Yes, you are correct, two clicks, the standby light goes off and i hear a buzzing sound.
                • Hamie
                  • Apr 2014
                  • 1383
                  Re: Lg 50pk590
                  Ok is the panel glowing?
                  Is there an LED light on the small control board?
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    #29
                    Re: Lg 50pk590
                    The panel glows for a split second when i take it out of standby but then goes back to a dark screen.
                    The LED is flashing, long flash then short, then a pause and repeat.
                    • Hamie
                      • Apr 2014
                      • 1383
                      Re: Lg 50pk590
                      Ok disconnect the LVDS cable from the main board and control board.
                      Then locate 2 holes marked ext auto gen on the control board an put a wire jumper across them.
                      • diif
                        • Feb 2014
                        • 6978
                        • England
                        #31
                        Re: Lg 50pk590
                        The LVDS cable being the silver one going left to right ?
                        I am struggling to find the 2 holes you mention.
                        • Hamie
                          • Apr 2014
                          • 1383
                          Re: Lg 50pk590
                          Unfortunately I can't find any service manual for this set.
                          If you plug in a DVD player via scart, do you get sound?
                          • diif
                            • Feb 2014
                            • 6978
                            • England
                            #33
                            Re: Lg 50pk590
                            I tried with a signal from my cable box and got no sound.
                            • Hamie
                              • Apr 2014
                              • 1383
                              Re: Lg 50pk590
                              I still find it strange that the panel doesn't glow considering the y-sus is performing normally.
                              Are you sure the panel isn't slightly lit up? Darken the room.
                              Imo if you are sure that you are on a cable station and you aren't getting sound then it's probably a mainboard fault. But that still doesn't explain why the ysus isn't lighting up the panel.
                              • diif
                                • Feb 2014
                                • 6978
                                • England
                                #35
                                Re: Lg 50pk590
                                Cheers Hamie, I shall try tonight when its dark as I don't have thick curtains.
                                If I find it is still slightly lit, what will that indicate ?
                                • sordids999
                                  • May 2013
                                  • 2161
                                  • uk
                                  #36
                                  Re: Lg 50pk590
                                  Found this so might be a idea to check
                                  One typical failure symptom of a failed power supply board is a TV that has a standby power, but upon attempting to turn TV on it clicks on and quickly back off, never actually turning on and staying on.
                                  An open fuse F302 or shorted diode D304 (located on the right side of heat sink HS2 toward the middle of the board)
                                  At the time of this listing's creation the kit contained 1 fuse (F302), 1 diode (D304) , two power resistors (R927, R929) and the IC301 voltage regulator IC.
                                  Contents may change as we gain more experience and see other commonly failed components and this listing may not necessarily be timely updated
                                  • diif
                                    • Feb 2014
                                    • 6978
                                    • England
                                    #37
                                    Re: Lg 50pk590
                                    Now it is dark, i can see a feint glow from the screen.
                                    I have just checked the diode and fuse and they are ok, so i've ordered an ic and i shall see what happens.
                                    • diif
                                      • Feb 2014
                                      • 6978
                                      • England
                                      #38
                                      Re: Lg 50pk590
                                      I have replaced the ic this morning, however i still get two clicks, the panel is white for half a second then dims.
                                      The LED on the control board has a different flash pattern now, 3 short followed by a long one.
                                      Whilst i am looking for some documentation to identify this flash code, can anyone shed any light as to what it indicates ?
                                      • Hamie
                                        • Apr 2014
                                        • 1383
                                        Re: Lg 50pk590
                                        this is normal for the tv.
                                        its always done this but you probably just havnt noticed it.
                                        what do you mean by you replaced an IC?
                                        • diif
                                          • Feb 2014
                                          • 6978
                                          • England
                                          #40
                                          Re: Lg 50pk590
                                          I bought a replacement part IC301. It was the only part in the repair kits i hadn't tested as i was unsure how.
                                          • Noah Glasse
                                            LG 50PK590 - three clicks and steady red light, won't turn on.
                                            by Noah Glasse
                                            I've got a LG 50PK590 plasma TV which upon plugging in will click three times and the red LED in the corner will come on and stay on, the TV however doesn't come on (no humming, sound, video, etc.) and using the touch controls or the remote does nothing. On exceptionally odd occasions, the TV will come on and work normally when plugged in and will last about 5 minutes before going back to off and unresponsive.
                                            I've got the back off of it and none of the caps stand out as visibly buggered, I've also tested the three resistors in the corner of the power board which...
                                            02-24-2025, 07:23 AM
                                          • tvguy12012012120
                                            by tvguy12012012120
                                            02-07-2025, 05:13 PM
                                          • fharris1977
                                            Vizio D50u-D1 Dead Set No Standby
                                            by fharris1977
                                            Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                            12-28-2023, 10:25 AM
                                          • Crystaleyes
                                            Samsung BN44-00259A standby question
                                            by Crystaleyes
                                            Hi all.
                                            I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
                                            SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
                                            Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
                                            The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
                                            08-11-2023, 05:15 AM
                                          • goldbird78
                                            LG 50PK550 EAX61392501/10 EAY60968801 clicks and shuts off immediately
                                            by goldbird78
                                            Hi All, I have an LG 50PK550 with the EAX61392501/10 EAY60968801 power supply board. When I turn it on it clicks and shuts off immediately, I have unpluged the power wires to to Zsus and Ysus board and it does the same thing. I have read up and replaced IC301 & d304 and checked the R927 R929 and all 3 fuses on the board and all appear ok. Still does the same, shuts off immediately with or without the z & ysus board hooked up. Any help would be appreciated. Thx
                                            02-17-2021, 08:45 PM
