Sony KDL 32L4000
  • cguzek
    • Jan 2010
    • 57
    Sony KDL 32L4000
    Seen some old threads on this TV. Heard of problems with both the t-con board and the panel itself due to shotty tabs connecting to panels. Most seem to be fixed by either replacing t-con board or a temporary fix by pushing down tabs with some sort of insulation causing better bond. My lcd did not respond to tabs being pushed down.
    Other difference between most pictures and videos I have seen on this LCD is that only the bottom 3/4 of my screen has the vertical lines and ghost images.
    Could it be t-con, main board, or do you think it is the panel. If consensus is that the panel is bad I don't want to waste any money on trying a new board that will do nothing. Thanks.
    Re: Sony KDL 32L4000
    It's a bad panel, it looks like a tab bond issue to me though.
      I second that, Tom.
      http://s807.photobucket.com/albums/y...t=DSC01537.jpg
      • cguzek
        • Jan 2010
        • 57
        okay, so even though pressure on tabs does nothing, its still tab connection, huh. that sucks. Is there any way to fix that with heat gun, or anything else?
        Should the power supply, mainboard, inverter, and tcon boards still be good to try and get rid of on ebay?
          When I went to try and fix a 40" it was very sensitive as to the exact angle and pressure, otherwise it would not work.
          • awyatt2
            • Feb 2012
            • 407
            • america
            i used a pin on one of these the video was on utube that explaind the fix. it was slow to respond and ghosting to a point in one area, lower left screen and a darker pic on the lower half or the screen.
            • Daren87
              Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
              by Daren87
              I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
              08-13-2023, 03:25 PM
            • iglitare
              Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
              by iglitare
              i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
              Backlight seems to work, Sound (Setup menu after reset) works.
              If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
              Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
              With my small knowledge i would think at least the cables are good.
              Can this happen because of a bad tcon board?
              Or is it always a bad/shorted...
              09-04-2025, 07:13 AM
            • kca
              by kca
              Hello all ~
              08-31-2025, 06:38 AM
            • thelankanguy
              Sony KD-55X9000F TCON Issue
              by thelankanguy
              The TV shows a black screen with no image.
              TCON ribbon connectors were disconnected individually for image and there was no half image even.
              Later both ribbons were disconnected and TCON voltages were tested.
              12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
              There is also a short to ground in this circled inductor.
              Is this a TCON issue or something else ?...
              12-13-2024, 12:27 AM
            • bbrain
              Sony KD-55AG9 TCON?
              by bbrain
              I have this problem with my Sony 55' AG9.
              It flashes 4x.
              I have found the service manual, and seems it is the TCON.
              Before I buy a TCON can someone check the vid?
              Thanks in advance!...
              09-19-2024, 10:50 AM
