Samsung NP300 Bios
  • cyberhack
    • Feb 2013
    • 466
    • Uk
    Samsung NP300 Bios
    Was updating bios failed now no boot up
    has any one got the bios bin file please model no NP300E7A-A08UK
  • techman1025
    • Jun 2014
    • 497
    Re: Samsung NP300 Bios
    Hi
    Try this if works i will need to rebuild the Me region for you .
    techman1025
    • dycc
      Vision
      • Nov 2011
      • 625
      • Côte d'Ivoire
      Give code
      • cyberhack
        • Feb 2013
        • 466
        • Uk
        I will get code as soon as I get back home thanks
        • cyberhack
          • Feb 2013
          • 466
          • Uk
          the code was 07QA BA-09243B 0621
          • cyberhack
            • Feb 2013
            • 466
            • Uk
            The above files did not work
            • dycc
              Vision
              • Nov 2011
              • 625
              • Côte d'Ivoire
              Try this
              • bjhawfam
                • Dec 2014
                • 144
                Would anyone have the dump or bin file for a np300e5c-a09us scala3-15-17crv BA41-01979A.
                There is absolutely no other way for me to repair this bios besides a programmer. Any and all help would be appreciated and thank you in advance.
                • khaahk
                  • Dec 2013
                  • 810
                  • Estonia
                  Use search:
                  https://www.badcaps.net/forum/showthread.php?t=37276
                  • bjhawfam
                    • Dec 2014
                    • 144
                    Hello khaahk,
                    Yes I did however these are the incorrect bios files. The bios I need will end in RAP, more specifically P02RAP.bin .... I do however appreciate the response.
                    • khaahk
                      • Dec 2013
                      • 810
                      • Estonia
                      Care to explain? What difference does it make how the file is named?
                      • ala_borbe
                        aka Donald
                        • 1625
                        • Malta
                        same laptop different platform, different motherboard
                        Im Back... sort of...
                        • bjhawfam
                          • Dec 2014
                          • 144
                          ala_borbe is correct, they are not the same, I have tried them to to ensure (praying) but no dice. The good news is, I did find the bios.bin file, the bad news= the error report from the programmer claims the file is to long! I can't figure out why. I have flashed the exact chip with an 8mb bios file with no error. This bios file reads 8mb however I get the error message "file is too long"? Is there something included in the file that I'm missing that can be removed? If so, it's extremely small. HELPERS? anyone? Thanks in advance.
                          • ala_borbe
                            aka Donald
                            • 1625
                            • Malta
                            if you can post you backup file, dump from your epprom, not working one and that "too long" file i might be able to help
                            and can you tell bios version previous to the update?
                            • bjhawfam
                              • Dec 2014
                              • 144
                              Thanks,
                              I don't have a backup file, I'm actually comparing the bios file to a random 8mb bios file. That's actually why I needed the bios, without it the laptop is useless. The previous owner decided he knew best, he and a cohort decided to wipe the chip after a bad bios flash. Now I'm trying to get the Laptop bios loaded back in. So I tried several Samsung bios.bin files that were 8mb with no error, this one is 8mb and returns an error. I'm guessing that there is a tiny useless file somewhere that can be deleted. I can provide the file, however, I cannot provide a comparable backup file.
                              • bjhawfam
                                • Dec 2014
                                • 144
                                I loaded both, a random Samsung 8mb bios driver and the Samsung 8mb bios driver I needed side by side into a hex editor. Running them in comparable mode does nothing except show they are similar at the starting hex and ending hex. That was to be expected, why lie I was hoping something would magically stand out. Maybe a red highlighted section within the bios that said "delete me I don't care".....
                                • ala_borbe
                                  aka Donald
                                  • 1625
                                  • Malta
                                  im afraid that without eprom backup it will be hard to rebuild eeprom
                                  i got samsung bios update file, if i had dump maybe i could rebuild it
                                  what are the markings on eeprom??? how big is eeprom???
                                  if its 4mb (16mbit) maybe this file would work but i doubt it
                                  • bjhawfam
                                    • Dec 2014
                                    • 144
                                    MX25L6405D if my eyesight is correct....
                                    • bjhawfam
                                      • Dec 2014
                                      • 144
                                      This is the file that claims to be to long.
                                      • bjhawfam
                                        • Dec 2014
                                        • 144
                                        Whooooo hoooooo I got it,,,, Thanks so much for the help...
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • Citymin
                                          NT955XED (Samsung Galaxy Book2 Pro - 15.6) BIOS dump file Request
                                          by Citymin
                                          My Samsung Galaxy Book 2 Pro 15.6-inch laptop has no display and won't boot.
                                          The charging red LED lights up, but the charging screen doesn't show any indication.
                                          When I press the power button, the blue LED cycles on and off three times, then the screen doesn't turn on, and the device won't boot.
                                          (I've tried removing the battery and resetting the device, but the issue persists.)
                                          NoteBook Model name : Samsung NT955XED-KK51G(Galaxy book2 pro, i5-1240p, 15.6inch AMOLED)
                                          PCB model name : Venus2-15-5G(REV1.2), Venus2-15 ADL NPC
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
                                        • Vesko356
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                          09-07-2024, 05:50 AM
                                        • TJ65
                                          Samsung Galaxy Tabpro S BIOS and Micom Version doesn't match
                                          by TJ65
                                          i made out of two broken Samsung Galaxy Tabpro S one that works partially.
                                          The one Mainboard had a broken screen output but working hdmi (usb c adapter) output and the other didnt start at all.
                                          I switch the bios chips and now the tablet starts but very very slow and it takes some trys to get it starting.
                                          The problem is, that the micom Version doesn't match with the bios version, see picture.
                                          How can i update the Micom Version? The Samsung bios update wont work.
                                          With https://github.com/tavinus/SamsungBIOSTools i could extract the newest bios update...
                                          01-09-2025, 01:35 PM
