DELL 2405fpw
  • Mirage00
    • Jun 2012
    • 58
    • Usa
    DELL 2405fpw
    My Dell 2405fpw stopped displaying anything on the screen. The power goes on and all controls work (front lit green buttons all work). The backlight is working when connected to a computer. I run my finger against the screen and see the white light. The Dell self test menu does not display nor does the On Screen Menu. I have taken off the back cover and can't see any obvious issues with CAPS so I will need to start testing. Does this sound like a LOGIC board issue? Where do I start testing ? Thanks in advance, this is a great forum!!!!
    Re: DELL 2405fpw
    It sounds like the T-CON board (Board is under the metal shield) is not getting the voltage from the main board, or it has blown fuse on the T-CON. You need to check that board.
    • Mirage00
      • Jun 2012
      • 58
      • Usa
      Re: DELL 2405fpw
      I just lifted the metal shield enough to test the fuse with the DMM and it was fine. What do I test next?
      Also, here are the pics from the panel board
      • retiredcaps
        • Apr 2010
        • 9271
        Re: DELL 2405fpw
        What is the DC voltage on each side of the fuse with respect to ground? You should have 2 readings.
        --- begin sig file ---
        --- end sig file ---
        • Mirage00
          • Jun 2012
          • 58
          • Usa
          Re: DELL 2405fpw
          Not exactly sure how to do that. I have the multimeter set to DCV at 200m and when i touch a ground point (screw hole) on the card and each end of the fuse I get .5 on both sides. Did I do it correctly? BTW this is my DMM I am using
          • retiredcaps
            • Apr 2010
            • 9271
            Re: DELL 2405fpw
            1) You get one retiredcaps' bonus point for a picture of your multimeter. I have never seen the Harbour Freight special in yellow, just red.
            2) You want it set on 20V DC because the voltages on the t-con are either typically 5V or 12V DC. However, since you are gett 0.5 on each side, it sounds like there is no power being sent. If the t-con fuse is good, then that suggests something might be wrong on the logic board.
            3) There are 4 voltage regulators that I can see. I circled them in red.
            4) Put your multimeter on 20V DC. Put your black probe on a ground screw on the logic board. Leave it there for all readings. This is your ground.
            5) Put your red probe on each pin including the "cut" pins, but ignore the "fat tab". The "fat tab" is north. Number the pins left to right.
            6) List all your readings like so for each regulator.
            Q1
            part number 1084-33
            pin 1 = 0.0V
            pin 2 = 3.3V
            pin 3 = 5.0V
            • retiredcaps
              • Apr 2010
              • 9271
              Re: DELL 2405fpw
              Did you use continuty to test the fuse or ohms? A good fuse should read less than 1.0 ohms.
              • Mirage00
                • Jun 2012
                • 58
                • Usa
                Re: DELL 2405fpw
                To test the fuse I used ohms. Set the DMM to 200 and it read .2
                • Mirage00
                  • Jun 2012
                  • 58
                  • Usa
                  Re: DELL 2405fpw
                  Also, when I set the DMM to 20DC V to test both sides of the fuse, I don't get any reading it stays at 0.00 This is why I kept lowering the DCV to the lowest setting of 200m. I switched the ground hole I used to the double screw hole on the left of the board and it read 1.0 on each side of the fuse. If I left the probes on it would slowly drop .1 or .2
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    Re: DELL 2405fpw
                    That definitely is a good fuse.
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      Re: DELL 2405fpw
                      That means no power is going to the t-con board, but we know for sure your fuse is good.
                      List your voltage regulator readings with part numbers and we can see if one of them are bad.
                        Re: DELL 2405fpw
                        That means the main board is not sending out the 5v or the 12v to the T-CON, this is done by switched transistor (this transistor is turn on when the monitor detects the video signal) some where on the main board.
                        • Mirage00
                          • Jun 2012
                          • 58
                          • Usa
                          Re: DELL 2405fpw
                          Ok. I had to leave the DMM on 200m for the voltage readings.
                          part number F5305S
                          pin 1 = 1.5V
                          pin 2 = 0.0V
                          pin 3 = 1.5V
                          part number FR9024N
                          pin 1 = 1.5V
                          pin 2 = 0.0V
                          pin 3 = 1.5V
                          part number H183
                          pin 1 = 0.0V
                          pin 2 = 0.0V
                          pin 3 = 0.0V
                          part number H185
                          pin 1 = 0.0V
                          pin 2 = 0.0V
                          pin 3 = 0.0V
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            Re: DELL 2405fpw
                            part number F5305S
                            pin 1 = 1.5V
                            pin 2 = 0.0V
                            pin 3 = 1.5V
                            part number FR9024N
                            pin 1 = 1.5V
                            pin 2 = 0.0V
                            pin 3 = 1.5V
                            Please redo the two above with your multimeter on 20V (twenty). Do you have power on and lcd plugged in?
                            • Mirage00
                              • Jun 2012
                              • 58
                              • Usa
                              Re: DELL 2405fpw
                              Some sort of signal is being detected because when the backlight turns of after 30-40 seconds, if I toggle the monitor output on my laptop that is connected to the 2405fpw the backlight turns back on again. So it senses some sort of signal from the laptop. Also, I mentioned in the first post the OSM does not display.
                              • Mirage00
                                • Jun 2012
                                • 58
                                • Usa
                                Re: DELL 2405fpw
                                No the lcd is unplugged. Does it need to be on? If so, can I plug it in and turn it on without the tcon board connected (I took it out for pictures and testing)
                                • retiredcaps
                                  • Apr 2010
                                  • 9271
                                  Re: DELL 2405fpw
                                  If the IC has more than one line on its part number, please list them all. For example H183 has 950T65.
                                    Re: DELL 2405fpw
                                    I know that the monitor detects the signal from the PC OK, but the main board is not turning on this transistor to supply the voltage to the T-CON board, that what we will have to trace out the B+ line from the T-CON connector to see where it goes to. There may be another fuse on the main board also, I cannot find any service manual for this monitor yet.
                                    It will have to be troubleshoot down to the component level at this point.
                                    Well, after reading post 16, I may have to disregard my troubleshooting method until we get more info.
                                    "No the lcd is unplugged"
                                    • retiredcaps
                                      • Apr 2010
                                      • 9271
                                      Re: DELL 2405fpw
                                      Yes, power has to be on for all voltage measurements. Let's start again with the voltage measurements on t-con and then the 4 voltage regulators (with all the part numbers on the IC).
                                        Re: DELL 2405fpw
                                        And hook it to running PC also, otherwise it will go into standby mode.
                                          LCD LED TV Service Menu Codes
                                          ALL LCD LED TV SERVICE MENU CODES
                                          Service Menu Code with Board Name
                                          China Universal Board / Jumper Board Service Menu Code
                                          Changhong Ruba Service Menu Code
                                          Ecostar LED TV Service Menu Code
                                          Orient LED TV Service Menu Code
                                          Haier LED TV Service Menu Code
                                          TCL LED TV Service Menu Code
                                          Samsung LED TV Service Menu Code
                                          LG LED TV Service Menu Code
                                          Videocon LED TV Service Menu Code
                                          Supra LED TV Service Menu Code
                                          Toshiba LED TV Service Menu Code
                                          Symphony LED TV Service Menu Code
                                          Veste/ LED TV Service Menu Code...
                                          10-31-2024, 03:58 AM
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • Aezakmi
                                          Dell 2408 - No OSD or input menu
                                          by Aezakmi
                                          A few days ago my Dell 2408 has stopped to working without any noticeable sign.
                                          It can be power on, power light stays green, backlight works but there is no OSD, menu input, Dell logo etc. It happens if there is some input source connected or not.
                                          I disassembled the case but I didn't see any failures on the board. The only element that looked suspicious was L6561 - there was some brown dirt under it. So I replaced this IC but it changed nothing.
                                          What else should I checked or is this repair even possible/worthwhile?
                                          Thank you for your c...
                                          01-29-2024, 04:12 AM
                                        • Akhlz001
                                          Dell Pro 13 Plus PB13250 Bios Unlock
                                          by Akhlz001
                                          Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...
                                          Yesterday, 07:15 PM
                                        • master3112
                                          Dell Inspiron 5590 Board 18778-1 no charging, charging not possible
                                          by master3112
                                          I would like to share my experience about charging issues with Dell power supplies with the tech community. I am working on a Dell Inspiron 5590, Mainboard 18778-1 with charging problems. The device can be switched on and works so far, only the message appears at startup:
                                          Alert! The AC power adapter wattage and Type cannot be determined. The battery may not change. The System will adjust the performace to match the power available.
                                          The power supply unit is not recognized in the Bios and the charging process is set to "idle". I use original Dell battery, type...
                                          07-29-2025, 01:55 PM
