SATA spinning HDD's Breeding at Night....
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    Once upon a time, I'd have killed for a stash like this....but today, they're pretty worthless.
    These plastic bins contain 92 spinners ranging from 500gb to 4tb...
    These two cardboard boxes are packed as full as they can get with another 90 spinners from ~73gb to 320gb.
    This bin contains ~88 that I was contractually obligated to DOD wipe and also physically destroy....
    I don't count my stash of SCSI, SAS, and IDE; as those are kept for other things. Everything spinning SATA under 320gb I am probably going to just give away. They all passed wiping without errors, but I'm not going to waste time checking the SMART data on each one. The ones that failed wiping were destroyed as well. As time goes on, the 500's will also be disappeared as well...
    So, is it just me? ...or is everyone's stash of spinners doing this too?
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
  • dmill89
    • Dec 2011
    • 2534
    Re: SATA spinning HDD's Breeding at Night....
    I know the feeling, I have a similar infestation, albeit on a bit smaller scale. Aside from some large storage drives (the 4TB storage drive in my main desktop and a pair of 6TB drives in RAID 1 in my NAS), I haven't put a SATA spinning HDD in anything in years (though I recently bought a NOS 40GB PATA drive to replace the failing one in my Windows 98 laptop), and the <1 TB drives are pretty useless given how cheap SSDs have gotten.
    I'm even starting to run into a similar situation with older/lower-capacity (<=256 GB) SSDs, though these at least have a decent chance opt being repurposed (most likely replacing a spinner HDD in an old laptop, though the low-capacity NVMe drives are more difficult to find a use for, since they aren't compatible with older systems and the low capacity isn't much use in newer ones which generally have a drive that size or larger already):
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16959
      I have a decent stash of 120~250gb SSD's, although they always tend to get used....like you said, upgrades for older laptops. I also have some 30gb & 60gb SSD's, those are great for HTPC's where the data isn't stored locally (all it needs to hold is the OS) and some little ITX systems that are used for running powerpoint presentations for a local advertiser.... He hasn't even filled one of the 30's up yet!!
      Team : 49813
      Join in!!
      Team Stats
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8716
        Wish I had a way to get them to multiply as long as they're >= 500GB ... though fortunately I have many more SATA disks >=500GB than <500GB. Vast majority of my < 500GB disks are PATA.
        Mainly using them for data backup. RAID has been dealing okay with their size and potential failure limitations.
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16959
          Everything in the plastic bins are 500gb+. Anything smaller are in the cardboard boxes, waiting for the right sucker....err, I mean person to lug 'em off!! a 500gb spinner in a Linux system is actually ok performance-wise....not SSD snappy of course, but for a cheap usable system, its fine. The 1tb+ drives are good for backups; like you said...and RAID's....but I still have way too many of them!
          Team : 49813
          Join in!!
          Team Stats
          • lti
            • May 2011
            • 2558
            If drives multiplied for me, they would probably be dead 2.5" drives. I still only have two "good" drives that aren't in a computer, and one of them took a while to spin up the last time I used it. It would be nice to get a good low-capacity 2.5" IDE drive for one of my old laptops that wouldn't POST with a 60GB drive (it locked up while detecting drives).
            What does breed at night is Pentium MMX 200s. I keep running into them in piles of old computer parts, and I never take them. One is enough, especially since the best motherboard I have for that type of CPU is dead (I might try to fix it some day when I decide to get a spare ATX power supply).
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8716
              Technically I think I can still use any size drive, was doing some accounting of how much data/storage I was using not counting redundancy, but seems not that much - only a few (i.e. single digits) TB and most of it is on one machine - my PVR. Big files are only a few GB so even smallish disks are okay, can still work with 250 GB disks easily, anything smaller probably needs to be volume managed or RAIDed.
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16959
                For 2.5" IDE situations, do yourself a favor and get these: https://www.ebay.com/itm/151519954907
                Stick a Mini PCIe SSD in it and run with it. 64gb and 128gb are cheap and size-specific to hardware of the era. XP and Win2k scream with these. I gave up ages ago trying to find 2.5" IDE spinners that were acutally still good. I have an old Dell laptop with WinXP on it, that has serial & parallel ports. Great for console programming uses....
                Team : 49813
                Join in!!
                Team Stats
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8716
                  Next problem is the 8G or 32G limit that old firmware chokes on, which apparently Iti is alluding to. Not sure if the adapters have a way to lie about capacity, just to get past BIOS.
                  I too ended up seeing a pile of dead 2.5" PATA drives which is unfortunate, currently have a pile of 3 in my dead disk pile.
                  • Topcat
                    The Boss Stooge
                    • Oct 2003
                    • 16959
                    You can get the mini PCIe cards as small as 2gb....they're alittle harder to find though. I did a NT system with one (2gb)...and I've never seen NT boot so quickly!
                    Team : 49813
                    Join in!!
                    Team Stats
                    • dragos2009
                      • Mar 2013
                      • 110
                      for the ssd's buy external caddys and use them as hella fast usb thumb drives
                      • lti
                        • May 2011
                        • 2558
                        I have the M.2 version in another laptop. The JMicron chips don't work well with VIA chipsets (they're really slow), but it would probably work in the laptop with the capacity limit (it apparently just uses a 440BX chipset) if I get a small enough SSD.
                        That one doesn't have any way to limit capacity.
                        • Uranium-235
                          Comrade Glimmer
                          • Aug 2007
                          • 5046
                          • US
                          I have a buttload but goddamn nothing like you. Larger ones like 4TB can be used for server arrays but something tells me you already have larger SAS 15k ones in there
                          Mine are spread over my room and workroom. Lot of laptop ones
                          You can partially thank windows 10 for this. It's I/O is so heavy using it with a spinner is basically impractical.
                          • Topcat
                            The Boss Stooge
                            • Oct 2003
                            • 16959
                            I also have a bunch of Dell Optiplex 330's shelved in the garage I haven't even gone through yet. They've been here quite a while, but there's nothing top secret on them...so I just didn't get in a rush to strip 'em. Most are XP/Vista born and upgraded to 7 & 10. Odds are they're packing even more sub-250gb slowpokes....but I agree, Win10 and up definitely one of the root causes. Win7 ran nice on a spinner but ran fantastic on a SSD...but wasn't required for a decent running/responsive system....this can even be said for 8/8.1...but 10? SSD is a requirement for it to not be absolutely agonizing slow.
                            Team : 49813
                            Join in!!
                            Team Stats
                            • CapLeaker
                              Leaking Member
                              • Dec 2014
                              • 8354
                              I have also accumulated a lot of regular HDDs and laptop HDDs. Unfortunately Zero used SSDs. Oh well… the only disks spinning are in my server. That’s it. I recently picked up a new 500gb ssd for CAD$40. I should have gotten a bunch, but then I would be stuck upgrading computers for a month… suffer colleges at work… suffer! As long a my shit works, I am fine…
                              • trepachka
                                Yoga 9 14ITL only left fan spinning
                                by trepachka
                                Hi, I have this laptop that had multiple issues: a bad USB-C chip, a bad power regulator, a bad ALC3306 chip. The latter stumped me because I never had an audio chip cause any issues. Yet, it was heating up to 80c.
                                After all of these got replaced, the laptop is working again but only the left fan is spinning upon heat buildup. The right one is not spinning ever. I had a spare heatsink/fan assembly which I installed but the problem is not going away. So, the fan itself is ok. I checked pins on the fan connector and it does get 5v and 3.3v.
                                I don't think it's the thermal...
                                11-07-2023, 03:09 AM
                              • mondogen
                                Lenovo G50-70 power on but no display and fan not spinning
                                by mondogen
                                Hi everybody, I'm a beginner and I've got a Lenovo G50-70 with NM-A271 rev 1.0 mobo.
                                It powers on BUT:
                                * no display
                                * fan not spinning
                                * power led is on and battery led too (if inserted)
                                * no power consumption without battery, with battery 0.27A
                                * no shorted coil to ground
                                * +3VALW, +5VALW and +3VALW_PCH are present
                                * 3.3V on bios pin 1 is present
                                * 1.9V on PL302 coil
                                * I tried to flash bios with external programmer (CH341A) e nothing changed.
                                Any suggestions?...
                                11-11-2024, 11:04 AM
                              • JakubM
                                Bosch serie 6 E:60 -9 and drum not spinning
                                by JakubM
                                Hello everyone, I'm troubleshooting our malfunctioning Bosch serie 6 washing machine and can't find many answers online (or ones that I can make sense of). At first it started showing error E:60 -9 and would not start a program. After several restarts it's no longer showing the error codes, but when I start any program (drum cleaning for example) it fills the water in but the drum doesn't start spinning. I couldn't find any physical obstruction, but turning the drum by hand I feel resistance. I tried opening it up, trying to inspect the motor brushes. This model either has a different motor that...
                                11-09-2024, 06:02 AM
                              • zaler808
                                Macbook Pro 15" Late 2013 A1398 Turn off randomly but after workload it shows black screen with fans spinning
                                by zaler808
                                Hi guys, this my first post but i want to be brief about it, i recently got a MBP L2013, the problem was that after some use the macbook shutted down randomly, at first i suspected to be the battery, and after connecting it with the charger i noticed that i didn“t shut, but after an hour or so it shutdown, after that i started searching a solution to my problem, but my brother tried to help me to find the problem and it that process to replicate the problem he reproduced a 4k video in multiple tabs and not much time after the macbook shutdown to never power again, what i noticed was that the...
                                05-23-2024, 05:17 PM
                              • Slicybtw
                                Laptop Showing no display only fan spinning
                                by Slicybtw
                                My laptop (Asus k43s) was working for a day after I cleaned its fans but then it stopped showing display (blank screen) and only would show display on a different monitor but even after booting up it doesn't let me login to my account (I use Fedora Workstation)
                                I removed all screws, it showed display but turns off after 5 seconds
                                Now it stopped working completely only fan spinning...
                                04-20-2024, 01:37 AM
