Adding an AGP Connector
+ More Options
Posts
  • bigbeark
    • Jan 2010
    • 661
    I have an IBM motherboard, socket 478 HT, which has onboard video, but also the 124-hole socket where one could install an actual AGP connector.
    I actually have a second near-identical board that has the header installed.
    I can buy the AGP connector from Digi-Key for $7.
    I would use the pin method and clear all 124 holes, then solder the new header in place.
    Aside from being a fair amount of work and not really worth it, are there any other possible impediments to doing this job?
    I have begun recapping the board, if it's successful, I was considering adding the connector.
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Adding an AGP Connector
    it will likely not work. there are likely missing smd components needed to run the board. not to mention it would be a huge PITA to install.
    sigpic
    (Insert witty quote here)
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16956
      Compare the boards for SMT components that would power the AGP. Yes, it would be a fun thing to solder in.....but not that hard. If there are a lot of empty solder pads around the AGP that would normally power it and bridge the AGP to the NB chip, then soldering the slot in place would not work.
      KC8 has done this with ISA slots and they worked, so if the components that would power and pass data to the AGP slot are present, it would probably work.
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • 370forlife
        Large Marge
        • Aug 2008
        • 3112
        Usually the manufacturer won't just leave off the AGP slot to save money, they will also remove other parts to save that little bit more. You can go ahead and try it you are ok with perhaps blowing $7+shipping for the sake of just seeing if it will work.
        I would test it with some crappy agp card, as you don't know what may happen.
        • severach
          • Aug 2007
          • 1055
          Commercial castoff motherboards from Dell and IBM are dirt cheap. Picking a random IBM 478 board I see a IBM NetVista 8303 with AGP connector already installed for $20 free shipping on eBay. There's a bunch more for $30 or less.
          sig files are for morons
          • corrize
            Best way to solder LVDS connector for beginner (and qfn) ?
            by corrize
            Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
            I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
            I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
            See the test :
            https://youtu.be/bNAzC-EvqHs?t=1767
            With hot air from bellow the board, that's...
            03-09-2023, 02:57 AM
          • stefanpng
            HP EliteDesk 800 G1 SFF solder an extra fan header?
            by stefanpng
            So the HP EliteDesk 800 G1 SFF has only one fan header on the whole motherboard, a 4 pin cpu. There is a second chassis fan header, but it is not installed, there are just 4 bare through holes and some silkscreen.
            Other models like the tower version of this computer have the chassis fan header installed, so I was wondering if it was possible to solder in a new 4 pin header.
            There is some surrounding circuitry, and I think it is identical to this schematic. The CPU fan header circuitry matches exactly except for one filter(?) cap, and the chassis...
            07-13-2022, 05:54 PM
          • howardc64
            by howardc64
            Problem
            08-04-2024, 10:36 PM
          • acedogblast
            by acedogblast
            11-02-2024, 05:13 PM
          • michhak
            Toshiba Satellite M50-A keyboard connector on LA-A481P motherboard
            by michhak
            Hi guys,
            i have a damaged keyboard connector on my older Toshiba Satellite M50-A laptop. I know there is LA-A481P motherboard. In attachment pictures there is a real looking connector and i also found a schematic to the connector. But i need help with finding a real electronic part to replace the damaged connector. e.g. on aliexpress (or different page).
            It is 34pin connector and the length from pin n.1 to pin n.34 is 26mm. So it means a pitch length is 0.764 mm. I have seen connectors with 0.5mm , 0.7mm , 0.8mm and 1mm pitch length. But not with 0.75. Is it some special custom connector...
            11-17-2021, 05:45 AM
