Cleaning edge connectors
  • pentium
    • Mar 2006
    • 2778
    I'm in ownership os a Lisa 2 now and of course it had the battery spooge all over the board and backplane.
    I have neutralized it and cleaned it as best I can but the edge connectors are still giving me trouble.
    The gold fingers on the cards were easy enough to clean with an eraser but the actual sockets themselves are being a pain. how would I clean those?
    The should eb nice and gold but they are instead blue, white, and grungy. It's causing all sorts of diagnostics faults and possibly causing my video not to work.
    Find Nedry!
    Check the Vending machines!!
    <----Computer says I need more beer.
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Cleaning edge connectors
    EWWWW!
    those are beyond saving even with deoxit.
    once the plating is gone like that its game over.
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      makes me grateful for my mac se with a loose hd cable.
      sigpic
      (Insert witty quote here)
      • RJARRRPCGP
        • Jul 2004
        • 6304
        Looks like major corrosion! (Or algae or mold O_O)
        ASRock B550 PG Velocita
        Ryzen 9 "Vermeer" 5900X
        Arc A770 16 GB
        eVGA Supernova G3 750W
        Alienware AW3423DWF OLED
        • pentium
          • Mar 2006
          • 2778
          from what I see, it's only the tops of the connectors that are realy bad. Further in the fact that somethign was plugged into them saved the contacts a bit.
          I am optimistic I'll ever find replacements.
          Find Nedry!
          • Krankshaft
            • Jan 2007
            • 2328
            Weird double post.
            • Krankshaft
              • Jan 2007
              • 2328
              Hopefully you can find replacements.
              It's real fun replacing those connectors I had to replace the cartridge connector on a S-NES once and the board was double sided which meant through hole vias. A nice deep tunnel for solder to stay trapped.
              The best you can do in the mean time is lightly scrape each contact with a tiny flathead screwdriver to hopefully get down to some type of clean metal.
              Whether the plating is gone or not you don't want it to keep eating at the metal.
              The only tool I've ever seen for cleaning connectors like this are the ones that used to be sold for cartridge type video game consoles. It was a piece of plastic that was inserted and removed from the slot to clean it. But those weren't designed for major cleaning like this.
              • Toasty
                • Jul 2007
                • 4171
                Need pin count and spacing. Seems DigiKey has a large selection.
                Use crocus cloth to clean and polish those contacts. Flush them out afterward with alcohol.
                Get the rest of that green/blue corrosion off all those other components too.
                It'd be nice to see it resurrected.
                Good Luck!
                veritas odium parit
                • Krankshaft
                  • Jan 2007
                  • 2328
                  A little Deoxit gold wouldn't hurt either for a bit of protection since the plating will probably be gone and they will be more prone to oxidation.
                    • 31036
                    i see this every week - fucking ni-cads!
                    firstl;y, i dont think you neutralised it fully.
                    if you did then there wouldnt be any green left.
                    put it on a tray and throw vinegar all over it - dont water down.
                    then rub it in with a paintbrush.
                    all the green should desolve and release hydrogen bubbles.
                    the edge connectors and any chipsockets will be done.
                    i always replace any damaged sockets, switches etc.
                    remove the wrecked parts before you vinegar - that way it gets to the area's of the pcb that are normally covered.
                    • pentium
                      • Mar 2006
                      • 2778
                      the battery acid has already been neutralized so relax.
                      Cleaning was finished today and it looks a lot better. I'll hopefully be able to test it tomorrow.
                      Find Nedry!
                        • 31036
                        i am relaxed, but normally the green & white residue disolves.
                        • kc8adu
                          • Nov 2003
                          • 8832
                          • U.S.A!
                          its not acid.hence the tip to use vineagar.
                          • Wizard
                            • Mar 2008
                            • 2296
                            People who said vinegar is correct procedure to neutralize the alkaline-based NiCd battery residue.
                            Look into wiki to learn more about NiCd and NiMh make up.
                            These connectors are still available from big electronic supplier and it is standard spacing. I'll look up and get info. Have to replace them.
                            Cheers, Wizard
                              • 31036
                              vinegar for ni-cad and alkaline,
                              isopropanol for lithium,
                              not had to deal with a leaked ni-mh yet, but i'd probably use isopropanol to be safe.
                              i'v seen a ni-mh eat through a fiberglass pcb once - so i'm not sure about the chemistry!
                              • NxB
                                • Feb 2009
                                • 1595
                                I had a whole voice mail system done like this. A leak dripped on it for 6 months. I was able to save the whole thing with just alcohol and some soldering.
                                • pentium
                                  • Mar 2006
                                  • 2778
                                  yea, reflowing joints is really annoying. a lot of the solder has oxidized to a point where it is really hard to head up and reflow.
                                  Find Nedry!
                                  • digge
                                    • Apr 2006
                                    • 296
                                    Not sure this will help you any, but what i use to reach inside those connectors is regular printing paper, folded over to a snug fit and then add your cleaning solution suitable for the job and stick it in and out. (hope you meant those ISA looking connectors cause that's what I'm talking about)
                                    Saved a whole bunch of Nintendo (8bit) connectors that way which are known to be some oddball alloy that always corrode like hell, at least the European version.
                                    You might end up taking of the plating like the others said, but if no new connectors is to be found there isn't much choice i guess. Just clean regularly.
                                    • pentium
                                      • Mar 2006
                                      • 2778
                                      I managed to clean up the card cage connectors so now that whoke kit works but I'm unsure about the interconnect lines. I'll double check their cleanliness again after I double check if my analog board is faulty as I know everything works but something between the card cage gold fingers and the tube is bad (either the cable or the analog board).
                                      Find Nedry!
                                      • howardc64
                                        by howardc64
                                        Problem
                                        08-04-2024, 10:36 PM
                                        LENOVO ThinkCentre Edge 71 SFF ThinkCentre Edge G630 Specification for Upgrade or Repair
                                        This specification for the LENOVO ThinkCentre Edge 71 SFF can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkCentre Edge 71 SFF boardview and ThinkCentre Edge 71 SFF schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                        09-12-2024, 03:36 PM
                                        LENOVO ThinkCentre Edge 72 ThinkCentre Edge G850 Specification for Upgrade or Repair
                                        This specification for the LENOVO ThinkCentre Edge 72 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkCentre Edge 72 boardview and ThinkCentre Edge 72 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                        LENOVO ThinkCentre Edge 71 ThinkCentre Edge i5-2400S Specification for Upgrade or Repair
                                        This specification for the LENOVO ThinkCentre Edge 71 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkCentre Edge 71 boardview and ThinkCentre Edge 71 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
