Re: Gateway 80486-DX2/50 Revival
Meh, not a museum piece unless it's complete with all the original hardware....strangely enough the old 'Holstein cow' boxes are more sought-after collectables than what was in them....but no worries either way.
A gateway I was given a few years ago; complete enough to keep around:
https://www.badcaps.net/forum/showpo...postcount=5102
I've got a DX4 system I need to get back to one of these days.
That socket next to the CPU might be for a Weitek FPU. I don't know the best place to find information about these old motherboards.
It seems weird that the I/O card would have its own battery, but I would guess that it was replaced at some point with whatever was available.
If you get around to cleaning the corrosion off that motherboard and removing the model rocket igniters, you can still buy new ISA slots. I don't think it will last too long with that kind of corrosion, but at least it works for now. That's an improvement over some of the leaking battery repairs I've seen.
https://www.digikey.com/en/products/...WN-S420/927281Last edited by lti; 09-27-2022, 09:14 PM.Leave a comment:
re: power plugs. If the reds were together, +5 was grounded via the chassis, if metallic motherboard mounting was intact. Some of those old ones used nylon standoffs & fiber washers, so it wouldn't always trip the power supply- in which case "motherboard dead." And even if the short on +5 shunted that rail, the other voltages could still damage stuff during the brief period they "twitch."
re: HDDs- Maxtor 7xxxAT series were OK, and period correct.
My first real PC had a 7245AT- came to 230ish MB after formatting.
Great spinup sound, too!
The sound that meant "we're firing up the PC & doing serious work."
And they had "artwork" on the PCB; each capacity had its own "feature," IIRC.
ST3660A was OK too, had one of those alongside the Maxtor.
Was interesting setting the jumpers- these weren't simply "master-slave," etc.
You should be able to find charts to jumper them for operation on the same cable.Leave a comment:
I have an old gateway p5/90 case that looks very similar to this 486dx2-50...full size AT case, board is long gone. It has a K6-233 (with 256MB SDRAM on a 430TX...) board in it now.
Alas no nostalgic value to me, it's still a bit too fast to run my old EPROM burner software...
"Black to black, back to back" ... if they didn't cut out the right keys on the board and plugs.Leave a comment:
Indeed.... Choppy in 320x200 without acceleration. This board looks to have no PCI slots, so no means to add even a voodoo1 card to speed things up a little.... This one would likely be more of a Doom machine....
If this turns into a failure, I have dibs on the case!! I've got a dual Pentium classic that would fit gloriously in that!
Sounds about right... feels like it weighs ~50ish. Would probably weigh 90 fully loaded.
And off the subject- Duke3d over quake any day.
The former has aged like fine wine, esp with the mods & "HRP" stuff, while the latter has aged like milk...
DN still has staying power, not so much because of the "mutants," but its take on "futuristic dystopias," explored more in DNMP.
The "gearbox" disaster of ~10 years ago doesn't exist to us nukem2/duke3d/DNMP diehards...
Should probably do that, but I don't have the time, nor would I want to risk trashing an otherwise good board with a mis-slip. This might be one for TC, but I've not got the $$ to make that happen at the moment. Right now, the system is gonna sit dormant for at least a couple of weeks while I grab a sub-528MB hard disk for it from an eBay auction. (Gotta wait on the auction to end and then for shipping.)Leave a comment:
Those old Gateways... it probably weighs 90 pounds!
Now an easy way to remember that two-plug power connector:
Black to black, you're OK, Jack...
Red to white, what a fright!
) something from early pentium stuff.
VLB would be it, though DX2s always ran the busses at half the internal clock; a straight DX50 would be 50 internal and external.
Beware of those orange/yellow "balloon" tantalums. I've had them short on old boards that were "dormant" for a number of years.
Just replace with modern low-esr electros, like Pana FM or FR or Nichicon HD (or similar).Leave a comment:
If this turns into a failure, I have dibs on the case!! I've got a dual Pentium classic that would fit gloriously in that!Leave a comment:
it should play Quake - what more do you need!Leave a comment:
So here's the background on this system:
It was built on June 13, 1993 and likely delivered to its owner sometime in the not-too-distant future. The original owner said that he used it for his business and that it ran either Windows for Workgroups 3.11 or Windows NT 3.1 until he retired it in late-1999 or early-2000. It has 8MB of RAM, an ATi video card (unknown amount of VRAM), and a Sound Blaster Vibra/16 card. It had a network card installed in it, but it wasn't playing nice with DOS and the drivers for it are long-gone (it's a clone of a clone card), so I pulled it. It also had a 120MB IDE hard disk that was pulled and dismantled after the system was retired. It also has a CD-ROM drive. It may have had a 5.25" floppy drive. If it did, it was removed a long time ago and I haven't been able to find it.
Up until early this month, the system had sat dormant and had not seen power for at least 22 years. I pulled it out of storage, disconnected the power supply from everything, and dry-fired it with good results.
I then reconnected the power supply and fired the system up for the first time in more than 2 decades.
First sign of life!
Unfortunately, it also had one of those Varta 3.6V poison pills of doom that had died decades ago (the system had an old Energizer external battery pack installed that had also died long ago) and it had begun to leak. Thankfully, the damage was not fatal to the motherboard, and the Energizer pack had remained fully intact. And yes, I have long since removed both batteries from the system.
A quick butt shot. All of the expansion cards got shifted down by one because the topmost ISA slot is damaged. The Sound Blaster and network card aren't installed as I just needed the bare minimum to get it to pass POST. Multi-I/O card on top, video card on bottom.
Because the original multi-I/O card was dead (battery damage), I pulled one from another system (a cheap-and-nasty 286 clone from circa-1990), as well as a floppy drive that worked for a bit and then stopped reading diskettes. Here's a front shot with the second floppy drive installed at the top.
Now for some open case shots.
System serial number.
And now for a motherboard shot.
More to come later!Leave a comment:
hmm...technically speaking a 512MB CF card would be sufficient. Then I need to get win98 or was it win95 back on this machine...Leave a comment:
Yeah I also have a 2GB PCMCIA Type II HDD, likewise does not detect properly.
Last drives that actually worked were Type III PCMCIA HDDs.Leave a comment:
been there - try a different cd-card.
some only id as "removeable media" and not "fixed-disk"
but only if the bios is not so old that it only offers a few fixed geometries for the drive!Leave a comment:
Need a hard disk for my 486DX4/75 laptop... silly pcmcia hdd, it did not like the PCMCIA-CF adapter with a 2G CF card...Leave a comment:
[placeholder post, details to come later]Tags: None
I am really needing Schematics for the motherboard on my Gateway laptop model GWTN-156-7BL
I attached a pic of motherboard info
Channel: Schematic Requests ONLY!
04-25-2025, 07:01 AM -
by Dan JohnGreetings everyone,
I have a Gateway P5WS0/NV57H58u laptop (P5WEO LA-6901P REV:2.0). The client said the battery was not charging. Upon checking the laptop,
1) On pressing the power button, the (power button) light turns on and stays on.
2) There is no boot, or anything on the screen.
3) The fan starts and stops a few times, then it stops completely.
4) The light on the power button remains on.
5) Battery not charging (original issue).
The original problem was that the battery was not charging, but the laptop still worked. My belief...5 Photos -
by aes1111Hello everyone, I have a laptop Gateway GWTN156-12BL, (XA133P rev 2.0) There was a crashed BIOS, I was able to find one for the GWTN156-12BK, and it rebooted. Can anyone share a BIOS dump for this model?
S/N 2GWTN15612BL2J21J008090...-
Channel: BIOS Requests ONLY!
Gateway ID49C04u ID49C11u Laptop Schematic...
Channel: Schematics and Boardviews
11-01-2024, 06:46 AM -
Gateway NV53 Series Laptop Schematic
Wistron SJV50-TR 09228-1 48.4FM01.011 Rev 1M...-
11-01-2024, 02:54 AM -
- Loading...
