i had to blow some dust off the board and heatsinks with the datavac as i didnt clean it up before putting it in storage. after finishing assembly of all the components, i powered on the system and noticed there wasnt any sound from the rear onboard audio jacks. oh no! not again... i once bought the same board locally with dead onboard audio that i had to return to the shop. this time i had the same problem. on the realtek hd sound effect manager program, on the audio i/o analog back panel jack detection tab, it couldnt sense any of the jacks being plugged in. none of the 6 rear jacks worked (no audio totally) and it couldnt sense anything being plugged in.
surfing around the internet, it seems im not the only one with this problem. it seems dead onboard sound and lan is a common fault on these gigabyte boards. grrr!
the next day, i decided to bust out the syba cmi8738 sound card i bought years ago with my first pc back in 2002 cause i was an audiophool back then that believed the myth that onboard sound sucks. well, onboard sound has come a long way since 2002 when i first built my first pc! however, i found that the 2002 cmi8738 didnt sound as good as the 2008 realtek alc 889a. the cmi8738 can only do 16bit/48khz with the dac while the realtek alc 889a can do 24bit/192khz.
the cmi8738 also sounded soft and i had to crank up the volume. after searching this forum, i saw a post by bigbeark who said that if a sound card doesnt sound good and the volume isnt as loud or its losing its loudness, it means the audio caps on the sound card are failing. yea, before putting the syba cmi8738 in, i saw it had 4 jackcon junk caps but two united chemicon caps. not sure which audio channel the ucc caps were on.
i decided to search through the internet for a replacement sound card. i had my eye set on the creative x-fi and audigy 2 cards for use on winxp and win98se respectively but after reading lots of driver nightmare horror stories on vogons and other sites as well as the fact that creative used junk caps on their sound cards. jamicon seems to be creative's fav cap on their sound cards and i've read online reviews of some people saying their creative card died due to bad caps. considering that the creative cards have at least 20 caps on them, a full recap is much too tiring work esp. since the 5-6mm audio caps are soo much smaller that the 8-10mm caps on mobos, i decided i just dont have the dexterity to do a full recap of a creative sound card.
next, i tried searching for creative competitor cards but the competition like the auzentech prelude, aureal vortex 2, diamond mx300, asus xonar series etc. are either unobtanium or too expensive on junkbay for my tastes. but while searching the forum, i accidentally came across an unusual thread of someone trying to hotwire their mobo onboard front panel header. so that gave me the idea of trying to connect a casing front panel audio jack header to the mobo front panel audio jack header. i also had to rtfm because i had read to watch out for what type of header u are plugging it into because the ac'97 header pinout is different from the intel hda azalia header pinout even though the connector is the same. the gigabyte mobo manual says their intel hda azalia header is backwards compatible to ac'97 but u must disable front panel jack detection in the audio connector settings.
so the next day, i tried it. i always remember to unplug the power cord first before tinkering unlike uranium-235. because the computer was under the table, i had to shine a usb torchlight to make sure the connector was lined up in the header properly and gigabyte decided to put the header right up against the rear panel audio jacks grrr! so i fired up the system, made sure the right inputs and outputs were unmuted, made sure front panel jack detection was already disabled then retasked the green front panel jack to line out and the pink front panel jack to line in. then i put on some skyrim music and the dtv set top box audio output into the mic input front panel pink jack and then the moment of truth! i plugged the speaker audio jack into the front panel green jack and i had my ears blasted with some good skyrim music. hooray it works! getting my ears blasted with some skyrim hd audio was a good thing also to boot, so no worries about my hearing. hahaha! oh and the mic jack also works in receiving the dtv set top box audio. x2
so the realtek hd audio sounded so much better than the cmi8738 audio indeed! so now this leads me to believe the audio chip isnt focked. just the rear panel jack detection switches are farked. i believe the jack detection is needed to turn off the audio signal to unused audio connectors to prevent signal reflection and echoing to preserve the high signal integrity and snr of hd audio, so then this adds on a new layer of problems. if the rear panel jack detection switches are farked, this then makes the onboard sound useless from just a minor fault.
so now i wanna ask if there is a way to trick the sound chip into thinking something is plugged into the jack bypassing the jack detect switches by hotwiring it or something? is it also possible to desolder the rear panel audio io jacks and replace it with a new one? i have another scrap ep35-ds3r that has either bad bga on the northbridge or lga775 socket. using momaka's hammerblow punch fix on the northbridge, i was able to get the board to post but as soon as i take my hand off, the board hangs instantly, so that board is an ideal candidate to pilfer the 6 jack hd audio rear io panel from. any suggestions on a more permanent repair for the hd audio rear panel jack set would be welcome.
im also wondering if blowing too much air at the mobo can cause esd dmg to the board and fry the audio chip partially or the jack detect switches? i know planes and helicopters have a grounding cable or the landing gear is slightly conductive to ground the plane on landing because the air friction of flying through the air causes electrostatic charge to build up on the plane.
P.S. i know i ramble on too much like momaka too. hahahaha! thanks for reading my grandfather's story post.
i also have another mobo with problematic onboard sound. the rear green line out jack only has sound on one channel, the right channel. there is only muffled nearly inaudible sound coming from the left channel but i think that is for another post which i will type later on in this thread when i get down to it using the same fix mentioned above with the front panel header bypassing the rear jacks.
