Caps in my computer
+ More Options
Posts
  • japlytic
    • Oct 2005
    • 2086
    Caps in my computer
    About two weeks ago, I decided to check the electrolytics in my system.
    * An Asus A9600XT video card with Sanyo electrolytics. It once gave a false core voltage reading, and is now fixed - perhaps from reseating the card?
    * An AVerMedia satellite tuner with CapXon electrolytics which were still good, used in the DC-DC step-up converter for the LNB voltages.
    * A Twinhan digital TV card with "REC" brand capacitors (most likely to be general purpose, but were not causing any trouble at all.
    * On the P4P800 Deluxe board, there were Nippon Chemi-Con capacitors near the CPU, with a few OST units, and a few GSC units (Fortunately not used near the CPU, but were used for bypassing, and probably used for audio as well).
    The power supply (LC-B400ATX) is mentioned elsewhere.
    How good are the capacitors in your computer?
  • Chris1992
    • Apr 2005
    • 561
    Re: Caps in my computer
    My system:
    GeForce FX5200: Sanyo lytics, with one Skywell 510uF 4v.
    Dell Dimension 8300 board: Rubycon, Nichicon, Chemicon, with a few Fujitsu RE.
    Creative emu10k1: small G-Luxon.
    Systems I'm responsible for:
    4x HP Brio PC uATX: Chemicon and some other brand I don't remember.
    2x Asus P4B533: Chemicon and Rubycon, with some OST.
    The great capacitor showdown!
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16956
      OST's are crap, period. Shame on Asus for using them. I have a an Asus P4C800 (I think thats it) sitting at the shop packed with bad OST's.
      My personal system:
      Supermicro X5DAL-TG2 - All Sanyo/Nippon caps!
      ATI 9800 AIW Retail - I never really looked at it, but the original ATI retails are well built.
      Zippy Double redundant 800W PSU - Never had it apart, so I dont know. I'll make a note of it next time I dust out the system. Zippy makes a kick ass PSU, so they can't be too bad.
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • Newbie2
        • Sep 2005
        • 885
        L&C LC-B400ATX? Those are bad 400W power supplies! Look at the very low-quality internals of one:
        The capacitors in my system? Here they are:
        PCCHIPS M955G Motherboard: All caps are made by OST, still not one bad!
        Enermax 300W PSU: All caps are made by PCE-TUR, still not one bad!
        XFX FX 5500 Video Card: One Sanyo OS-CON, rest Evercon caps, still not one bad!
        5-Port USB 2.0 PCI Card: All caps are generic, still not one bad!
        My gaming PC:
        AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
        ASUS M4A77TD AMD 770 AM3 Motherboard
        PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
        G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
        TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
        WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
        ASUS Xonar DG 5.1 Channel PCI sound card
        Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
        Antec Three Hundred Mid-Tower Case
        Microsoft Windows 10 Pro 64-bit
        Microsoft Windows 7 Ultimate SP1 64-bit
        • Chris1992
          • Apr 2005
          • 561
          Newbie2, can you post some pics of PCE-TUR caps? We don't have any on the forum IIRC.
          • yanz
            • Nov 2004
            • 910
            PCE-TUR?
            i remember saw it on a monstrous PCp&C psu. i'll dig for some pics.
            days are so short when you actually do something..
            • yanz
              • Nov 2004
              • 910
              here it is..
              a user (Electron Chaser) on ocforums has modified this big wtx psu into atx psu..
              full story: http://www.ocforums.com/showthread.php?t=347137
              the caps: http://www.ocforums.com/showpost.php...1&postcount=96
              perhaps 10000uF is more than enough
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                looks like jpcon.
                • Chris1992
                  • Apr 2005
                  • 561
                  looks like the P is a J and P stuck together.
                  • Newbie2
                    • Sep 2005
                    • 885
                    I now have two guys who use crappy PCE-TUR capacitors, Enermax and PC Power & Cooling! I have saw some PCE-TUR caps in a Bestec PSU, so that makes three!
                    My gaming PC:
                    • Rainbow
                      • Aug 2005
                      • 1371
                      I've checked caps in my PC today:
                      Asus P2B board - Rubycon and Sanyo
                      PowerColor AR2L Radeon 9100 - Panasonic through-hole and unknown SMD caps
                      DTK PTP-3007 PSU - CapXon (the big ones), G-Luxon (outpout filtering) and those (J)PCE-TUR (some of the other) - no problems with any of them - I like these PSUs as the construction is good and fan quiet
                      (anyone seen bad (J)PCE-TUR cap?)
                      • Spacedye69
                        • Nov 2005
                        • 698
                        • US
                        Compaq Asus Scket 462 mobo OST
                        MS6191 slot a Rubycon
                        EP8KTA3 GSC 6 are bulging-flaky mobo
                        A&V333 liitle OST and big Nichicon HM(M) in vrm- no post, beep, nothing
                        FX5200 GPU G-Luxor
                        • kc8adu
                          • Nov 2003
                          • 8832
                          • U.S.A!
                          i have seen plenty.
                          found several exploded in an a power(crap) psu.
                          looks like the vent wasnt stamped right so they blew their bottoms out.
                          • incapacitance
                            • Jan 2006
                            • 29
                            Originally posted by yanz
                            PCE-TUR?
                            Wait, so even PCP&C uses bad caps? This is insane...
                            • Chris1992
                              • Apr 2005
                              • 561
                              My secondary box:
                              Chemicon KZE 1200@16 for VRM input
                              Rubycon MBZ 3300@6.3 for VRM output
                              one GSC 680@6.3 for audio
                              Chemicon TMZ 1000@6.3 all over
                              • banimal
                                • Feb 2011
                                • 3
                                I have a xfx motherboard that was frying video cards right and left. I have looked at all the caps and I don't see any that look bad how can I test them , none of then are bloated or leaking.....
                                • toastygoodness
                                  • Jul 2005
                                  • 813
                                  sounds like its your power supply rather than your motherboard.
                                    by momaka
                                    03-12-2025, 03:42 PM
                                  • eryjus
                                    by eryjus
                                    05-10-2023, 11:21 AM
                                  • Paxman_Swede
                                    by Paxman_Swede
                                    Hello!
                                    01-14-2025, 09:51 AM
                                  • captain150
                                    by captain150
                                    03-16-2025, 07:34 PM
                                  • Foetuss
                                    Gigabyte GA-6OXT :: caps question
                                    by Foetuss
                                    Good evening
                                    I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                                    Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                                    But I was also suprised about the bigger boys, which are 330µF 25V.
                                    Could it be they used 25V caps because they were cheaper / available at that time?...
                                    02-11-2025, 12:22 PM
