imaging/backingup dual boot windows 10 and windows 11
  • cyber16
    • Oct 2021
    • 16
    I am looking for a method that actually works.
    This would be a single drive with multiple partitions, like a 256GB split into two 128GB partition drives.
    I like to run both win10 & win11 on a single drive
    Also best method/software to restore onto larger drives?
    I have tried clonezilla, it always tends to lead to problems, only one of the two OS seem bootable, same results with windows backup.
    Just looking for a means of retaining a dual boot setup without a bunch of hassles afterwords getting it to work again.
    Anyone have hints/ideas to share?
  • diif
    • Feb 2014
    • 6978
    • England
    Re: imaging/backingup dual boot windows 10 and windows 11
    Do a search for "dual boot windows 10 and 11" there is no shortage of tutorials.
    • TechGeek
      Computer Geek
      • Jan 2015
      • 2254
      What cloning/imaging mode are you using with Clonezilla?
      Permanently Retired Systems:
      Kooky and Kool Systems
      sigpic
      • cyber16
        • Oct 2021
        • 16
        Just the default Beginner mode, then top choice savedisk
        I do the whole drive, but after a restore only one of the two OS are available for booting,
        both are there, all data is there
        • R_J
          • Jun 2012
          • 9535
          You can try doing a repair with bcdedit, it should find both operating systems and repair the boot manager so both os are again available.
          • claws77
            FX553VE-DM318T(FX553v) not POSTING
            by claws77
            Cpu i7-7700hq Ram - 8gb samsung, 32 gb sk hynix
            Gpu - nvidia geforce 1050ti
            Ssd orion o700
            Hdd hgst721010A9e630
            See images
            What's not working right?
            The system does not even POST, display is black,
            LEDs on - power led, aiplane mode, capslock fpr few seconds in the start(when connected to ac power) only.
            When did the problem happen?
            My laptop had dual boot setup, ubuntu and windows 10.
            It already had a moklist error, that would occur when i tried to boot ubuntu.
            05-17-2025, 04:09 PM
          • mr.malcom
            HP 17-cd0606ng no Windows or Linux Boot, exept idle=poll Boot-Parameter
            by mr.malcom
            this is a very strange Problem:
            Notebook hang instantly on Boot. BIOS is accesable.
            Windows: instant after showing "loading circle", even Windows Boot Stick hang instant (even without installed SSD/NVME )
            Linux: instantly (if Linux Boot in leagacy Mode with log messages: Machine Check exception after 0.25 sec)
            i have tried:
            - only one RAM Stick, another working RAM, both RAM channel
            - BIOS Flash to newest Version F.50, BIOS Reset
            - Memtest86 hang instant at Test 2
            - HP UEFI Diagnostic wont find...
            02-26-2022, 05:19 AM
          • eltano4i20
            [HELP] SAMSUNG NP270E4E-K01AR
            by eltano4i20
            1) Error trying to enter the BIOS
            --> [F2] won't let me enter the BIOS. To enter the BIOS, I had to create a shortcut and then type C:\Windows\System32\shutdown.exe /r /fw /t 1 in the destination. This forced it to restart and enter the BIOS.
            Once inside, I went to the BOOT menu, but, surprise, it wasn't there. I got the following message:
            BOOT PRIORITY ORDER (img-05)
            1- Windows Boot Manager
            2- SATA HDD
            3- NETWORK
            4- Debian
            2) Error trying to access the BOOT MENU
            --> I restarted the notebook and pressed [F10] but the BOOT...
            07-04-2025, 12:39 AM
          • japlytic
            DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
            by japlytic
            In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
            Tried (only with keyboard/mouse connected):
            • BIOS + database update
            • Using latest Windows 11 image built with official image creation tool
            • Previous setup version for Windows 11 installer
            • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
            • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
            • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
            06-19-2025, 04:59 PM
          • privato89
            Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
            by privato89
            I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
            Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
            Let's begin:
            Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
            03-26-2024, 06:37 AM
