WD2500 issues
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: WD2500 issues
    so post the smart data.
    • RJARRRPCGP
      • Jul 2004
      • 6304
      Re: WD2500 issues
      Originally posted by seanc
      Run MHDD on it, it may be able to fix the sectors. You can also use it to read the SMART attributes.
      +1
      ASRock B550 PG Velocita
      Ryzen 9 "Vermeer" 5900X
      Arc A770 16 GB
      eVGA Supernova G3 750W
      Alienware AW3423DWF OLED
      • RJARRRPCGP
        • Jul 2004
        • 6304
        Re: WD2500 issues
        Originally posted by stevo1210
        I give up. tried HDD regenerator and it freezes at 31MB...
        Wouldn't be surprised if you're getting the dreaded click of death.
        Arc A770 16 GB
        • gretti
          MSI Z370-A Pro, works but does not power off or reboot and USB issues
          by gretti
          I have a MSI Z370-A Pro. The board does not reboot or shut down from the Windows recovery console. USB communications stop and the status light on USB 1 stays on and does not blink. I have programmed a new BIOS with a CH341A programmer already, swapped RAM, PSU, CPU. The board will power off when the power button is held and resets when the reset switch is pressed, but it will not react to the reset switch if already told by software to shut down or restart. The board will reboot from BIOS after a save and exit command.
          The MSI BIOS included the ME firmware for the board. The size...
          10-16-2025, 02:14 AM
        • SoulFreeze
          Audio Issues - Realtek ALC3306 - Lenovo Slim Pro 7 14ARP8 - Type 83AX
          by SoulFreeze
          Hi, trying to troubleshoot some problems with this laptop I just finished repairing which had power issues (Burnt Buck converter - SY8883DFC shorted to ground).
          After repairing the above issue, I realized the following remaining problem,
          Sound only comes from bottom speakers, top palmrest speakers don't work. Neither does the headphone jack (static/buzzing).
          The computer recognizes headphones are connected and displays a popup in windows
          Sometimes, the computer will boot up and the sound will be working fine. However, if I run intensive programs and the computer...
          06-21-2025, 09:53 AM
        • Nagyesz
          Lenovo IdeaPad Gaming 3 15ACH - Ideapad 3 well known solder joint issues
          by Nagyesz
          I have a Lenovo IdeaPad Gaming 3 15ACH, which has started exhibiting the well-known issues of the Lenovo IdeaPad 3.
          All stress tests run perfectly, and there are no performance issues. However, the solder joints are almost certainly starting to fail. If the top two screws on the back are not screwed in, moving the screen results in a BSOD or, in some cases, a slight artifact and freeze. This is a 2023 notebook..
          How can I extend its lifespan? Could reflow help?
          It has ryzen 5 5500h, rtx 2050, no soldered ram.
          Example of the artifacts:
          03-01-2025, 11:11 AM
        • pwnjuice
          Bitlocker issues
          by pwnjuice
          Customers laptop had a Motherboard go bad and replaced it. they want to try to get data but. I am having bitlocker issues. I will list below
          Issue 1: When connect the drive to my computer to decrypt it I get this message. "there are no supported protectors on this drive the drive cannot be unlocked"
          Issue 2: When I run powershell as admin and try manage-bde -protectors -get e: I get this message. " ERROR: An attempt to access a required resource was denied. I also get the same error when I try manage-bde -status e: When I try the same with terminal with
          01-06-2025, 05:33 PM
        • Skgod
          Asus Rog strix g15 g513ih hn0865 and it's having display issues while running on igpu
          by Skgod
          Hey I am having Asus Rog strix g15 g513ih hn0865 and it's having display issues while running on igpu. Works fine when I open any game or whatsapp windows application. The issues are :
          Black screen, freeze
          The weird thing is that when as long as the laptop is running on igpu the problem keeps happening. But as soon as I open any game or whatsapp windows application, the laptop works completely fine.
          When the screen freeze or black screen I used to move the display lid up and down and it usually works like that.
          So can anyone tell me what would be the possible cause?...
          10-16-2024, 08:11 PM
