Can PSUs Cause Bad Caps?
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Can PSUs Cause Bad Caps?
    i heard newer ost's might be not so bad...
    Mann-Made Global Warming.
    - Dr Seuss
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      really. the newer ones i heard were holding up better in power supplies, like teapo. honestly.
      the old ones are shit, i know that.
      the one i have now still runs great... i put in my dad's computer... if it was shit, i would not be giving it to him...
      sigpic
      (Insert witty quote here)
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        RLS isn't new.
        Neither is a PSU that went in production in '05 and out of production in '06.
        If I look around I probably even have some bloated RLS from '05 & '06.
        I had a batch of FSP units loaded with them.
        - Dr Seuss
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          i thougt that qualified as newer... whoops...
          sigpic
          • c_hegge
            • Sep 2009
            • 5219
            OST has always been similar to Teapo and LTEC. Can be OK in a well cooled PSU but Only Some Trash on motherboards. Personally, they are not up to my quality standards so I re-cap all three of those brands in a PSU I intend on using/keeping, bloated or not.
            • Kong
              • Jul 2010
              • 19
              #26
              Have any of you seen any solid state capacitors in PSUs or motherboards go bad?
              Some companies advertise how they use Japanese solid state capacitors with their products. Are all brands of Japanese solid state capacitors generally regarded as high quality caps?
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                Solid State Capacitors would be capacitors formed into the silicon in IC chips..
                -- RAM and is essentially banks of Solid State Capacitors.
                -- Flash memory [including that in a BIOS Chip] is the same as RAM in that.
                So when you see bad RAM or a bad BIOS chip you are seeing bad Solid State Capacitors.
                Solid Polymer, Functional Polymer, and Organic Polymer caps [as various manufacturers call them] aren't solid state parts despite various advertising campaigns.
                Any part can fail.
                The failure rate of the various Polymer cap varieties is very low...
                ... probably somewhere around what it is for transformers.
                Watch out for electrolytics that -look like- Polymer but aren't.
                Sacon FZ are the the famous one but there are many others that don't get noticed because they don't fail in droves like the Sacons.
                - Dr Seuss
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  My point was as of 2006 OST is still crap.
                  - Dr Seuss
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    ~~ Stupid time-out glitch!!!
                    A while back I thought Capxon had 'become okay' in PSUs too but I've revisited that idea and changed my mind.
                    Seen too many blown Capxon in LCD's & TV PSUs w/ dates as new as 2008. Last week I cracked open an FSP 700 watt [built late 2006] and its packed with swollen Capxons. [The damned things are 8mm x around 30mm at 2200uF ... WTF-over?]
                    I see less OST than Capxon these days so I see less bad OST than Capxon.
                    ... But if I see 100 Capxon and then 100 OST the - % - of either that is failed would be about the same. [My guess is about 50%.]
                    ... If I added 100 Teapo to that comparison there the failure rate for Teapo would probably be less than 5%. [Better but not great.]
                    [But anymore Teapos mostly show up as primaries or 6.3mm and smaller caps except in total crap brand PSUs.]
                    - Dr Seuss
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      well, with that nidec beta sl fan, you can bet it is well cooled.
                      sigpic
                      • c_hegge
                        • Sep 2009
                        • 5219
                        They might be fine then.
                        • acstech
                          GrumpyModerator
                          • Jul 2007
                          • 1432
                          I have yet to see one of these AcBel units fail, in the 2 or so years I've been using them. Of course that doesn't mean that they won't fail at some point, but so far they've worked fine.
                          OBTW, concerning the 70% efficiency. That is probably a worst-case number, similar to their stated ripple specs. I can tell you that running in my computer this AcBel is nowhere near as high on ripple as they rate it.
                          A man convinced against his will is of the same opinion still.
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            Ads always give peak [best] efficiency.
                            That usually occurs at around 75-80% of rated max load.
                            It's less above and below that.
                            - Dr Seuss
                            • acstech
                              GrumpyModerator
                              • Jul 2007
                              • 1432
                              Is that why they put the > sign in front of the number?
                              • PCBONEZ
                                Grumpy Old Fart
                                • Aug 2005
                                • 10661
                                They test at increments like 70%, 75%, 80% and -hope- it's more between test points.
                                - Dr Seuss
                                • acstech
                                  GrumpyModerator
                                  • Jul 2007
                                  • 1432
                                  Would they not be considered to be lying if they published that efficiency was greater than or equal to 70% when it wasn't?
                                  Then why even publish it?
                                  • PCBONEZ
                                    Grumpy Old Fart
                                    • Aug 2005
                                    • 10661
                                    They don't want to say 73% and then get sued because some units only manage 71%.
                                    - Dr Seuss
                                    • eryjus
                                      by eryjus
                                      05-10-2023, 11:21 AM
                                    • Paxman_Swede
                                      by Paxman_Swede
                                      Hello!
                                      01-14-2025, 09:51 AM
                                    • captain150
                                      by captain150
                                      03-16-2025, 07:34 PM
                                    • Foetuss
                                      Gigabyte GA-6OXT :: caps question
                                      by Foetuss
                                      Good evening
                                      I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                                      Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                                      But I was also suprised about the bigger boys, which are 330µF 25V.
                                      Could it be they used 25V caps because they were cheaper / available at that time?...
                                      02-11-2025, 12:22 PM
                                    • black6host
                                      Replacement caps for Samson Resolv studio monitor 65A Amp board.
                                      by black6host
                                      Good day!
                                      I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
                                      I'm going to replace the caps and I'll be the first...
                                      02-06-2024, 08:22 PM
